You may have the Miele problem. The line that drains the fan housing gets plugged with glop. You just take it out and clean it.
This happens every year or two. Take off the outside front panel to access the hose that runs from the bottom of the fan down to the dispenser, and lets the water drain out through it to the interior. Clean out that hose as well as you can. Replace. This is an idiotic problem that Miele should have a permanent fix for. Grrrr.
The hose cleans out quickly, the problem is getting the front back on. 4 hands make it easier. It slips on when you start close to vertical, then slip in in and down. For putting the screws back in, you might have to use a micro screwdriver to re-align the little clips on the door panel. (You will see what I mean when you do it!) This costs a service call ($100, give or take) to call for service. It can be done at home with no added parts. I think it applies to all Miele dishwashers, and I have now done it several times. As I said before, this is a design fault and should not be necessary!
If you have a helper to help contain the mess, you can spray water into the fan area (best is backward through the hose, but try all directions) and catch the runoff. We have done this and it catches a lot of gunk.muck and slop.
Doggone design sucks on an otherwise nice machine!!
SOURCE: Miele G868 dishwasher - leaks from front panel air vent
Hi all,
I have had the same problem. Here is what I've done. Take the door apart (a whole bunch of screws on the side of the door). The front panel will come off and you will see a rubber tube. Take it off and blow it out. Then take the blower out (you need to unscrew the inside of the blower). Take apart the blower and clean it out.
Good luck.
SOURCE: leaking from the bottom a lot, immediately when I start the cycle
I found this post on another website. Hope it helps:
"Six torx screws securing the fine mesh filter just below the lower
spray arm. Make sure they're all tight. Bit size is T 20 also, check
for damage to the mesh screen. What happens when those screws are loose
is water pressure seeps under and creates a tidal wave sort of effect
by spraying water forward instead of thru spray arm...long shot, but
I've seen it 50 times."
SOURCE: My Frigidaire refrigerator water dispenser
lift up & out on the drip tray (it will come out) after removing it you will see 3 screw. unscrew the screws & lift the face plate of the despenser & it will come off. Be careful though. There is a ribbon wire connected to the back of the face plate. make sure to dissconect the ribbon wire from the control board not the back of the face plate (its alot harder to reconnect to the face plate & pretty simle to reconnect to the control board).
SOURCE: Miele dishwasher drying problem
you need to remove the front of the door.there is a small pipe from the dryer fan to the top of the detergent dispenser. tis usualy gets blocked at the fan end. also the spout from the fan. this happens if you dont rinse loose food of the items you put in the dishwasher.
SOURCE: I got a Whirlpool AW Z 865 dryer. It is a
I had a similar problem with a Whirlpool AWZ 8578 Tumble Dryer. The solution was to clean the fluff out of the rubber grommet in the drain hole under the left front of the condenser. Then the water from the condenser could run into the collection container underneath.
