How di I fix code 0x80240fff - Office Equipment & Supplies
Posted by james liggett on
Why is amy copier throwing a sc 49-1 code?
What do you mean yo cleaned the control board?? Did you remove it????? IF you did major problem a Will have to go back and remove each connector looking for a bend pin and ensuring each connector is properly seated. Never remove board unless required. As for the code: please check code could not find in the service manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 22, 2014 | Konica Minolta Minolta Di 650 Di 551 Di...
Error code 42-2
Below the main power switch (Located left rear) now move your down and towards the front about in the middle is vent well check the fan behind that vent. clean/replace worse case the board controlling it is bad.$$$$$$$$$$$$$$$$$$$$$$$$$$$
try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 19, 2014 | Konica Minolta Minolta Di 650 Di 551 Di...
Di650 error code 42-2
FM-2 Fan code, Below the main power switch (Located left rear) now move your down and towards the front about in the middle is vent well check the fan behind that vent. clean/replace worse case the board controlling it is bad.$$$$$$$$$$$$$$$$$$$$$$$$$$$
try this site
How do i clear the user code on the minolta Di 2610
do you mean Di 2510 ???
Do you mean access code for adminstrator or the Password for accounts??
Mar 15, 2014 | Konica Minolta Office Equipment & Supplies
Clearing code
what code???????
Nov 20, 2013 | Konica Minolta Minolta Di 650 Di 551 Di...
Error code sc23.03
Minolta Di 750 error code SC-23-01 i want solutions this code.
Sep 17, 2013 | Konica Minolta Minolta Di 650 Di 551 Di...
What di I have to fix when i get the following
only the code book will tell you if it is a code from an odb reader, if your on board system say it, refer to your owners manual.
Dec 12, 2009 | 2003 Saturn VUE
Fixing code cof32
The excess toner is under cleaning blade.Posible you emptied the developer.COF 32 ATDC sensor malfunctions.Tray ATDC gain level from 155 to 168.
Apr 22, 2009 | Minolta Office Equipment & Supplies
What changes have been done to the latest firmware for my DI-604 and DI-614+?
V3.36 (DI-604 RevE only): Fixed minor interface bugs V3.38 (DI-604 RevE only): Fixed issue with non-standard FTP port function Fixed issue with WAN speed selection feature Fixed issue with Stats page - showing 0 transmitted packets Fixed minor Virtual Server bug V3.39 (DI-604 RevE only): Add WAN speed selection option - defaults to 10Mbps Fixed dial on demand/idle time bug Fixed Asheron´s Call II reboot issue Fixed Static DHCP/MAC filter clone issue Fixed Virtual Server entry bug
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
50 people viewed this question
Marvin
Marvin
