Question about Tablets & eReaders
I have a Kodak mini projector and when ever I plug it in to my iPad it will say "warning no device connected" or it will connect and then unconnected right away. How do i
Posted by Maddison reist on
3 Related Answers
Christopher Buono
  • 20 Answers
SOURCE: how to connect an asus transformer to a phillips picopix 2055 projector ?
you cant, directly at least... there are no drivers for android to run this projector. since it is only USB, you cannot convert the hdmi to usb...
you could use your computer as a middle man, without hdmi input on your pc there would be video lag and your better off just using your pc.
you could return the picopix you have and get the PPX2480 version, that is brighter and also has hdmi input which you could get a mini-hdmi to hdmi cable and use it directly.
hope that helps
Posted on Feb 28, 2013
Speed up download & up loading on iPad mini 4
You can't speed up the device only the internet connection. My internet connection also supplies my television signal from Bell so I have 125mbps. It is blisteringly fast. The device you have is only held back by the size of the 'pipe' that the date travels down. Your iPad Mini is plenty fast enough, your internet connection isn't.
Upload a file from home and time it. Upload the same file from MacDonalds when the place is EMPTY and time it. The place must be quiet as you are all sharing the same connection.
Dec 25, 2016 | iPad mini Tablets & eReaders
My IPad mini is showing info when I open it -disabled try again in 60 minutes, how do I fix it
you need to connect your iPad to a computer that has iTunes then hard reset it by pushing the sleep /wake and home button till you see the iTunes logo on your phone, then you'll see and option on the computer screen to restore, then click restore then wait for it to finish, then you can setup your device like new
Forgot passcode for your iPhone iPad or iPod touch or your device is...
Jun 23, 2016 | Apple iPad Mini
I need to update my ipad mini to 9.3 to run an app. I get the error message that the device is not connected to the internet but it is !!
Good morning to you.
what I do to ensure that my mini pad is connected is to be near the router and:
  • I go to settings and look at the Wi-fi and see if my service provider is there
  • then I see if I can open a newspaper, I use that web paper to find out if I am connected
  • if this works I know I'm connected.
  • if that does not work I go back to settings
  • and Wi Fi that opens for available connections
  • choose your connection
  • write the password on the password line
That procedure helps me.
kolbrun
May 09, 2016 | Apple iPad Mini
How do I find the IMEI code for a mini iPad?
Find iPad Mini IMEI number:
Navigate to settings-general-about, and scroll down to view your device's IMEI number and other details.
Device body and packaging
Check the back case of your iPad, and you'll find the IMEI number printed near the bottom. If you have the packaging too, look for the IMEI number on the barcode label.
ITunes
Connect your device to your Max or PC, fire up iTunes and click on your device name to open the summary. You'll see your devices name and capacity listed alongside an image of your model - simply click the field below the Capacity field once or twice, till it shows you the IMEI number. You can also right click the number to copy it.
How to find your iPhone or Cellular iPad IMEI number
Nov 21, 2015 | Apple iPad Mini
An ipad in lost mode can not unlock....do not have icloud info
When the iPad was set, there was an Apple iTunes account connected to the iPad. Apple would not have activated the device. You should be able to get a message to the mail address that you connected to that account. Ask Apple to reset the password via their support. Go here:
https://www.apple.com/support/appleid/manage
Apr 25, 2015 | Apple iPad Mini
I was trying to get the original screen with the installed apps back on my ipad mini after failing to do a factory reset but was unsuccessful. How can I get it back?
In your settimgs go to back up/restore. There should be the option to factory reset your device. Click it, after confirming you want to reset, your device will reset back to its original settings.
Apr 14, 2015 | Apple iPad Mini
Why does my I pad mini keep telling me to plug into i tunes
Could be your operating system didn't update properly...... By connecting to iTunes you can reinstall or update from there!
Feb 06, 2015 | Apple iPad 2
My daughter was trying to update her ipad mini and it froze up and it has a picture of itunes and like a picture of a cord going to it
- to update is now only possible with connecting the device to iTunes on a connected computer.
Plug it into your computer and open up itunes, under devices click on your ipad which should appear on the left and then click on check for update. daughter-trying-update-her-ipad-mini-idk31xyog1zytopaznkz4ivh-2-0.jpg daughter-trying-update-her-ipad-mini-idk31xyog1zytopaznkz4ivh-2-2.jpg daughter-trying-update-her-ipad-mini-idk31xyog1zytopaznkz4ivh-2-5.jpg daughter-trying-update-her-ipad-mini-idk31xyog1zytopaznkz4ivh-2-9.jpg
Jul 08, 2014 | Tablets & eReaders
Tablets & eReaders Logo
167 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
