Question about Epson Office Equipment & Supplies
How do i get to the waste ink tube on my epson artisan 710? I want to install an external waste ink tank.
Posted by Paul Hirata on
5 Related Answers
Anonymous
  • 159 Answers
SOURCE: Clean "Waste Ink Cartridge" Epson R300
Had the same problem. (its a work around without removing the waste ink pad)
Took alot of work but I fixed it.
Frist thing you need to know that error means your ink waste pad is full. Its a $75.00 to replace but there is a work around it.
You will need this free app. SSC service utitlty.
http://inkjetprinterhelp.us/epsonSSC.html Its a great app.
Instrusctions are on the website there.
You will also have to Open the access panel on the rear of the printer (remove screw) and look inside carefullly with a flashlight. You will see a tube (down and to your left) coming from the cleaning pump and it will have an open end on it. This is the tube that delivers ink to the waste pad.
Use a piece of coat hanger wire or equivalent, and fish out this piece of tube. Bring it to the outside of the printer, thru the access panel.
Find yourself a suitable container (Tupperware or a plastic cup or jar) that is not too tall. Put the tube into this container and secure the tube and container so they won’t come apart or lose connection if the printer is moved.
If you wish you can make a hole or notch in the access panel cover so it can be replaced.
Posted on Feb 14, 2009
websnail
Martin Smallridge
  • 419 Answers
SOURCE: Epson R285 need service utility
It sounds a lot like you have managed to reset the printer using the R290 adjustment utility and it now thinks that your printer is an R290 printer.
As a result it's rejecting the yellow cartridge (presumably the first to read empty since you reset the printer) and expects you to provide R290 consumables.
The only fix that I've heard suggested (and I'm still waiting to hear if it worked) if to get someone with a valid R285 to use the same adjustment utility to make a backup of the EEPROM data (nothing else), save this file, send it to you, and then for you to restore that same data to your own printer EEPROM.
As I said, I haven't heard if it works and I could be wrong about the cause but as I provide waste kits myself and have already had quite a few people report a similar issue I suspect I'm about right.
Hope that helps.
Martin
Posted on Jul 07, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: Have a need to reset the waste ink counter on an
Hi
I looked around for you and I have found some links for you to look at it tells you what you need to do, just click on the links and have a look.
Link 1 = http://www.wasteink.co.uk/waste-ink-mods/epson-artisan-800-mod/
Link 2 = http://freedomtoprint.com/epson-inkjet-printer-reviews/epson/artisan-800/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Jan 31, 2010
pineworks
Clive
  • 4345 Answers
SOURCE: Waste in ink tank near full
Hi there
There no easy way the printers are been made this way so you take them to the shop, but if you are handy with your hands and know what you are doing then you will need to take all apart and take out the ink pads inside the printer and clean them up make sure they nice dry when put back in, then you are going to need a program that you can find on the internet it will be called waste reset tools, or your printer will not work even after you done the clean out.
I am not sure what canon you have so I cant tell you the tools you need for yours, i have got canon MP-Tools on my website if this is the one you need.
with this you can reset the waste ink tank before you do the clean out but remember in time you will need to clean out or it going to be a big mess of ink coming out your printer.
Click Link = http://www.4all2sell.com/reset-tools/MPTool.exe
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All files on my website are only there for a limited time
Posted on Apr 25, 2010
Anonymous
  • 1382 Answers
SOURCE: Epson Artisan 710 won't print black
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results..
Thank you!!
Posted on Jun 09, 2010
How can reset epson artisan 730 using ssc service4.30 in winddows 7/8
Download WIC Reset Utility - Free - 2Manuals.com
www.2manuals.com > ... > WIC_RESET
Operation Systems: Windows XP, Windows 7, 8, 10, Mac OS ... THE WIC ResetUtility WILL RESET Your Epson Inkjet Printers WASTE INK COUNTERS ... 700, Artisan 710, Artisan 720, Artisan 725, Artisan 730, Artisan 800, Artisan 810, Artisan 830, .... Q.: If I buy 5 RESET KEYs I can use them for different printer models?
WIC Reset Utility - Reset Epson printers Waste ink Counters
wic-reset-utility.blogspot.com/
Oct 5, 2014 - Artisan 720.725\Artisan 730\Artisan 800\Artisan 810\Artisan 830 .... If I buy 5 Reset Keys CAN I use them for different printer models? .... The Windows 7 WICReset Utility - for Waste Ink Pad Counter reset - Service ... Reset epson printer protection counter using ssc service utility, reseter epson r220 [...]
Printer Manual: SSC Service Utility for Epson Stylus Printers
printermanua.blogspot.com/2014/.../ssc-service-utility-for-epson-stylus.h...
Feb 22, 2014 - Problems with Epson printer, the red and greenness lightheaded ...
What printers will take espon ink cartridges 99
The products that uses the T099 ink cartridges are the following:
  • Artisan 700
  • Artisan 710
  • Artisan 725
  • Artisan 730
  • Artisan 800
  • Artisan 810
  • Artisan 835
  • Artisan 837
1helpful
How to reset epson t 60 printer
Depends on what you mean by "reset".
If you're referring to the waste ink counters, you can either:
  1. Locate a copy of the AdjProg service utility and use that to reset the waste counters
    Note: Will not work on MacOS or Windows 8
    ... or...
  2. Download the WICReset (for windows) or iWIC (for MacOS) and purchase a WICReset key to reset the waste ink counter that way.
Whatever you do, remember that resetting doesn't deal with the waste ink inside the pads so you should be looking at changing the pads (not easy to do yourself) or fitting an external waste ink tank like a printer potty.
How do i clear ink pad at end of life code
download adjustment program for epson to the net
1helpful
2answers
Epson Stylus Photo RX 340 Started getting message "Parts inside your printer are at the end of their service life" and now it won't work. It was working just fine. Remember coming across this complaint...
Wrong you can save the printer by installing an external waste ink tank and resetting the code.
don't replace the ink pads install a external waste ink tank instead, then reset the printer using reset program . . search on eBay for epson waste ink tank comes with reset program. I got a tube one for mine and it saved my printer.
2answers
I have a problem with my printer epson stylus C90. may i know what todo when parts of my printer are near the end of their life service.?how can i fix it?
It means waste ink pad full or nearly full. Reset waste ink counter using SSC ver 4.30. Find at indoreset.blogspot.com. Don' forget to replace pad, washing or extend outlite pipe to outside of printer.
3helpful
2answers
2helpful
Ny epsom r360 reads ink pads saturated
don't replace the ink pads install a external waste ink tank instead, then reset the printer using reset program . . search on eBay for epson waste ink tank it incudes the reset program.
Printer send s message Life of parts ending
The "end of life" message means that the waste pads are full of waste ink.
You need to either:
  • get the printer serviced at an Epson service center
    OR
  • install an external waste ink counter and reset the waste ink/protection counter.
All the information you need to install an external waste ink tank is available from here:
http://www.continuousink.info/forum/viewtopic.php?t=4096
Resetting the waste ink counter is easily done using the IPR utility which you can read more about and find downloads for, from here:
http://www.wasteink.co.uk/epson-ipr-reset/
Hope that helps..
Martin
Open Questions:
Top Epson Office Equipment & Supplies Experts
Ekse
Randy Prevost
Randy Prevost
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
