Question about Locks & Locksmithing
I have locked my keys in the safe and have forgotten my code. Can I reset a new code so that I can be able to open up my safe again? Have tried to use the manufacturers code but no luck.
Garrison electronic safe EA20 Serial # EX2006274214
Posted by Mary Dracos Malanos on
5 Related Answers
Anonymous
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
Anonymous
SOURCE: need to reset the electronic code to open the safe.
are you the manager user of the safe?if yes,you can reset a new code by yourself.
Posted on Apr 09, 2009
Anonymous
SOURCE: gordon electronic safe and can't open it
Wow , I have the same safe thats been locked for more than a year.
I locked the keys in the safe and forgot the code.
I took the thing out side and droped it on its corner and whala.
go figure it worked ,thank you to who ever was the first 1 to try that
cody in west palm beach,fl
Posted on Apr 25, 2010
Anonymous
SOURCE: Detroit electronic digital safe lost code and keys
Help, just boughta Detroit digital safe, code number to open my instructions are locked inside.
Posted on Aug 20, 2010
SOURCE: CAN NOT OPEN MY SAFE,
To retrieve your lost sentry fireproof safe combination. First, find your safe's Model and Serial Number. The Serial Number is printed on the small label on the right side of safe (on paper tag near hinge) or under handle. As this information is confidential a valid credit card and email is needed to verify a customers name and address
sentry safe combination archives searches. Do come with a service charge although it's definitely cheaper then buying a new home electronic sentry fireproof safe.
A
good locksmith should be able to help you with the dialing programming instructions and lost Sentry Safe Key Replacements
Posted on Sep 18, 2010
Mother just past away,luckily safe was open at time,but dont know combo to keypad or we haven't found a key,how do i reset code to sentry10 gunsafe
To reset the combination on a Sentry safe, open the door of the safe, delete the existing codes, press the PROG or P key and enter the factory code. Finally, enter a new five-digit number as per individual preference, which is the new user combination.
It is always prudent to reset the combination on a Sentry safe when the door is open because it prevents the user from being locked out. To open the Sentry safe door, type the five-digit factory code given in the owner's manual. This factory code cannot be altered.
To delete the existing codes on newer models of the safe as of 2015, press the P button. Then, type the factory code and follow it up by inputting "00000" into the safe. On older models of the Sentry safe, press the PROG button and type the factory code two times.
After deleting the existing codes, press the PROG or P key and then enter the factory code once again. Within five seconds, type a new five-digit number, which is the new user code. To verify if the user code is working, retype it and then close the door of the safe. The user code is the primary code for opening the safe, and users can reset it as often as they want too
Says code error
How To: Open A Locked Sentry Safe If You Forgot ...
? 5:21
https://www.youtube.com/watch?v=Mr8QrvVAtuI
Jul 15, 2014 - Uploaded by TipsNNTricks
I show you How To Open A Locked Sentry Safe If You ForgotThe Combination Or Loss Your Digital Code Or Lossed Your Key. The Sentry Safe ...
' Sentry® Safe ' Lost Your Combination
https://www.sentrysafe.com/.../Lost_Your_Combination
Sentry GroupCombo Recovery. What you'll need: Model Number; Safe Serial Number; Notarized Statement of Ownership. Step 1. Safe Info. Step 2. Notary Form. Step 3
opening a electronic safe forgotten the lock code ready to ...
www.instructables.com/.../OPENING-A-ELECTRONIC-SAF...
InstructablesJul 6, 2009 - I HAVE A SAFE GAURD COMPANIES SAFE I HAVE FORGOTTEN THE LOCK CODE TO OPEN IT. THEIR IS NO ALTERNATIVE OF KEY ...
How to Crack a Safe (with Pictures) - wikiHow
My safe, a Cathedral EA15 Will not lock. Any suggestions people?
Instructions
  1. 1
    Enter your code on the keypad located on the front of the safe. Some electronic digital safes require you to input a special character like "#" before and after your code. The safe should either beep, have a LED turn green, or display "OPEN" if you have correctly entered the code.
