Question about Bose Audio Players & Recorders
Bose Wave music system CD changer repair
I am lookig for a mechanical ger for a a Bose Music wave system
Anonymous
SOURCE:
Anonymous
  • 23 Answers
SOURCE: bose wave muoti cd changer
I have had a few of these come to my shop. The gears jump out of timing causing the cd lift to jam or become unalligned. The unit will have to be disassembled to get the CD out and the unit itself will need to be serviced (rebuild and retime cd changing mechanism)
Posted on Mar 18, 2009
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: can the new 5 cd changer work with the older Bose
It will work as a manually-operated AUX input, but since there was no remote for the original system so that function won't be available.
Posted on Nov 30, 2009
Anonymous
SOURCE: I have a Bose Wave Music System with add-on 4 cd
I had a similar problem. No discs would play and sometimes they would not eject. I solved my problem with the crevice tool on my vacuum cleaner. I vacuumed out all the openings on the unit, especially the cd slots. This discs now play and eject.
Posted on Feb 14, 2010
woodzowl307
  • 667 Answers
SOURCE: have a Bose wave Music Sys model AWRCC2 with stuck
Yes I think you can, get out your tools and take apart the unit, what do you have to loose you can always take it to a pro if you can't get it out. Be careful to unplug the unit. Don't force anything when you take it apart, be careful not to break any parts, put all pieces back together as you took them apart. Should be very straight forward if you are careful at what you do, get a bowl to put small parts in. Good Luck.....
Posted on Apr 09, 2010
John Cunningham
  • 6771 Answers
SOURCE: CD not playing with bose wave system but same cd
The cd assembly is the issue, over a period of time the laser pickup becomes weaker until it can no longer read the disc, one possible solution is to buy a disc cleaning kit and follow instructions in an effort to recover the assembly. If that fails the only option is contact Bose for pricing since they are the only authorized service centre that work on their own products.
Posted on Sep 15, 2011
Wave Music system Multi-CD Changer
The unit has a power supply problem, no user servicable parts inside. Bose uses a thermal fuse built into the power transformer. Take unit apart and check for connection issues first, then look for a possible fuse, if none exist chances are it is in the power transformer, contact Bose for service.
Sep 02, 2012 | Bose Wave music system Multi-CD Changer...
HAVE A bOSE wAVE MUSIC multi changer disc will not play
The laser pickup unit [Optical Pickup Unit] is faulty. Bose uses a special type. You can't get it from open electronic spare part market. It is best to get this set repaired by the authorised service center for bose at your town.
Apr 20, 2012 | Bose Wave music system Multi-CD Changer...
My bose wave multi cd player will not play discs, error code comes up. Only 1 year old.
hi,
may be some mechanical problem or laser pick up unit have some problem. is better u should replace the same, for maintaining the audio quality.
ok
Dec 17, 2010 | Bose Wave music system Multi-CD Changer...
Can the new 5 cd changer work with the older Bose
Nov 29, 2009 | Bose Wave Music System CD Shelf System
Bose wave muoti cd changer
Nov 25, 2007 | Bose Wave music system Multi-CD Changer...
Playing CDs
An old post but did you get an answer and do you need a copy of the manual?
donald
Jun 29, 2007 | Bose Wave music system Multi-CD Changer...
65 people viewed this question
Top Bose Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
