Question about Frigidaire ATF6000ES Front Load Washer
Open up the back panel. taped to the right hand wall (looking into the opening) is a tech guide that will show you how to put the washer into a diagnostic mode. very easy.
Posted on Apr 04, 2010
Sound like you need a door lock. your door lock is not locking or not tell the control that it is locked.. should try 6 times to lock before it will give up trying... hope it helps
Posted on Sep 19, 2009
Oct 05, 2013 | Washing Machines
Sep 11, 2013 | Frigidaire ATF6000ES Front Load Washer
Jan 11, 2013 | Frigidaire Washing Machines
Sep 19, 2010 | Frigidaire Affinity ATF7000E Front Load...
Mar 10, 2010 | Washing Machines
Feb 17, 2010 | Frigidaire Washing Machines
Dec 03, 2008 | Frigidaire Affinity ATF7000E Front Load...
Sep 18, 2008 | Frigidaire ATF6000ES Front Load Washer
Sep 02, 2008 | Frigidaire ATF6000ES Front Load Washer
Mar 25, 2008 | Frigidaire GLTF1670A Front Load Washer
480 people viewed this question
Problem is, its not giving the signal like it normally would when the door isn't closed (It usually just beeped 3 times and stopped.) Whereas, when you listen and watch the control panel, it thinks its running right.
