How to reprogram f150 radio no fm - Audio Players & Recorders
Posted by JERALD UPDEGRAFF on
LS. How do I reprogram the frequency bandwidth on FM on a theftlock radio?
You are confusing AM channel spacing with FM tuning. Some radios have a switch for selecting 9 KHz or 10 KHz spacing.
Jan 28, 2016 | 2002 Chevrolet Blazer
Toyota-56037 radio (FM/AM) malfunctions..like... the system receives FM signals 76Mhz to 90 Mhz only although there are a lots of channels after 90Mhz. How to reprogram it? Plz help. TAUFIQ
if there is a mode button , press that and there is fm 1 whch is what you have , press again and you get fm 2 press again and you get fm 3
each fm number is a band width so select the band width that has most pf your stations and then auto select on it
if you have the owners hand book , the procedures are in ti for setting the radio
Nov 17, 2015 | Audio Players & Recorders
Changed battery now radio will work on am only when i push the am/fm button the display reads set1
When you replaced the battery, it reset the radio. You will need to reprogram the radio stations you want on fm. Find the radio station you want and then press the set button on the radio and then the corresponding number on your radio (ie: set1, set2, set3, set4 or set5)
Feb 27, 2011 | 1995 Jeep Grand Cherokee
FI have a cb radio from Hong how do Ichange frequency to suit Australia. The radio is Qishi fm transceiver, QS-368S.Is it possible to change crystals,if they still use crystals
There are versions of this radio on different bands, some versions will not work on the Australian 477MHz CB channels even if reprogrammed.
Reporgramming the radio requires the software and a programming cable. Ask you radio supplier if the software and a cable is available.
If the radio is a version that will work and you manage to reprogram it it may work but will not be legal to use on the Australian UHF CB system because it is not type approved.
Sep 05, 2010 | Radio Communications
Speaker sizes for 1985 F150?
the front door speaker size is 6.5". i dont belive there is speakers in the dash
Feb 07, 2010 | 1985 Ford F150
88 Ford with AM radio That i wish to withch to factory AM/FM Cass
There should be a button or switch somewhere on the new radio that allows you to go between AM and FM tuning.
Jul 20, 2009 | Pioneer AVIC-D3 Car DVD Player
Aiwa CR-LD120 AM/FM Radio?i program my radio stations, but when i have to change batteries i lose all the stations and have to reprogram them
This is a common problem when disconnecting power!
Try buying an ac adapter at your local pharmacy or radio shack and plug it in before changing batteries
Feb 08, 2009 | Aiwa CR-LD120 AM/FM Radio
56 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
