T
Terri Forster Posted on Oct 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wall Arco SE, first time to recharge batteries and won’t recharge
Tom Chichester
Level 3:
Top Expert:
  • Audio Player... Master 62,329 Answers
  • Posted on Oct 29, 2020
Tom Chichester
Level 3:
Top Expert:
Answers
62329
Questions
0
Helped
672062
Points
975369
1. Defective batteries
2. Defective charger
1 Related Answer
k24674
  • 8093 Answers
  • Posted on Jan 04, 2010
SOURCE: tom tom 125.se will not recharge battery threw my
You have another option. Connect the GPS unit to a USB port on a computer. And please use the USB cable supplied with your unit.
My Samsung Galaxy II won't recharge , though the battery can be charged in another SGS II ?
Time to start your collection of Dead Phones... put double tape on the back of phone and stick it on the wall.. When you look at it..it will remind you of the money spent...!!>>
1helpful
My battery for my mp3 won't last long
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
1helpful
Nwz-w262 battery will not hold charge
Nikon camera battery keeps losing charge
Battery Uses
Needs screws for a Wahl 8786451A Arco SE Pet Clipper
I would take it to Home Depot or Ace Hardware and gently try to fit screws in until something fits easily. Then adjust up or down for the correct length. Should be pretty easy.
Hope this helps! Dont forget to rate!
My zen vision m 30 gig only comes on when plugged into the mains
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
4helpful
3answers
HTC battery wont charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
I have a philips se 455 cordless phone that won't hold the charge at all and was considering getting rid of it until I saw this site and read that I should be using rechargeable batteries ? Will this...
well it very well may see they rate batteries in mah normal duracells and thing are usally only 800-900 mah milli amp hours a good rechargable battery can be from 2200mah i have seen them up to 3200 mah for phones so yes a rechargable battery would last longer in the phone as they have a higher mah or in simple english longer discharge time
if it helps please give 4 thumbs up it helps me continue to help all of you thanks
May 12, 2011 • Cell Phones
 Grubhead
Grubhead
SmartAviator
SmartAviator
