For psr-640 disquet programing to host connection driver
Posted by Gilles Laplante on
My yamaha psre323 does not connect
I have a PSR-E323 and to connect it with my pc using a MIDI connector should i install driver from http://download.yamaha.com/usb_midi/ ??? I tried to install that.. An error msg popped up... error 25001 no device is connected. connect a device and try again. If the "found new hardware" wizard appears push the cancel button...What should I do?? Help me pls...
Apr 10, 2012 | Yamaha PSR-E323 Keyboard
How to connect psr-3000 to computer
You can connect it with USB connection to your computer. It should be plug and play, but some drivers might be required.
You can connect it also via MIDI interface: - you will need sound-card with MIDI input connector, or you can use special MIDI device like M-Audio UNO.
Mar 07, 2011 | Yamaha Full-Size Keyboard
Yamaha psr 640 model, recently change new rubber but,problem came again
check the circuit board below the rubbers for dry joints or corrosion. check the MKS board.
Feb 17, 2011 | Yamaha Portable Keyboard
I have a Yamaha PSR E423 keyboard with USB connectivity. When I connect it to the computer it will not detect it, (I have tried three different computers and several different USB cables). I cannot install...
Your manual is here, but you are right, you put the disc in the drive, and then plug the kb into the computer with the power off, then when you turn power on, it SHOULD start the found new hardware wizard. If it isnt, the midi/usb connection may be faulty
http://www2.yamaha.co.jp/manual/pdf/emi/english/port/psre423_en_om_c0.pdf
Sep 05, 2010 | Computers & Internet
Is the ds6707 compatable with windows 7?
If connected with a CBA-U01-S07ZAR and programmed as the default HID keyboard USB host type, yes it should be compatible. The device uses the same drivers the host uses for a USB keyboard.
Jun 22, 2010 | Zebra DS6707 Bar Code Reader Barcode...
Problem connecting PSR I425 to computer.
how to psr i425 recording data tranfar to computer ...plz reply
May 27, 2010 | 2003 Yamaha YZ 125
Please teach me how to do a recording of bits with the keyboard PSR S710, it uses a USB drive, but i don't know how to use it
You need to have a basic recording program installed on your computer. If you use Apple you can use garageband. If you use Windows you can install audacity http://sourceforge.net/projects/audacity/
You will have to install the drivers of our yamaha keyboard than connect it with the usb cable to your computer and select the PSR S710 as an input in your recording program.
Mar 10, 2010 | Yamaha Music
USB connection problem using Windows 98 Second Edition.
The cause of this problem can be traced to both the computer's hardware configuration and Windows 98SE (Second Edition). PhotoMAX cameras and other devices featuring USB (Universal Serial Bus) connections may not work with computers running Windows 98 Second Edition and equipped with the following computer hardware: * an AMD processor (350 MHz or higher) * VIA Technologies USB Host Controller or SiS 7001 USB Host Controller To find out what USB Host Controller is on your system: 1. Click Start > Settings and choose Control Panel. 2. Double click the System icon. 3. Choose the Device Manager tab. A window similar to the one shown below appears. 4. Expand the Universal Serial Bus controllers listing by clicking on the "+" sign next to the listing. 5. Note the type of host controller in the listing. The example above shows the SiS 7001 PCI to USB Open Host Controller.
Sep 14, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
Computers & Internet Logo
32 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
