Question about Stihl Saws
How to remove a carburator from a ts350 stihl concrete saw
Richard Ranney
    New Friend:
  • 25 Answers
Handles have to be removed first
Posted on Nov 20, 2019
5 Related Answers
Anonymous
SOURCE: repair manual for Stihl TS
my decompression valve camp lose how can i get to put back in
Posted on Jun 10, 2011
Andrew White
  • 2239 Answers
SOURCE: husqvarna partner 750 concrete saw wont start
You need to make sure it is mechanically sound, has the piston picked up on the exhaust side? does it have enough compression? is there signe of concrete dust on the inside of the air filter and filter houseing?there are many after market carb gasket sets, some have a small hole missing from the diaphram and gasket on the metering side, this activates the compensator, this needs to be there as the metering cover has no breather hole in it.
Posted on Mar 14, 2012
H2_Brad
Brad
  • 425 Answers
SOURCE: stihl madel ts420 how to change air filter
There are 4 torx screws on the black back cover. Here is the owners manual. It is explained on page 33.
Stihl TS420 owners manual
Posted on Aug 25, 2012
Andrew White
  • 2239 Answers
SOURCE: How do I gap ignition module on a TS350 Stihl concrete saw?
I thought the unit was under the flywheel, in this case there is no gap to set it just screws to the crankcase and you re fit the flywheel.
Posted on Sep 21, 2012
Bill Boyd
  • 53816 Answers
SOURCE: I need to replace the piston in my MS 441 Stihl chain saw.How do I remove the carburator
go google and type in ---workshop manual for stihl chainsaw model ms441--
download the pdf version
Posted on Nov 06, 2016
Original parts diagram for stihl ts400
I found a parts diagram for a Stihl TS400 CutQuick concrete saw here: http://www.sawagain.com/stihl-concrete-saws-1/ . The direct link to the parts diagram is http://www.hellumdiamant.com/filarkiv/File/Sthil/ts400.pdf . I found some of the parts shown in the user manual as well. The manual is available here: https://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/TS400_Manual.pdf . See page 44 for that parts diagram.
I hope this helps.
Jul 18, 2017 | Stihl Saws
How to adjust oil pump 08s concret stihl saw
There is no oil pump on a concrete saw, only on the chainsaw.
Feb 17, 2014 | Stihl Garden
I have a dewalt d28710 metal chop saw which blows the 13 amp fuse in the plug when I press the trigger to start cutting , anybody else had this problem ?
Download Link:
This service manual contains detailed descriptions of all the repair and servicing procedures specific to this power tool series.
1.stihl ts350 parts manual
There are separate handbooks for servicing procedures for standardized parts and assemblies that are installed in several STIHL power tool models. Reference is made to these handbooks in the appropriate chapters in this manual. As the design concept of models FS 120 FS 200 FS 300 FS 350 FS 400 FS 450 and FR 350, FR 450 is almost identical, the descriptions and servicing procedures in this manual generally apply to all models.
2.stihl ts350 parts service manual
Dec 03, 2013 | Saws
Sep 18, 2012 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
Need repair manual for stihl ts350 super
Download Link:
Jul 05, 2012 | Saws
What gas to use for TS350
Gasoline cut-off saws are a simple and extremely robust tool that will easily last for many years if treated with respect and maintained regularly .
During normal operation it is absolutely imperative that the correct fuel/oil mix is always used. An incorrect mixture leading to a lack of lubrication is by far the easiest way to ensure an untimely death for your cut-off saw.
Here's a list of regular cut-off saw maintenance tips that will keep your machine running and running:
Jul 20, 2011 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
Why won't my Stihl TS350 Cutoff saw go to full revs? It starts well.
I would inspect the intake side of the piston behind the carburetor. The most common problem with cutoff saws with no water kit is fuel reversion. that is wear on the intake side of the piston that has removed over 10% of the machining marks like this:
If you do have wear like this consult a Stihl Gold certified dealer like www.arcolawn.com for parts and tools to repair it.
Good Luck
Dec 11, 2010 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
How to remove stihl ts350 clutch
how to replace a TS350 stihl saw clutch
Oct 14, 2009 | Saws
Saws Logo
136 people viewed this question
Top Stihl Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Stihl Saw Expert? Answer questions, earn points and help others
