Hi Darshan Ganesh, you can connect your phone to your Philips D573
You must connect the audio audio output of your phone (headphone output) to the Philips Auxiliary input on the rear panel
Hola Darshan Ganesh, puedes conectar tu telefono a tu philips D573
Debes conectar la salida de audio de audio de tu telefono(salida de auriculares) a la entrada Auxiliar del Philips en el panel trasero
https://www.philips.ae/c-p/FWD573_98/-
SOURCE: I'VE PHILIPS D573 DVD HI
Your disk could be scratched. You can try and resurface it. You may try to clean the disk as well. Also if a burned the DVD some players will not play every format. Are you getting the same response from several DVD's? If so then I recommend getting a good DVD lens cleaner disk and running it through a time or two or even three if it has been a while since it has been cleaned. Good luck.
