Question about Whirlpool Refrigerators
I have the whirlpool WRX735SDBM02 and I want to remove the bottom glass just over the drawer to clean. There are no instructions for this ANYWHERE! It's gross
Posted by carmen on
Gator141a
    New Friend:
  • 22 Answers
Be sure not to put got water on cold shelf it grenades not fun
Posted on Mar 24, 2020
Tom Chichester
    Top Expert:
  • Whirlpool Master
  • 55,375 Answers
Remove the bottom drawer(s) and pop up the glass from underneath. Handle carefully to scrub clean in the sink then set aside while you scrub the rails clean.
5 Related Answers
Anonymous
SOURCE: glass dirty on bottom side
Here's the HP link to clean most of the scanner printers
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00553775&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Posted on Apr 06, 2008
Jeff Meyer
  • 423 Answers
SOURCE: the dishwasher is leaving a gross film on the glass dishes
You may think this is strange, but I am 99% certain that your main problem is a failed heating element in your dishwasher. Pretty bold statement when I don't even know the Make or model of your dishwasher.
After you pull the lower basket out, as you look beneath the wash arm, you will see screws holding down the top of the filter shroud. Take a picture of it with your snazzy cell phone camera as you remove those screws and as you lift things out - for reference when you go to put it all back. While you are down there, feel the entire heating element "circle" Note any breaks and "bubbles." Remove all the debris but watch out for (sharp) broken glass! If you do not see obvious damage to the heating element, reassemble the filter and test. When you see the poor results, a heating element is the root cause. A replacement element cn be ordered and changing it ~may~ require you to pull the DW out (or not) depending on the make and model.
If you are not up to changing the element youself, the service guy can do this.
Good Luck! Please report back with what you find, OK?
Posted on Apr 16, 2009
Anonymous
SOURCE: maytag refrigerators mtbe1956de
brute force on the glass shelf.... it was just stuck in place by the cold sticky liquid that had seeped under the edges and bonded the glass and plastic together
Posted on Jan 13, 2010
Testimonial: "Gee... you are really smart! When id doubt brute force is good."
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: How do you remove the glass front of the oven door
See page 34
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Nov 20, 2010
oldTech2332
Gene Meier
  • 2341 Answers
SOURCE: I removed my crisper drawer and glass to clean and
http://c.searspartsdirect.com/lis_png/PLDM/P0512024-00006.png
the above link as for a drawing of the shelf area and i hope it helps you figure where that piece goes
Posted on Jul 22, 2011
Took our deli drawer to clean. Can't reassemble. Help
If it's the deli drawer from the bottom of you refer and you took the entire assembly out at once you will know because it all came apart when you started cleaning it. If it's got two drawers then you now have a piece of glass a frame with legs on it and two drawers. So open the refer all the way, look at the back and the sides where you removed it from, you'll see some groves or ridges or little nubs take the frame by its self and fit it into those places you see, then take the drawers one at a time ( usually the one closest to the door hinge is best to start) and slide them back into place. take your time because like a dresser drawer there is a notch that you will have to work with that's designed to keep you from pulling it completely out when you open it. then place the glass into the frame on top and your done.
Oct 02, 2012 | KitchenAid Refrigerators
I purchased whirlpool GX5FHTXVA and there is a divider piece of plastic taped to the bottom of deli drawer, I have no idea where it goes. It is not in the manuel.
The wider end of the piece can be hooked anywhere on the back of the deli drawer. Keep the piece bent when you install it or it will scratch the glass on the front of the drawer. Also, make sure the tip of the smaller end is touching the bottom of the drawer before straightening the divider._1165.jpg
Apr 17, 2011 | Whirlpool GX5FHTXVA Bottom Freezer French...
F21 clogged line on a new Duet Sport less than a year old???
Hi, regarding the F21 Error on the Front End Whirlpool Duet, I was able to resolve the problem with the instructions from here, just want to stress cleaning out the filter by removing the front panel. Very easy and the error code is now gone. (screws are underneath front panel at bottom, remove stacker drawer for easy access, remove screws, pull panel off, remove the filter cap, turn to the left and pull out-that's where you will locate the clog.
Oct 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag refrigerators mtbe1956de liquids have dripped on to the bottom glass shelf and seeped under the edges where it cannot be cleaned. do I have to remove the vegetable drawers and totally dismantle the...
Jan 12, 2010 | Refrigerators
The glass cook top of my whirlpool range cracked and i can`t seem to find a model number anywhere on the unit. help
You might find the tag in one of these places:
Cooktop/Range/Stove
Gas:
  • Inside the cooktop--if the top lifts up
  • On the outside, bottom of the unit
  • Inside the top of the vent duct--if it's a “downdraft” unit
Electric:
  • Under one of the surface burners, or inside the cooktop--if the top lifts up
Gas or Electric Oven
  • On oven side of the door jamb (with the door open)
  • On the lower drawer jamb (with the bottom drawer open)
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Aug 02, 2009 | Kitchen Ranges
How can I remove the Whirlpool Duet washer pedestal drawer?
When you look this will not appear to be how it is done but it is in fact the way. Pull the drawer all the way out and then look on the side of the drawer at the very front and you will see a single small screw that attaches the track to the drawer. It would appear this is part of a series of screws and the track itself should seperate but neither side of the track removes. Simply remove these screws on both sides of the drawer with a small hex head socket and the drawer will pull right out. Push the tracks back into the pedestal until done cleaning the drawer.
Jun 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Where does this part/piece go in the frig?
by process of elimination .....I finally figured it out...
Jul 17, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Refrigerators Logo
93 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
jdthefixer
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
