Question about Refrigerators
Frig model gfss6kkycss flashing pc and er - Refrigerators
Posted by Steve Sheppard on
I have a GE refrigerator model gfss6kkycss with a Samsung ice maker model DA97-07365A the problem is it is not making any ice and the water dispenser is working fine
-Make sure turn the ice maker " ON"
If it's on then the Water valve to the ice maker might not function.
Good luck
Mai
Oct 26, 2017 | GE Refrigerators
My lg frig display screen says "Er" and registers just 1 degree. Normally it registers freezer and frig temperature.
could be that the icebox is defrosting itself but you can check on google and you maybe able to find why else the error code comes up
Jan 07, 2017 | LG Refrigerators
I have a samsun fridge and the code pc er came on and the light is not working nor the temp why????
"PC-ER" its a error in the PCB (computer).
Try resetting the control panel by depressing power frig and power freeze for more than 8 seconds. You may have to unplug the unit for 20 minutes if the compressor it very hot and not starting. You may have to depress power frig and power freeze to reset the units control panel to restart the compressor after the 20 min let the cooling system stabilize period.
Samsung says that... if the code "PC-ER" appears on the display panel or if you cannot resolve the issue, the refrigerator needs to be repaired. Contact a Samsung service technician.
Hope this helps.
Jun 09, 2011 | Samsung Refrigerators
Sul display del frigo appare er pc lampeggiando
Code PC Er is saying there was a momentary power loss.
If after all of this you still have issues with the lights or the unit is not working properly just repsond here and we will help you.
Hope this helps to solve it.
Jun 04, 2011 | Refrigerators
Getting a er f1
are you sure this is a refrigerator . f 1 code is in most case a renge code and it is a stuck touch pad . you will have to replace the touch pad to correct problem .. if its a frig i need a model # and a brand to hepl you more .. mm majic **** and thanks for using fix ya .. mm
Oct 21, 2010 | Refrigerators
Kenmore Refrigerator 65812
camp, see if your model starts with 106.65812, Serial beginning with EP or ER. If so it may be the air tower. They had a service flash out on this line but the closest I can get to your model number is 106.65824. E-mail me at [email protected] with the complete model and serial and I will see if I can help you. If your model doesn't start with 106, repost with the correct one. Catriver.
Jan 22, 2007 | Kenmore 65812
Refrigerators Logo
123 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
