Question about Furniture
I have a Eurocave purchased sometime in the early 80s. Model EC1T/200.
Works perfectly and have all the original paperwork, wine tags, shelves, Wine Manual, etc. Does anyone have any idea what it is worth? It was used for about one month in the 80,s. Been in my downstairs den since then.
Posted by Diane Sartori on
5 Related Answers
Anonymous
  • 1122 Answers
SOURCE: Eurocave Repair
can you tell if if it's running by putting your hand on the compressor,then we can go from there
Posted on Dec 17, 2008
Sheldon Dedek
  • 912 Answers
SOURCE: Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
Posted on Nov 02, 2009
Anonymous
SOURCE: Wine Refridgerator - Class Action Lawsuit
Franklin Industries (Franklin Chef) has filed for bankruptcy protection as of 9/11/09:
http://www.franklinchef.com/important.html
Looks like we are out of luck
geoff hunter
  • 4793 Answers
SOURCE: Moving a Eurocave wine cooler laying flat
the reason you should not lay a fridge/freezer on its side is that you will get air bubbles in the cooling pipes,which you may not be able to get rid of when you turn it back upright.I have moved loads of f/f, in the past and have had no problems,as long as you give the unit at least 24 hours to right itself.....and keep the door(s) closed while it is "resting"
Posted on Apr 17, 2010
Testimonial: "Thanks for the great answer!"
Anonymous
  • 259 Answers
SOURCE: Are red wines stored on the top or bottom of the
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Posted on Jun 14, 2010
Excess condensation in my eurocave 266
Check the door seal gasket is sealing without any gaps. Check the ambient temperature isn't too high, and check the condenser is clear and aired.
Apr 20, 2014 | EuroCave Comfort 266 Connoisseurs Package...
One side of my Eurocave SoWine Cooler does not work.
As you must be aware there are individual fans in both the compartments. Check if the fan is running in the compartment not cooling. If not, check the wires / connection of fan or replace the fan.
If the fan is working than the issue may be with the THERMO ELECTRIC ELEMENT. you'll need to replace it.
Sep 09, 2013 | The Wine Enthusiast Wine Enthusiast...
Ice in the unit. Whould shoud I do? Who should I contact to get the service...What kind of filter does it take and where can I purchase it?
I also have problems with ice in my unit. How can this problem be solved? Do it need a repair technician to come out?
Sep 02, 2011 | EuroCave Comfort 260 Collector's Package...
Eurocave comfort 264: Problem, ice formation inside the unite , half the way the middle section of the unit ( Racks 8-10)
It's likely that you need to change the filter. Have a look at this post: http://blog.wineenthusiast.com/2009/04/20/caring-for-your-eurocave-3-simple-steps-towards-long-lasting-wine-protection/
Sep 30, 2010 | EuroCave Comfort 260 Collector's Package...
Apr 17, 2010 | EuroCave Comfort 260 Collector's Package...
Eurocave digital thermometer
The digital temperature display on the EuroCave has a small lithium battery that can be replaced by removing the bezel around the display. This was all that was needed to solve the problem.
Jan 22, 2009 | EuroCave Comfort 260 Collector's Package...
Eurocave Repair
Dec 17, 2008 | EuroCave Comfort 260 Collector's Package...
Top indicator light is on (orange)
Get info here:
http://www.eurocave.com/wine-cellar/wine-cellar-cooling.htm
Jan 03, 2008 | EuroCave Comfort 260 - Black Solid Door
Furniture Logo
141 people viewed this question
Top Furniture Experts
Tom Chichester
ray gallant
Are you a Furniture Expert? Answer questions, earn points and help others
