Question about Smeg Cooktops
I HAVE A SMEG CERAMIC HOB SE395ETB JUST OUT OF THE BOX BRAND NEW EVERYTHING TURN ON BUT NO HEAT ANYONE KNOW WHAT IS HAPPENING
Posted by fred cordonnier on
1 Related Answer
gerbee gomez
  • 222 Answers
SOURCE: neff T1722 so 02 ceramic hob
its normal for the ceramic hob to ON & OFF coz of the sensor inside the unit to protect for overheating.same here in phillipines.its normal.tnx gerbee
Posted on Jan 27, 2009
Induction hob not heating up. What does 5h or SH error code indicate?
if they are not steel bottomed pans they will not work with induction hob test them with a magnet
Apr 07, 2013 | Smeg Cooktops
Hob problems
Take a closer look at the wiring diagram on the base or in the book.Check you have put in the relevant links.If not wired properly you may only get half the hob working.
Hope this helps.
May 19, 2010 | Smeg 28 in. P752 Electric Cooktop
Want a narrow ceramic cook top / hob
Look at Baumatic 90cm Slimline 4 Hyperspeed Zone Ceramic Hob. Dimensions are 350mm x 880mm
Apr 26, 2010 | DeLonghi Cooktops
Eurokera hob - lights flashing, buttons not working
hi i have a eurokers ceramic hob and it has not worked in about a yr. it is touch screen and only 1 mth old when problem happend it was like it over heated and now when you turn it on it flashes on the dial i cnat make out it and the hob wont come on. pls help it is brand new and dont want to throw it out.HELP PLS
Dec 26, 2009 | Cooktops
Cant switch on hob
gud day,the ceramic hob is very sensitive to operate if u not read the manual.after u unlock the switch go to the control of the hob wat area u want to operate by touching the sensor then if u see the zero # touch again the area,positive side to increase the heat 1-9 the standard control heat.some model & brand have a different operational procedure,try to read the manual 1st or check the voltage of the unit coz the ceramic have a 4voltage standard for different country. tnx gerbee
Jan 26, 2009 | Neff 23 in. T1443 Electric Cooktop
Brand new bosch pke691e20e ceramic hob trips 50amp mcb
You have a short to ground somewhere.
Was there a new cord installed on it or did the cord come already installed?
It could have been wired wrong causing a short to ground. there could be another wire touching the cabinet, a wire pinched by the cabinet.
You may have to trace down every wire with a continuity meter to find it, but its probably fairly obviose.
I'd start at the cord.
First try this, unplug the cord, turn the breaker back on just to make sure the problem is indeed in the unit not the receptacle or panel box.
If the breaker stays on, you know its in the unit.
Dec 05, 2008 | Cooktops
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Neff T1722 so 02 ceramic hob
Jul 28, 2008 | Neff 23 in. T1443 Electric Cooktop
PROBLEM WITH HOTPLATES SWICTHING OFF
Sometimes this happens if the pan bottom is not completly flat or is highly polished. Darker, flat pans work best. It sounds as if the safety is cutting off the burner.
May 31, 2008 | Cooktops
Cooktops Logo
145 people viewed this question
Top Smeg Cooktops Experts
Ismael Rodriguez...
Jorgie Navito
Jorgie Navito
Andrew Taylor
Andrew Taylor
Are you a Smeg Cooktop Expert? Answer questions, earn points and help others
