Question about Hardware & Accessories
Can I buy just the dial foryour basic indoor timer?-Jack 4805021190
Posted by Jack Ratterree on
Orbit timer 57899 no AC
Transformer is probably burned out. If it is a indoor timer buy a new 24V transformer. If it is a outdoor timer buy a new one.
Apr 28, 2013 | Orbit 9 Station Super Dial Irrigation...
How do i program the above timer?
Here are the instructions:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t101%20-%20english.ashx
Basically, pull the yellow dial out, rotate the yellow dial until the pointer indicates the current time, then push the dial back in. Set the ON/OFF trippers as desired.
Feb 06, 2011 | Intermatic T101 - 24 Hr. Dial Time Switch...
POOL TIMER T104P3 DIAL DOESN'T MOVE..HAVE POWER
If manual override turns Load on-off, and if override snaps crisp and clean, then timer is basically sound.
If dial does not rotate, then replace T100 series 240Volt clock motor.
Link below shows clock motor & trippers for T104 240volt timer.
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 16, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I need the instructions to do the set up
You posted under Intermatic TN300 24-hour plug-in indoor timer with 2-prong outlet
If this is not your timer, add a comment
http://www.amazon.com/Intermatic-TN300CL-Indoor-Mechanical-Timer/dp/B001KBZUK8
Intermatic TN300
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/tn300.ashx
TN300 is same as Woods 59200
http://waterheatertimer.org/pdf/Woods-59200.pdf
Rotate dial until current time lines up with arrowhead located on inner dial.
The segments located around edge of dial are pushed down or raised to set on-off times.
Push segments down for times you want timer ON
Override switch on top of timer.
For programs to operate, move switch to Timer ON
Plug lamp into timer.
Turn lamp ON
Plug timer into wall
Dec 09, 2010 | Intermatic 10 Amp Mechanical Indoor Timer
I bought the model 59200 indoor mechanical timer, I followed all the instructions but the timer does not work...
Is this a Woods 59200 timer?
Yesterday somebody wrote fixya and said that they had two 59200's that didn't work.
I suggested he check timer on another receptacle in another room.
If timer works on another circuit, the first circuit may need a line analysis to check for electrical problem on line. Buy a line analyzer at Home Depot in electric department.
http://waterheatertimer.org/Woods-timers-and-manuals.html
Let's review the timer.
The lamp has to be turned ON.
48 segments located around dial represent 1/2 hour each.
Pull up segments for times you want timer OFF.
Leave segments down for times you want timer ON.
Set timer switch to ON position.
To check if lights turn on, slide switch to OUTLET ON
Timer dial should rotate with passing time.
If dial is not rotating, then check that receptacle has power.
If dial still doesn't rotate, then timer is probably bad ... but check circuit as described above.
Nov 27, 2010 | Hardware & Accessories
How do i program the 24 hour timer by woods?
You posted under Woods indoor plug-in 24-hour mechanical timer.
This particular timer:
Rotate dial until current time lines up with words: 'time now' located on inner dial
To set on-off times, look carefully at dial that rotates.
There are tiny pins that stick up on the dial.
Each pin represents 1/2 hour.
Use fingernail and click pin outward for each half hour you want timer ON
Leave pins inward for each half hour you want timer OFF
Next, plug table lamp into side of timer.
Last step, plug timer into wall outlet.
If this is not your timer, see all Woods timers and manuals:
Or add a comment and I will help.
Nov 17, 2010 | Woods 2C 24 Hour Indoor Mechanical Timer...
My T101 mechanical turns on manually but not by itself. The gears are no longer moving and the dial no longer changes time. how can i fix it?
Buy new 125V clock motor
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=Wh40&op=search&Ntt=Wh40&N=0&sst=subset
Or buy new T101 timer and swap out insides without changing box
Sep 10, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Intrametric T-101R timer used to turn a swimming pool pump on and off. The dial not longer turns so I need to manually turn the timer on and off. Manually it works fine, but the timer feature doesn't...
Check wires from timer motor to terminals. If you buy the same brand of timer, you can "pop" timer mechanism out and replace it with the new one you take out if it's enclosure. Be sure the tripper hands are on the dial.
Jun 15, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Hardware & Accessories Logo
110 people viewed this question
Top Hardware & Accessories Experts
Tom Chichester
ray gallant
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
