Omg antique STEREO, back when PB was in USA ,
PB is now ACER.com in CHINA.
finding old books on things this old is not easy
google is your best chance, ever use google>?
first google it and has schematics. there.
https://audiokarma.org/forums/index.php?threads/help-me-pick-an-amp-design-p-p-el84-with-12ax7-driver.759935/page-2#post-10356387
join and learn how it works 6BQ5 output power amps, Push/pull.
not as good as real CLASS A amps of any kind.
the primary winding on the power transformer AC
may be tapped,
some transformer will run in 3 countries or more and switch or jumper to set , your countries voltage, 100, 120 or 250vac.
Iv'e repaired things like that back to 1965 and Ham gear too.
The primary must be wired correctly and 3 wire plugs best.
Hot
Neutral
Ground (safety)
OP, how to power it up. (generic answer first the more details last)
Jame Myers, all parts or sold now, but those custom transformers. and those can be rewound.
OP:2019 necro posted but for the reason of safety playing with 400vdc toys. ok?
read on.
well RTM read the manual first. (none found)
then strap it or turn the knob or switch
marked line voltage to your unstated countries AC line voltage, or blow it up and not you to or your home or the amp is fuseless as some are.(why is known)
make sure fuses are good. 1 or 2, can be.
depends ON COUNTRY SOLD. 250vac in some,
100v in others. 120vac 60hz here.
some rigs that old do not work at all on 50Hz power or burns up. (fixed many done that way)
the B+voltage if touched can be lethal.
the line cord must be with 3 wires, 1 green.
or a very danger to you, lacking any kind of real earth safety ground.
this amp is not some kind of magic amp
no different from any cheap amp made from 1950 to 1970+ transistors took over.
even heathkit sold lots of great tube amps
built many my self.
Class "A" bias amps are best, no crossover
distortion any human can here.
be safe and if wise use correct voltage taps on the primary of the transformer.
Most of these amps are 2 wire primary, but...
and use variac to power it first time.
if tubes who white frosting on glass they are full of gas. do not use those.
join here,
DPA-20 found in relic TV/COnsoles, maggot- box.etc
I see lots of lies there from kids, with no formal electronic training.
they do not understand CLASS TUBE BIAS
nor what those funny 2 caps are on the AC hot and neutral lines, those are RF filters.
aka DeathCaps.(2 wire ac IS THE *****)
keep noise from other things in the home from sending conductive noise to your Audio amp.
it is a filter and needs replacement so that do not catch fire, using modern versions , do ask me and can show that.
replace the old cap with a modern AC safety cap that's rated X1/Y2.(types sold at mouser.com) ask. can do.
one guy there does not know difference from AC impedance and DC resistance nor reflected impedance on a transformers (super complex)
370VdC IS LETAL AS IS AC HOT LINE LANDING ON THE METAL BOX. SEE RELIC BELOW PHOTOS.
the comments go 3 wire AC line is the only way, nobody ever today uses 2 wire with any kind of tubes and HV, 370vdc is lethal.
do not run any TUBE gear at all lacking the 3rd green (usa color) wire. (green-yellow in EU?)
https://audiokarma.org/forums/index.php?...[node]=14
1: NEW POWER CORD 3wire. 3 prongs.
2: STRAP THE PRIMARY OF ac TRANSFORMER TO YOUR COUNTRIES (HOME) VOLTAGE AC.
3: NEW FUSE MISSING OR MAKE SURE AMPS IS CORRECT. FOR YOUR LINE VOLTAGE.
4: LOOK FOR HACKS UNDER THE AMP CHASSIS.
5: tubes not broken or frosty white, all are bad.
6: power up with variac. first time,
7a: no smoke good, now try and input to the amp, (TV, phono, Microphone,or guitar.\ or any line audio near about 100mV.
even line out of PC but try not to blow up the PC .
some countries have 2 prong plug that only plugs in 1 way and the home is wired on one pin with actual earth ground and earth ground stake in the ground at the service entrance of the home. (3 wire is USA for sure)
SANS most tubes the 20 is here.
super old.
now the bad news, this is for a TV
to save money the TV makers , did not put series CAPS (1uf at 500vdc) in both inputs
and that was done on the TV side.
see?
that means any thing you connect now to 2 left and right inputs AF amps. will wreck the bias on both tubes grids and huge distortions.
all the Electrolytic caps are now bad, 100uf sized (large)
even worse the amp has no fuse on some models
but in the stead, used the TV fuse for protection, never run any Amp with no fuse.
there are lots of variances from PB
and is in the contract from TV maker to PB
and all that is a secret.,
that means only looking for horrors here matter.
and I can not see yours.
AC side can be a horror see this mess.
Safety then was zero
no ground in homes (2 pin wall AC jacks)
so safety not a worry then.
easy to fix , new cord and new strain relief.
and a fuse socket added.
120vac, 1amp SB fuse to start if blows try 2.
max line watts 50w I think. (mostly wasted heat that)
SOURCE: my power supply for packard bell blew up due to much power,so i
The style of power supply is different from a universal power supply. A universal power supply won't fit in the slot properly.
This website has it for fairly cheap:
http://www.partstore.com/GetModel.aspx?MfgName=Sumitomo+Group&BrandName=Packard+Bell&ModelNumber=845061&Page=1&SortBy=idealitemnumber&SortDirection=desc
SOURCE: Packard Bell Easynote, when laptop
First, try wiggling the power cord while it is plugged to the laptop. Notice the power LED while doing this. Does it blink?
Next, do you hear any beep sounds from the laptop after you switch it on?
Next, check if any external device are attached to the laptop. If any, disconnect all of them then try to power it up again. If it did not work, notice the sounds of the fan & hard drive. Do you hear any?
Please answer these questions so that we could build a picture of what could be the root cause of the problem & what we could do to fix it.
SOURCE: packard bell easy note tj65 will not power up
the short cable running from the power button to the main board has probably snapped where it passes over the RH hinge. remove the screen surround to gain access to the power on switch area and check. it would seem to be a common fault with the packard bell
