Question about Hannspree 19" Widescreen LCD Flat Panel Monitor
Full hd capable, but only functioning in 480. how do i set my monitor to 1080?
Posted by nedsg23 on
Anonymous
  • 119 Answers
On the wallpaper of your pc left click your mouse and a dialog box will appear select and click properties on the settings tab you can see a screen resolution below it there is a scroll bar slide it to your desired resolution
Posted on Sep 18, 2009
Anonymous
    Scholar:
  • 89 Answers
I would have to know what type of connection you are using. usually in most hd monitors, the vga plug will only show up to 480i/p and some will show 1080i. DVI will only show 480i/720p/1080i and if it has an HDMI you can get 480i/480p/720i/720p/1080i/1080p. you will also have to set you resolution of your video card to match.
  • Anonymous Sep 18, 2009
    so what type of connection are you using or what cable?
I have a HX32N2176h Hisense 32" LED tv will this TV handle and display HD when connected to a Laptop or Android Box with HDMI Cable?
The Hisense HX32N2176H will display an HD signal of 1366x720 with the HDMI input. (Any resolution above 480 (lines of pixels) is considered HD.) However, this isn't a full-HD (1080) capable TV. See https://www.hificorp.co.za/hisense-32in-81cm-hdr-led-tv-hx32n2176 for the specifications. Click on the Technical Details tab.
I hope this helps.
Apr 25, 2018 | Hisense Televison & Video
How do i get my vizio in full hd
Consult the owner manual to make sure the input it is connected to is 1080 and you are on that input-------HDMI? Component? 1080 Component?
Apr 16, 2012 | Televison & Video
How do I change my Olevia 47" from 480 to 1080
The Program you watching sets the res. If you watch a HD 1080 Program it will switch by its self. Most programs are 480 still and you can't watch 480 in 1080 format.
Oct 08, 2010 | Olevia LT42HVi 42 in. LCD Television
It say 480 stretch on the screen how do I turn it to 1080 for my Hd tv
Make it sure that you have a 1080 signal from your source(eg. HD receiver, bluray player etc.). Try pressing format button on the remote until you get full picture . Or try changing the format or aspect ration in your satellite or cable box.
Dec 29, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Just fixed the convergence chip problem.$534.00. Now 720p and 1080 1 signals are showing double images and colors. Also the componentinput #2 is showing double images on any format
many of these sets need the convergence adjusted in the 480 and the 1080 separate-- the set most likely if looks good in 480 needs to be adjusted with the original remote in the 1080 mode.
Whoever charged you 534 got you---if you did it yourself you paid way too much--with 1080 signal--enter convergence mode and try to adjust in customer menu--if 480 is ok---it needs to be adjusted in the hd mode.
SD TECH
Oct 31, 2009 | Pioneer SD-643HD5 64" Rear Projection...
1080 won't come in when in HD, but will at 480
Flutter is a result of sync issue probably. Check these:
1. If 1080P, try 1080i and see if this works
2. what is the length of the HDMI cable...>3 meters may cause this
3. try 720P, how is this?
4. If component, try various resolutions and see if it is specific to 1080P, if so check this further
5. try other Blu-ray disk or another source, maybe the source player or disk is the only problem.
Apr 29, 2009 | Sony KDF-E42A10 42 in. LCD Television
32" sanyo model ds32224
picture 330 lines
video input 700 lines
16.9 full HD has 1080 resolution and this is for a ds 32224
Jan 28, 2009 | Sanyo DS32224 TV
Just got the proscan 42LA45H lcd/tv from sears set it up with the 5 cables for the dvd to work for 1080p but the tv is still at 480 what can i do ?
is your dvd player is a blue ray or hd dvd ? if it is you need to go into the setup menu of the dvd and set it for 1080. if it's just an older dvd player it will be at 480
Jan 21, 2009 | Proscan 42LA45H 42 in. LCD TV
Change from 480 pixles to 1080 how do you do it ????
Do you have the HDMI out in your Xbox??
The input is auto switching for the resolution.
Oct 09, 2008 | Hitachi P50H401 50 in. Plasma HDTV
1080 VS 480
Trash can it and buy a new T.V.
Jan 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Hannspree 19" Widescreen LCD Flat Panel Monitor Logo
Top Hannspree Computers & Internet Experts
Tom Chichester
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
