Question about Health & Beauty
My wrench light flashes 9 times on my promo m94
Posted by Donna Dotson on
Tip
Promotional Video Converter-Convert Flash/Camera Promo Videos to iPad Everyday,...
Everyday, we encounter different kinds of promotional videos and demos as video marketing, or experiences and opinions sharing. When facing an attractive and interesting promotional video suddenly, do you want to save it to your iPad, iPhone 4 or other portable devices, and share it with friends? I find a banned iPad promotional video from youtube, and it is interesting. You can have a look at it from http://www.youtube.com/watch?v=3HHLNQ3BZEA.
To create your demo video, just have your camera ready, and you can build a promo video and display it on iPad. No matter your camera is JVC, Canon, Sony, Panosonic or other. To download Flash promo video, you just need some free downloader tools to download youtube videos, or Flash videos from websites on computer. The next thing you need is just a powerful video converter to convert the promo videos and captured videos to iPad compatible .mp4 files. Aunsoft Video Converter is the right tool to convert promo videos to iPad and iPhone 4 and other portable devices without losing video quality.
Here I would like to take iPad as an example for the simple steps on the promotional video converter.
Step 1. Load promo videos to Aunsoft Video Converter.
Download promotional video converter, and click the "Add" button to load promo videos and demos to the converter. You can load Flash demo in .flv, .f4v, and camera videos in .mts, .mpg, .avi to the converter.
Step 2. Choose output format.
Click the "Format" option and choose iPad > iPad HD Video(*.mp4) for output video format.
Tips: There are also many different profiles for iPhone 4, iPod or Xbox 360. If you want to display promo video on iPhone 4, just choose iPhone > iPhone 4 H.264 720P(*.mp4).
Step 3. Convert promo videos to iPad MP4.
Click the convert button under the preview window, and the promotional video converter will start to convert HD promo videos/demos to iPad MP4 format.
You can then connect iPad to computer, and sync output mp4 videos to iPad via iTunes. It is just that easy for you to enjoy promo videos/demos and share with friends in high quality.
on Jul 01, 2010 | Cameras
What does a jazzy 614 power chair 9 flashing wrenches need?
hi, that is the code for a brake fault , check the wiring to the brakes located on top of the motors...
Regards
Rob
www.gewizrepairs.co.uk
Jul 05, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
I have a Invacare Pronto M51, the chair won't move. When I turn on the joystick, the wrench light flashes 9 times, stops, then flashes 9 times again. Can you tell me what that indicates?
A flash code of 9 indicates a communication fault. What this means is that there is a lack of communication between the joystick and the other electronic component, the controller module. In my experience, the usual culprit is that the charger plug makes bad contact inside the joystick housing causing it to heat up and burn. This can cause components inside the joystick to burn out. The other more common problem is that there is a break in the 4 wire harness going from the joystick down to the controller in the base. Sometimes it is just a matter of unplugging the connector, cleaning it, and pushing it back in. In other cases, the wire has been cut or broken along its length. Look for cuts along the black covering of the 4 wire harness (connecting cable)and twist and tape or splice and solder to repair the wires. These connecting harnesses are so inexpensive it is usually easier to replace, however a quick splice can get you going temporarily. If you smelled burning that would be an indication that the joystick assembly has burned out and I would replace that along with a new harness (connecting cable with a plug on each end) to the base electronic module.
The connecting cables have always been a weak link in this design and have had a history of failures over the years. For this reason I replace both the joystick assembly and connecting cable when servicing. Hope this helps.
Mar 21, 2014 | Invacare Pronto M51 Power Wheelchair
Lock key keeps blinkinglights blink 9 times
Depending on the controller type being used you either have a controller solenoid brake fault (sticker on bottom of joystick will say "PG Drives" and have 9-bars flashing) or a communication error between the controller and joystick (Dynamic Controller flashing wrench).
Repair for PG Drive is to replace joystick/controller.
Repair for Dynamic is to clean, remove and reseat or replace joystick cable.
Nov 12, 2013 | Pride Jazzy Select 6 Indoor Power...
Flashing wrench 9 times
Lester - so many issues. Take it to a dealer.
9-Flashes means comm fault - check joystick wiring harness.
Nov 01, 2013 | Electric Mobility Invacare Pronto M41...
My jazzy select 14 on the controler near the joystick lights up what looks like a yellow wrench in a 9 flash. Lights 9 times stops then lights nine more times over and over . please help
well a wrench means the obvious that something needs adjusting , if it came with an instruction manual search for the code 9 blinks will mean.
Oct 16, 2010 | Pride Mobility Products Jazzy Select 14
One red light three green flash when turned on
Your chair has a motor problem. The code does not tell which side it is. Make sure both motors have the brakes in the drive position before turning on the chair. Also check that both motors are plugged into the main control module in the base of the chair.
May 15, 2010 | Invacare Supply Group Invacare Pronto M91...
No power
well,,, um try getting it a new power battery?
Apr 03, 2009 | Invacare Supply Group Invacare Pronto M91...
Health & Beauty Logo
137 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
ray gallant
Are you a Health and Beauty Expert? Answer questions, earn points and help others
