Question about Brother Office Equipment & Supplies
HL-3170. How can I reset the page counter to clear the REPLACE PF KIT1?
I have done the go button and + parts life and gotten to the page count but it doesn't reset it just give you the amount
Posted by Jill Abbott on
5 Related Answers
Anonymous
SOURCE: Brother HL-5270DN PF Kit Problem
I found the answer in another group, from Sunshine3240:
Open the front cover and leave open while completing the following steps:
Turn the printer off.
Hold the 'go' button while turning the printer on. All panel lights should be on.
Release the 'go' button.
Press the 'go' button 2 times.
Pause.
Press the 'go' button 5 times.
The toner light should be off.
The paper light should be on.
Close cover. The ready light should be the only light on.
Posted on Mar 13, 2009
Anonymous
  • 121 Answers
SOURCE: Brother HL 1250 Laser. Drum & page counter
Reset the drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
  4. close front cover
Posted on Mar 23, 2009
Anonymous
  • 4 Answers
SOURCE: Dell 1720 flashinf replace drum- error.
I believe this message is occur because the laser printer drum needs to be replaced, not the toner cartridge.
These are two different things. The part is a DELL 310-8710 Drum Unit. Just google DELL 1720N drum and you should be able to find one.
Posted on May 29, 2009
n25an
Norman Davis
  • 622 Answers
SOURCE: brother mfc-8460 service manual
link to it here...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 27, 2009
Anonymous
  • 26 Answers
SOURCE: REPLACE PF KIT1
THIS IS HOW YOU WILL RESOLVE YOUR ISSUE OF REPLACE PF KIT1 ON UR Brother MFC-8460N All-In-One Printer
1) Turn off printer
2) Press and hold menu button and turn on. Keep holding button until you see maintenance on display.
3) Press 88. This brings up parts replacement menu.
4) Press Up arrow until you see the part you replaced (laser, fuser, pf kit1, pf kit mp).
5) Press the OK button.
6) Power off and restart printer
THIS WILL DEFINATELY RESOLVE THE ISSUE
REPLACE PF KIT1 : THIS IS IN REGARDS TO THE MAINTENACE DISPLAY THAT YOU HAVE ON YOUR PRINTER
TAKE CARE AND HAVE A NICE DAY..
Posted on Jun 22, 2010
RESETING BROTHER 8910 PF KIT
See Step 15 in online instructions at the link below:
http://www.shareyourrepair.com/2015/08/how-to-fix-brother-mfc-8950-replace-parts-pf-kit-1-error.html
Step 15: Reset the PF Kit 1 Counter This will clear the "Replace Parts PF Kit 1" error that keeps coming up.
Step 15a: From the main menu simultaneously press both the 3 and 9 keys once.
You must access the secret reset menu to do this. If you don't time it correctly you will set the number of copies. If you do that just press the Stop/Exit button and try again. You DO NOT hold the keys down, just simultaneously press them once:
Simultaneously press the 3 and 9 buttonsIf you do it correctly, you will see the reset menu on the display:
The Secret Reset Menu
Step 15b: Tap "PF Kit1" on the screen.
Tap PF Kit1It will double check and ask you if you want to "Reset PF Kit1?" Tap "Yes."
Tap YesIt should then say "Accepted" to let you know that the counter has been reset:
After tapping yes it will say "Accepted"To get out of the Reset Menu press the Stop/Exit button:
Press the Stop/Exit button to get out of the Reset Menu
OK, we've got a second-hand brother 6050dn for our computer lab of about 35 computers. I've recently replaced the PF KIT For the MP drawer, but had trouble resetting it. Finally figured it out...
Replace the parts! If it is used you have no idea of how old the parts in it are even if they look good. The counters that turn these messages count sheets of paper not time and the parts may have moisture damage from sitting up.
1helpful
I need to replace "PF
Ah the Paper Feed Kit 1 on this unit is pretty easy,
If you remove the paper tray and put the printer on it's back you should see the rollers you're going to replace.. unfortunately the service manual doesn't show this procedure so I can't provide a picture.
If memory serves correctly there should be a long light-blue plastic piece that holds the PF Kit roller assembly in place. If you bend this towards the back of the machine the PF Kit should swing down and you just slide it out, replacement is the reverse of this.
Once you're done you'll have to reset the PF Kit counter by:
Press GO and + together,
you should see RESET PARTS LIFE on the LCD
You can then use the + / - to pick the PF Kit and press the SET key to reset the counter.
If you still have problems let me know via this question and I'll try to help further.
How can I replaced the PF KIT2 on my MFC9420CN?
2.3 Parts Life Reset Function
This function is provided for service personnel in order to reset the counter of each periodical replacement part and count the number of replacement times when replacing the periodical replacement parts.
(1) Press the 3 and 9 buttons at the same time in the ready
status. (sometimes can be 2 or 8 or 1 or 7)
(2) The "Reset Menu" will appear on the LCD. Select the
applicable periodical replacement part by pressing the up arrow or down arrow button and press the OK button.
- Drum - Belt Unit - PF KitMP - PF Kit1
- PF Kit2 - Fuser - Laser
(3) When the OK button is pressed the "1. Reset 2. Exit"
appears on the LCD. Press the 1 button if resetting the
counter. If not, press the 2 button.
(4) Pressing the 1 button accepts that the machine implements
the counter reset.
(5) If the 2 button is pressed the machine goes back to the
select part counter again. If you need to Exit press the
Stop/Exit button at any time.
(6) The machine returns to the ready status.
Note:
- All periodical replacement parts are always indicated on the LCD even though their lives do not reach 0 %.
- The PF kit2 is always indicated even though Tray 2 is not installed, or it is not supported for the model to be used.
- The machine returns to the ready state automatically if no panel operation is implemented for 60 seconds.
MFC9420CN brother printer says Check tray #1 Reinstall tray
I had this same problem. The solution was resetting it, and the instructions below worked for me:
status.
the counter reset.
22helpful
REPLACE PF KIT1
1) Turn off printer
26helpful
How do you reset the fuser counter on the 9440CN from Brother
status.
(2) The “Reset Menu” will appear on the LCD. Select the
< Periodical replacement parts are indicated on the LCD >
(3) When the OK button is pressed the “1. Reset 2. Exit”
the counter reset.
2helpful
2answers
47helpful
6answers
Resetting "Replace PF Kit 1" message
Same with me on my MFC 8870DW. The procedure worked perfectly:
1) Turn off printer
6) Power off and restart printer.
But how do I know whether or not I really NEED to replace a PF Kit1? I guess I'll find out if it recurs soon.
Joe
Ekse
k24674
