Question about Health & Beauty
Heiniger ahndy new clippers and blades flew off . cant seem to get blades fitting again
Posted by anne kelly on
5 Related Answers
Anonymous
SOURCE: oster clippers
Found another web site where some one had posted the information I needed. I just used Google search and found the information.
Posted on Jul 15, 2008
Anonymous
  • 304 Answers
SOURCE: barber clipper blades
Soak them in motor oil the use 400 grit wet sandpaper (The black kind available at the hardware store) and lightly sand off the rust. They will be good as new when you are done.
George
Posted on Jul 25, 2008
rggp
  • 22 Answers
SOURCE: have pro clippers do not have instructions for changing blades
Schematics are located at this link. Hope this helps.
http://www.clipperrepair.com/parts.htm?brand=8
Posted on Feb 02, 2009
Anonymous
  • 276 Answers
SOURCE: Replacement blades?
I'm not at work so can't confirm if there's blacdes for the HC920 but the majority of Remington Hair Clippers do have replacement blades.
Go to http://www.remington-products.com/country/index.htm to slect your country.
Authorised Remington Service Centers can be found at http://www.remington-products.com/consumer/asd.htm
Posted on Apr 11, 2009
Anonymous
  • 76 Answers
SOURCE: how do you change blades on Wahl's clippers?
No problem look at your clipper blade, you will see 3 screws remove the screw in the middle ONLY, The clipper blade will come off, replace with new blade put back the middle screw on and tighten.
Posted on Mar 30, 2010
So I have andis agc super 2 speed brand new. I have literally shaved half my dog clippers now seem too dull or cant cut hair. IThis cannot be normal to hVe this much trouble with brand new clipper
First, I'm not a Andis Tech.
* Check your warranty and call for service.
*** Following is for information only ***
* Normally I would suggest cleaning and tightening the 2 blade holder screws as in a normal "Human" hair clipper. But I noticed this pet clipper uses a snap on blade (or a combo blade as shone in "Blade Maint" video. Looks like it's mostly cleaning though I have seen other vids with clippers going dull during pet "rescues" having to trim matted hair. One lady used 2 blades and ending up using a 3d blade. It could be just that; really thick dirty hair. Dirt and grime is a collection of stone dust and oils after all.
* Demo; https://www.youtube.com/watch?v=Aun5QDCtGgc
* Blade Maint; https://www.youtube.com/watch?v=v-rS_YQ-ro0
* Basic Repair; https://www.youtube.com/watch?v=CRGEQHhfCIc
* Repair (detailed); https://www.youtube.com/watch?v=pbDLhMugSgg
Aloha, ukeboy57
Jul 06, 2018 | Andis Health & Beauty
How to change heiniger clipper blade support
No adjustment needed but you must make sure the spring ends from the hinge are pushed into the two holes either side on the latch. If your still having trouble give us a call.
http://www.angliaclipperservices.com/dog
Jun 03, 2016 | Heiniger Saphir Cordless Dog Clipper
Oster blade no. 913-50
http://www.ebay.com/itm/Oster-Blade-Set-913-50-Fits-Fast-Feed-17-tooth-76913-506-New-/130803957423
Mar 09, 2014 | Oster Corporation Pet Oster Performance...
Heiniger clippers won't clip
It's likely the tension nut or screw needs to be tightened a little more providing the drive block is in place and the blades have been put on correctly.
You shouldn't need to buy new blades even when they go blunt just send them to a professional sharpener
May 05, 2012 | Health & Beauty
Oster Blade 918-306 Size Texturing Fits Oster Classic 76 Clipper, Power Pro, Power-teq And Star-te: Oster class 76 clippers....had them for a week and...
70ca16d.jpg Hope this helps, this is a tongue guide, you hopefully recognise it on your blade. If they are not paralell, then adjust them with pliers, both need to be perfectly vertical. When you put it on the clippers push the latch in as you close the hinge.
If it still wobbles then the next fe wthings need checking
1. The hinge screws on the clipper are tight, located either side of the hinge on the clipper.
2. The drive lever may be worn, thats the maroon peice of plastic sticking up at the top of the clippers, it moves from side to side when clippers are running.
3. If all seems fine up to now, your clipper should be fixed under warranty as it will involve changing parts covered by the warranty.
www.sheareaseltd.com
May 17, 2010 | Sunbeam Oster Blade 918-306 Size Texturing...
Blades fell off oster dog clippers but can't fit them back on. Please help !!
With the hinge of the clipper facing you:
Make sure hinge is open, if it is not, prize it open with a flat head screwdriver.
Slide the blade on with the blade siz/number faceing you.
Snap shut.
If this fails, try again, but push the latch in as you snap them shut.
If this fails, you may need repair!
May 15, 2010 | Oster Golden A5 2-Speed Universal Motor...
My Golden A5 clippers won't shave a knowlegable dog groomer friend of mine said the blade seems sprung from the housing it doesn't fit snug against the body of the clipper is there an adjustment I can...
it seem the hinge on your clipper is worn out, here how you can check it, place blade on with the clipper off tap the blade forward if the blade pop,s open the hinge is worn out, you need to replace it, Now on the cutting part of the blade when was the last time you had your blade sharpen. if it been a while or you can not remember it's time to have it sharpen by a professional.
Apr 13, 2010 | Oster Golden A5 1-Speed Universal Motor...
I have andis AGC 2 dog clippers. I have having trouble taking off/removing the blade that came with the clippers. The under portion of the blade assembly seems to be stuck. Also, since I'm having so...
Ok you need to locate the Latch which holds the blades into place. There should be a black piece of metal at the rear end of the clipper blade whilst on the clippers, simply push this in towards the blade and at the same time pull the front edge of the blade away from the clipper to release this should simply pull off in a forward direction.
Fitting is easier slide a blade onto the tongue of the Hinge Assembly and pull it into the body of the clipper.
Mar 18, 2010 | Andis AGC2 Hair Trimmer
Wahl 8550 Pet Clippers Won't Work
Tried the above solutions but it all keeps falling apart. It's a wahl pro series rechargeable. There are two screws, large blade, small blade, white plastic part and a silver bracket that seems to slide on the white plastic part. What goes in first? How do I assemble it? How do blades match? Do the grooves on large blade fit into small blade? Help, I can't reassemble it. Thanks in advance! Pam
May 06, 2009 | Wahl 8550
Health & Beauty Logo
139 people viewed this question
Top Health & Beauty Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Health and Beauty Expert? Answer questions, earn points and help others