  2. 2
    Turn the handle to the right within five seconds of correctly entering the code. If you wait too long, the safe will lock and you will have to enter your code ag
Open the safe with a key. Use your emergency key that came with the safe to open it if you forgot the code or if the batteries have died. Remove the key cover from either the handle or the control panel to reveal the lock.
  1. 1
    Enter your code to open the safe.
  2. 2
    Place the electronic digital safe into code reset mode. On some models you need to hold the last digit of the code or press the "*" button to get into code reset mode. Other safes require you to open them and press a small red button on the inside of the door.
  3. 3
    Enter your new code on the keypad and press "#" to finish. Some safes may require you to press "*" or a letter to finish the code. If the safe requires it, enter the new code again to confirm that you entered it correctly.
  1. 1
    Use your code to open the electronic digital safe's door.
  2. 2
    Locate and remove the battery cover on the inside of the door.
  3. 3
    Replace the used batteries with new ones. For most safes, this will require two or four AA batteries.
  4. 4
    Test the batteries. Use your code while the door is open to test the batteries before closing the safe.
Change code
If you can get the door open.
There is a reset button on the hinge side of the inside of the door.
Press the reset button, and then you have about five seconds to enter your new code.
Test the code with the door open!
That way, if it does not work the first time, then the doors is still open, and you can do it again.
Warning: Place fresh batteries into the battery compartment before doing this, or you will just get locked out again.
If, you cannot get the door open, and your keys are locked in the safe, then call Harbor Freight.
Call Harbor Freight:
Technical
& Parts (Safe Keys) 1-800-444-3353
Give them the key code number. (it is located on the key insert, where you stick the key in the lock)
It takes about two weeks to get a new key/keys.
6helpful
Kingavon electronic safe 28
  1. The original factory code is 1-5-9 A (or B) to open the safe. There is usually an override key for your safe in case you have lost your code.
  2. Once the unit is open, you can reset the combination by pressing the red button, the yellow light will come on. Input a new code 3-8 numbers and then either the A or B button to finish the code.
  3. Test your new code several times before locking.
  4. If you don't have an over ride key, the first three digits of the serial number should be the key code.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
33helpful
5answers
How to unlock a cathedral electronic safe ea25
After opening the electronic safe (with the pre-set factory code of 159B) locate the small red button on the
inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep. DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits long, and confirm your new code by pressing the letter “B” on the electronic touch pad. Before you close the door, try the new security code to make sure the lock release the knob so you can turn it and retract the live action locking bolts.
If the code fails, go through steps 1-3 again. If the code works successfully, then you should lock the safe. When you open the safe in the future enter the security code you have set followed by the letter “B” and turn the knob.
If the incorrect security code is entered 3 times you will have an automatic lockout for 20 seconds before you can try your code again. If the incorrect security code is entered 3 additional times there will be a 5- minute lockout before the code can be tried again.
BATTERY REPLACEMENT
This safe uses 4- AA batteries. Under normal use, batteries will last about 1 year. When the battery is low, a red light will come on warning you that the battery is low. To test the batteries, enter your security code. If the batteries are low the red light located in the middle of the top of the keypad will start to flash.
To replace the batteries, open the safe door with your security code and turn the knob. Push the batteries cover plate, which is located on the back of the door, and replace the old batteries.
YOU MUST PROGRAME YOUR SECURITY CODE AFTER YOU REPLACE THE BATTERIES. SEE STEPS 1- 3 UNDER “ENTERING YOUR SECURITY CODE”.
TROUBLE KEY
A “Trouble key” has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
MAINTENANCE FOR KEY AND ELECTRONIC SAFE
If the door of the safe starts to rub on the door frame, open the door per the instructions above. By the door hinges you will find a threaded stem. Use an Allen wrench to tighten the threaded stem. This will help realign the door and give you trouble free access to the contents of your safe.
15helpful
2answers
Gordon item#45891 digital safe, lost code the door is open
there is red button on the inside of the door (hinge side) press this , then key in a new code
228helpful
10answers
Forgot pin code to unlock my hardline digital safe
I have pin code but batteries went flat while I was on holiday, how do I unlock my Hardline digital safe? I do not have override key
Locks & Locksmithing Logo
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
