Onn bluetooth speaker startup/shutdown voice volume is too Loud. Can it be adjusted or turned off?
Posted by Jennifer Heinze on
5 Related Answers
Anonymous
SOURCE: RCA Home Theater Model RTD215
cox digetal cable universal remote will not work with this system now i have 3 remotes for tv,cable, and now my home theature system
Posted on Feb 17, 2008
Anonymous
SOURCE: internal speaker volume
how skin install in moto e398
Posted on Sep 04, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: VSX-D608 Overload and shutdown
Overload is displayed when the amp draw is excessive, and can be caused by different faults.
when Overload is detected, the protection circuit will shut down the unit to prevent further damage.
The first thing to try is hard reset. Shut down the unit for about one hour to drain power completely.
This can fix minor problems that can cause overload, for example electrostatic charge accumulation on internal capacitors.
If that does not fix the problem, then you must find the fault.
Overload can be caused by shorted speakers, wrong impedance speakers, or by a contact on speakers wiring.
Check speakers connection and test different speakers with 6, or better 8 Ohms impedance.
Another test can be done by unplugging all speakers, and reconnecting and testing them one at a time, at a very low volume.
No more than two 4 Ohms speakers can be connected to the unit, or you will get overload.
If the speakers are OK, then preamp, shorted input/output connectors, main power supply or faulty output transistors can draw too much amps causing overloading.
In that case it is recommendable contacting Pioneer at the number listed on the owners manual.
Posted on Jun 22, 2009
Anonymous
SOURCE: Tom Tom no sound
Let the battery get full charge.
Take the SD off.
On the bottom push in the RESET at least 15 SECONDS.
(It will go off, but it is resetting)
After that press the POWER ON for 5 SECONDS
Put in back the SD card.
Done.... easy!!!!!
Posted on Oct 02, 2009
sarasvatas
Sarasvatas Kumar
  • 329 Answers
SOURCE: There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Posted on Oct 03, 2009
How do I pair speaker with phone
turn both phone bluetooth and speaker bluetooth off. then turn them back on. the speaker's light should be flashing indicating its searching for a device to pair with. as its flashing make sure your phones bluetooth is visible and searching. they will pair and your phone will tell you and the speakers light should quit flashiing and just remain on.
Oct 20, 2014 | Audio Players & Recorders
How do I turn the speaker on?
You can turn on (or off) the voice guidance ... to announce the driving instructions.
Make sure you select (in your Speaker Preferences) ... the internal speaker ... your Sound is turned ON, your Volume Slider turn up (high), and select (a Voice Preference) as a computer voice... and select the ENABLE Voice option.
In Speech Preference, select the situations which you want instructions/directions/warnings to be read out loud.
Apr 15, 2013 | Tomtom GO 720 GPS Receiver
My left speaker is loose
The symptom you are describing is exactly what is known as a "BLOWN" speaker or the voice coil has "shorted", this is caused from the volume being up to loud, heating up the voice coil and frying it, in the future if the bass/sound is distorted then turn the volume down just enough to stop the distortion and this will save the speaker.
As far as getting a replacement speaker, you will have to contact the manufacture to get a replacement.
Good Luck !
Apr 21, 2010 | Philips FWC577 CD Shelf System
VOICE TOO LOW
When you talk on you phone make sure your volume label is up. There is a key in right hand site on top. Press up / down for adjusting the volume. if you seen the volume label is fully up but nothing to be change in voice, its mean the internal speaker is damaged. Replace it. And about your voice is not loud from other side then replace that microphone also. I think that's a common problem of Nokia N73 mobiles.
Thanks
Jan 24, 2010 | Nokia N73 Music Edition Smartphone
HOW DO I TURN DOWN LOUD SPEAKER VOLUME?
There are 2 possibilities. One is the speaker volume, adjusted with the up (top and bottom) and down of the gray circular key while you're on speakerphone, and the other is the background music is turned on by pressing the "1" key while the phone is idle. One or the other ought to fix it.
Carl
Nov 17, 2009 | Panasonic KX-T7730 Corded Phone
go to control panel
voice
or
Oct 03, 2009 | Bose Companion II Computer Speakers
Bluetooth volume too low Go730
You are out of luck...I have the same unit and it wont even connect with my LG Voyager! the volume doesn't want to cooperate with anything I think it should do. I actually went with a wired headset to answer call once it did connect and forgot about the whole speaker thing.
Aug 27, 2009 | Tomtom GO 730T Car GPS Receiver
Env2 vx9100 call volume soft
We have 3 ENV2's in our family. None of them have volume problem. The speaker phone is especially loud when used in indoor environment. It is so loud that I have to turn the volume way down when used with good quality ear set. You probably are right about the phone being defective.
Aug 23, 2009 | Verizon Communications enV2 Cellular Phone
Pearl 8100 cannot hear voice.
I think the internal speaker is damaged. You can use speaker and turn the volume down but if the phone isn't under warranty I don't think you can easily fix it.
Dec 09, 2008 | RIM BlackBerry Pearl 8100
Sherwood rx4105
you may be using an equalizer? try to pop-up the volume with all tone controls in flat mode. see if it still cuts off. if this is the first time youencounter this then something must be wroing with either your speakers or your amp. unless your ventilation is not good enoughg, you can also try placing a blower on top of your unit to cool it down
May 04, 2008 | Sherwood RX-4105 Receiver
48 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
