Question about GE Washing Machines
GE model number gtw330ask0www no matter what setting I put it on heavy light delicates casual speed wash it doesn't matter when I push the start pause button the fill light comes on but then doesn't do nothing I took the panel off the back and I'm looking at the circuit board route for the fuel light is there's a on the green silicone board now z201little green light flashing what does that mean what's wrong with it how can I fix this
5 Suggested Answers
Anonymous
SOURCE: microwave wont come on at all.
replace the fuse. You have to remove the top grill and then you will find it above the display
Posted on Dec 29, 2007
Anonymous
  • 149 Answers
SOURCE: Toshiba TV model CZ27V51 - picture+audio off, red light flashing
hi there, Flashing light red means a shorted electronic component is need to be replaced. do some test at video section, most of it are diode, transistors, transformers. ty
Posted on Jan 27, 2008
David Coomer
  • 1073 Answers
SOURCE: Whirlpool Duet washer control lock
hold in the signal button for 4 seconds and it will unlock the control
Posted on May 06, 2008
Anonymous
SOURCE: kenmore 80 series modej # 110 20842 990
Problem solved with a new washer
thanks
Posted on Dec 16, 2008
Anonymous
  • 31 Answers
SOURCE: Kenmore Elite H3 control buttons - some work some don't
The diagnostic function will not help you if your user interface board (UIB) is acting up because to put into diagnostic you have to select drain spin, then the no spin option, and hit the prewash button 4 times.
It sounds like your UIB is the problem.
Posted on Feb 12, 2009
GE GFWN1100LWW. Can the high speed spin work on the lower wash cycles?
From my experience, the lower wash cycles are set to only do certain things. For example: the Delicate won't do a high speed spin, even though a high speed spin wouldn't really be destructive to delicates, but would force more water out of them! I usually just run a "Drain/Spin" after the Delicate cycle.
Nov 27, 2015 | GE Washing Machines
HE3 doesn't respond to any button. Time light keeps flashing time. Pause cancel button does nothing, Cycle doesn't start. The only thing that will change is if you push a different mode ie, heavy,...
Unplug the machine for at least half an hour to eliminate the possibility of an electronic glitch. Then upon plugging in back, close the door then push CONTROL/ON (if present on this model). Select the DRAIN/SPIN cycle then select NO SPIN by pressing the SPIN SPEED button. Push PREWASH OPTION four times within five seconds. If PREWASH OPTION is not present on this model, press EXTRA RINSE four times within five seconds. C:00 will light up on the display. If the Starting procedure fails, push the PAUSE/CANCEL button then repeat the starting procedure.
In order to advance to the next step of the test procedure, push PREWASH OPTION button two times. If PREWASH OPTION is not present on this model, press EXTRA RINSE two times. The test program goes from C:00 to C:08 and should flash an error code when a problem is present. Post the code back for further troubleshooting, including the exact model number of the machine.
Sep 20, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a GE Washing/dryer Stackable machine combo. The speed maintain normal speed even with the Delicate Clothes option. How to trouble shoot? There is a Siebe Control that is connected to the timer Knob...
The speed change voltages are selected by the timer contacts. Try rotating your timer clockwise rapidly through several revolutions then select a delicate spin cycle and see if the speed is still too fast. If it is then the most likely suspect is the timer itself.
http://www.appliancepartspros.com/part_details.aspx?part_id=2045983
Model number used: WSM2780WAWWW
The timers are the same.
Thanks for using FixYa.
Kelly
Mar 18, 2010 | GE WSM2780W Stacked Washer / Dryer
Whirlpool GGW9250PW Automatic Cycle not working
We are sorry to hear of the problem with your Whirlpool dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at [email protected] with your name, phone number, address and the model and serial number for your refrigerator.
Apr 04, 2017 | Whirlpool GGW9250PL Gas Dryer
Whirlpool front load washer won't spin - just sometimes
Most Whirlpool (Hotpoint) machines have "out of balance" sensors that detect very large movements of the drum suspension usually due to a very badly balanced washing load.
This can occur for various reasons but putting large and/or heavy items in can trigger these sensors i,f as the machine starts to spin, the items dont get distributed evenly around the drum. This is more likley with large/heavy items.
The machine will then restrict the spin speed for the remainder of the wash cycle, and once the machine is switched off, the next time the machine is used it returns the spin speed back to normal - but if it detects an out of balance situation, it will again restrict the spin speed.
It sounds to me the machine is acting as designed. You could try positioning the items differently as you load them, and hope they dont end up "all over one side".
Oct 06, 2017 | Whirlpool CAM2752KQ Top Load Washer
GE 5500 washing machine TERMS
These are the agitator and spin speeds.
Mar 11, 2009 | GE WBSR3140DW Top Load Washer
Jan 01, 2009 | Kenmore 42822 Front Load Washer
Washing Machines Logo
79 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
