Question about Becker GPS
Becker map module dead after firmware upgrade how to bring it back to life
Posted by Zeljko Jurkovic on
5 Related Answers
Richthofen
SOURCE: I tried to upgrade my firmware now it gives me the Rescue Mode Screen
I had the same problem while upgrating the firmware. I asked CREATIVE and they told me to reinstall the Windows Medial Player 11. I upgrated the firmware again and now it runs.
Posted on Dec 28, 2007
mccbala
Balasubramanian G
  • 36 Answers
SOURCE: dead mp3 player
the battery needs to be recharged or to the worse, replaced... try charging it for sometime, else u have no option other than replacing ur battery..
Posted on Mar 12, 2008
Anonymous
  • 6 Answers
SOURCE: can't find website for map upgrades
Here's what you're looking for:
http://www8.garmin.com/support/download.jsp
Good luck...their customer support is excellent! Call them!
Posted on Apr 10, 2009
IQUIT
  • 3940 Answers
SOURCE: DEAD DRIVE AFTER UPGRADE FAILURE
If you tried a firmware updateon the drive, and it failed and the drive no longer functions, then it is time to buy a replacement. Drives are generally available on Ebay for $25 to $50
Posted on Apr 13, 2009
Anonymous
  • 148 Answers
SOURCE: My O2 Atom life got dead bootloader.
I'm not using an Atom Life, so I don't have the flashing files for your device. But I think these links will help you a lot for understanding the process. First link is exactly for your device, I got it translated from russion to english by google, second is from a very good source, xda-developers. And the last one is not Atom Life but it is close so the pictures can help. You'll also need a JTAG cable. I hope this helps. (Because the only other solution than this is replacing your mainboard which will cost you around $300-$400) (http://translate.google.com/translate?prev=hp&hl=en&js=n&u=http://pda2u.ru/forum/topic338.html&sl=ru&tl=en) (http://forum.xda-developers.com/showthread.php?t=336278) (http://xdaflameusers.com/viewtopic.php?id=703)
Posted on Apr 21, 2009
The display went blank, changing battery didn't bring it back to life. I have 2 of these watches and have successfully changed batteries before, despite the tricky process. is this watch dead?
Unless the new battery is dead that would explain it, but assuming the battery is good it indicates a failure in the electronic module and should be considered done.
Jun 27, 2011 | Watches
DO YOU NEED TO UPDATE OR WILL IT STILL WORK?
Most updates fall into 2 categories: a) Firmware update. Corrects a problem(s) found in the firmware since the previous version that may provide more reliable operation, additional features, removal of features or other changes the manufacturer wants, and b) Maps update. Updates the installed maps.
In the case of "a" above, many times there is an explanation of the firmware update. Longer battery life, faster time to fix, additional bluetooth cellphone support, etc. It is best to review the list of changes to see if you want to upgrade or not.
In the case for "b", streets change, close and new ones pop up all the time. Using the latest maps will minimize the chance the you'll be sent over a road that either no longer exists, or has been rerouted to somewhere else. A map update may also rely on updated firmware (in "a") or might even automatically update firmware during the process.
Generally, updates almost always solve more problems than they create and add features rather than strip them. Map updates are nice to have - but you may need to balance the need for them with the cost of them. Not performing an update should not make the unit fail to work; unless there is something happening on a much larger scale than just your particular brand / model.
I hope this helps & good luck. Please rate my reply. Thank you.
Mar 30, 2011 | Magellan Maestro 3200 GPS
I removed the battery while it was installing the latest update. Now only the green power light comes on and goes off after a while and my psp looks dead.
Unfortunately as your PSP was in the middle of a firmware update it will not work again. If it is under 1 year old Sony will replace it free of charge but if it is out of warranty they will charge you. If it is an older type PSP you could possibly bring it back to life with a Pandora battery and a magic memory stick. Look under the battery to see what model number it is, either a 1000, 2000 or 3000. If it is a 3000 then there is no way to bring it back to life. The other models are able to be brought back to life using the Pandora battery. Let me know what model it is and I can tell you how to do it if it can be done.
Hope this helps
Aug 04, 2010 | Sony PlayStation Portable (PSP) Console
I had nokia3110c it is dead condition can anyone tell me that how to format it in this condition.
if it is dead then you can bring it to life only by using flasher kit , if you dont have on ,go to nearest nokia care center and ask for firmware upgrade
Nov 14, 2009 | Nokia Cell Phones
BL-C131 died during firmware upgrade
Seems to be a common problem for these cameras even without doing firmware upgrade. The finnish importer Kaukomarkkinat Oy will not acknowledge it and will only sell new ones to customers complaining about this.
Aug 26, 2009 | Panasonic BL-C131 Network Camera
Can't find website for map upgrades
Apr 09, 2009 | Garmin nuvi 255W GPS Receiver
Zune won't turn on or charge
man i have the same problem, i was listening to my black 120gb Zune & i just upgraded to firmware 3.0 & now this s*** wont turn on! i been using it 3 days fine, but now it just shut off like its completely dead. i have been charging it for hours & hours & it just doesnt even turn on or have a battery icon or anything! i have it plugged in now too. restarted the computer, everything.... i tried to restart it by pressing back & up... are there any other shortcuts i can try? computer doesnt detect it or ANYTHING!!! HELLLLLP
[email protected]
Sep 02, 2008 | Microsoft Zune JS8-00001 Digital Media...
Don't like PlaysForSure
Just convert all songs to Mp3 format - will save you hours of your lfie
Jun 07, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Dead mp3 player
Mar 01, 2008 | Samsung YP-U2X Digital Media Player
Load Main Image failed
Get the Sansa recovery tool for your model:
http://www.sandisk.com/Retail/DriverDownloads.aspx
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Feb 16, 2008 | SanDisk Sansa E280 MP3 Player
GPS Logo
121 people viewed this question
Top Becker GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Becker GPS Expert? Answer questions, earn points and help others
