Question about Sander Tools & Hardware - Others
Kobalt 6" air Sander pad replacement Model SGY-AIR105. How do I replace the pad.
Posted by John P Davis on
5 Related Answers
Anonymous
  • 55 Answers
SOURCE: 7336 orbital sander
If you are talking about the actual sanding pad itself it should just pull of .If you are talking about the backing pad it should un screw
Posted on Dec 04, 2008
rowdy45176
David Ford
  • 2176 Answers
SOURCE: replace sanding pad on random orbital sander dw443
You will find usually 3 torx drive screws on the bottom of the tool, remove them and the pad comes off. The replacement pad number is 151416-01 list 27.49. Let me know if I can help further
Posted on Feb 23, 2009
Anonymous
  • 89 Answers
SOURCE: kobalt air compressor problem plastic tube gets a hole
EVERYONE WANTS TO MAKE EVERYTHING PLASTIC THESE DAYS. REMOVE PLASTIC LINE AND REPLACE WITH 1/4" FLEXIBLE COPPER ( ANY KIND ) JUST PICKUP A SMALL ROLL AT A HARDWARE STORE. MAKE SURE YOU GET A COUPLE OF FITTINGS, NUTS AND/OR FERRELS. HOPE THIS HELPS, JODY
Posted on Apr 20, 2009
Anonymous
  • 104 Answers
SOURCE: replace velcro pad on rupes random orbital sander
I have replaced velcro on various sanders , you just take the original velcro off and make sure that the base is very very clean, use turps and metho to clean it with then buy some velcro from a good hardware supplier and really good glue [two pack epoxy is best ] and simply cut to size and then just glue new velcro onto the base of the orbital sander
Posted on May 23, 2009
Anonymous
SOURCE: Where can I get replacement disc pads for a
I have purchased similar replacement discs from Kingspor's Woodworking Shop. Contact www.woodworkingshop.com
Item KD60120 for 120 grit
Item KD 60100 for 100 grit
Item KD 80100 for 80 grit
Posted on Feb 14, 2010
Kobalt gravity spray gun and I have a little air that comes out constantly. Why is that and how do I stop it? Thanks
You must be using a "turbin" which is different and better than a compressor however a turbin runs all the time and air must escape from it unlike a compressor with an airtank the shuts off after the desired pressure is reached it shuts it self off then turns back on with tank pressure drops below what you have set it at- a turbin reaches the pressure you set the regulater at and maintains it constantly NEVER STOP THE AIR FROM PASSING THRU IT in fact a lot of times i do this to remove any dust i may have missed so evrything is working like it should on yr sprayrig..
perry tradesman
Oct 19, 2014 | Kobalt Large Gravity Feed HVLP Spray Gun...
I need an owners manual for a kobalt 6 in orbital palm sander. Where can I find or download one?
depends whats wrong with it.they r basically all the same inside.,motor,armature,tiny brushes,two small roller brgs,eccentric drive to vibrate the pad,on/off switch
Aug 22, 2014 | Tools & Hardware - Others
Kobalt 350 impact runs without trigger pressed
Sounds like a problem with the throttle valve.
you will have to remove the air inlet (item# E) then pull the spring out (item# 37) and look to see if you find any foreign objects, if not the proceed to pull the throttle valve (pin cover) (item# 37) and check the seal (item# 34) for wear.
Follow this link for the parts manual:
http://pdf.lowes.com/useandcareguides/879686002796_use.pdf
Dec 31, 2013 | Kobalt 350 ft-lbs Air Impact Wrench...
Craftsman dual action sander model#875.199770. how do you remove sanding pad to replace with new one?
I used a thin vise grip to hold the spindle and the old rubber pad was easily removed.
Apr 17, 2013 | Craftsman Dual Action Sander
How do i change the sanding pad Ingersoll Rand Ingersollrand Dual Action Air Sander - 6
It simply unscrews. The pad is held on by a small bolt length attached to the pad. Unscrew it.
Jan 15, 2012 | Ingersoll Rand Ingersollrand Dual Action...
Orbital sander doesnt orbit!
Never start the Sander without first placing it against the surface to be sanded. In free air the Sander will not osolate.
Jun 12, 2009 | Makita BO5010 5" Random Orbit Sander
Need to convert pad to hook & loop sys. Is product made to fit this sander pad ?
Thought about what my orbital sander is like, then went to a craft store and bought a large sheet/pad of velcro and cut it to fit the 6" rubber disc pad glued it to the pad and then bought hook and loop sanding discs. And you wondering why I didn't use my orbital sander?? Because I needed to get into tight spaces and the orbital sander is a bit too large for this, plus it's too heavy to use working overhead .
Thanks for your site and for asking if problem still exists. Appreciate it.
"Necessity is the mother of invention" Truer words were never spoken
Els439
May 29, 2009 | Black & Decker Tools & Hardware - Others
How do i use this thing
Yes it should screw on and the sanding pads should either be sticky or velcro
Oct 02, 2008 | Ingersoll Rand Ingersollrand Dual Action...
Tools & Hardware - Others Logo
197 people viewed this question
Top Sander Tools & Hardware - Others Experts
gbob59
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sander Tool and Hardware - Other Expert? Answer questions, earn points and help others
