How do i clear a 2101 error message scanning from olivettie d-copia6504mf
Posted by Christine Ruth... on
5 Related Answers
Anonymous
  • 25 Answers
SOURCE: ERROR CODE 2101 WHEN TRYING TO SCAN
you have to have a user name and password set up on the computer you are scanning to then you set theat up in the address you set up on the copier.
Posted on Nov 04, 2008
Anonymous
SOURCE: KM 3060 Scan Error 2101
Hi Guys,
I was getting the 2101 error as well. I resolved this by placing the IP address of the computer into the "host name" field. Only thing to remember is that your IP address will change from time to time. You will need to assign a static IP to that particular machine or give it a reserved IP address through your switch. Good luck!
Posted on May 27, 2009
n25an
Norman Davis
  • 622 Answers
SOURCE: I have a KM4050i and am getting 1102 and 2101 errors
the copier needs to login into each station... like a user logs in... but it needs admin rights... so whatever account is logging in must have admin rights number one... number 2 the folder must be shared with everyone and they bust have admin rights to the shared folder... you can change that after stuff starts working but for testing thats best... third make sure that you use the ip address... the login username and the login password of the pc you are scanning to... you use the ip address because dns can destroy connection if its not configured right meaning pc name may not be detected... to test ... just goto press scan... then attempt to edit the address book entry for the pc and scroll down to the smb entry and then test... you can test it straight from the copier changing settings and testing until you get a connection... this is after you have made all changes on the pc... now once you get a connection... you are good... any more questions or if you feel this is a bit jumbled... email me and we will set up a chat session and I will walk you through it...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 26, 2009
Anonymous
  • 74 Answers
SOURCE: scanning error 2101 scanning to smb file
you have to have a user name and password set up on the computer you are scanning to then you set that up in the address you set up on the copier.
Posted on Mar 27, 2010
Anonymous
  • 74 Answers
SOURCE: getting error code 2101 when scanning a document
Error code 2101 when scanning fs-c8020mfp
Check and replace your network cable. If that does not work then you must replace your network card.
Sep 15, 2018 | The Office Equipment & Supplies
How to scan with an olivetti d-copia 284 scanner?
You can setup scan to email or scan to folder. You use the web to configure this the easy way. Do you know the IP address of the machine? If you do, type it into your web browser address bar. The login defaults are Admin Admin (User and password are the same, don't forget the capital A). You can then setup an SMTP server for scan to email.
Sep 29, 2016 | Olivetti Office Equipment & Supplies
When scanning, error code 2101 is shown.... why is that?
pleas can you provide the make and model number of product
Jul 15, 2014 | Office Equipment & Supplies
Olivetti d-copia 16w error code H4
I need driver olivetti_d_copia_16w for winXp....
Sep 25, 2012 | Olivetti Office Equipment & Supplies
Digitech 2101 error messages
Hi there:
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
Dec 31, 2011 | Music
Scanning error 2101 scanning to smb file
Mar 25, 2010 | Kyocera Copystar CS-1820 Black and White...
Getting error code 2101 when scanning a document into our kypcera mfp cs 1820. What is the error and how does one fix it?
Mar 02, 2010 | Kyocera Copystar CS-1820 Black and White...
Oct 30, 2008 | Kyocera Copystar CS-1820 Black and White...
Hi Guys,
Oct 14, 2008 | Kyocera Mita FS 3800 Laser Printer
49 people viewed this question
Ekse
Marvin
Marvin
