Question about Hardware & Accessories
I need to change the pulse duration on a 4VV38 Dayton timer that controls all the lunch and break buzzers. It currently is in default mode at 1 second.
Posted by Jeff King on
1 Related Answer
Tom Wagner
SOURCE: I have a Dayton controls programmable timer in my
Slide switch on bottom left to TIME. Press H key for hour - M key for minutes Then WEEK key until day of week. Press SET and current time is displayed. Slide bottom left switch back to AUTO and present time will display
Posted on Nov 17, 2011
I have a Dayton controls programmable timer in my shop to control the bell for breaks, lunch, etc. I need to change the time of day to allow for the end of daylight savings time. I don't know how to...
Nov 07, 2011 | Amperite Dayton Solid State Timer On Delay...
I need to know what to set my dials/sttings on 1EJE8 Dayton Timer. What I am trying to do is sound an alarm when I hit reset the timer shuts off the alarm for twenty min before resounding
Question is unclear.
Help me break it down.
You want to push a button and sound alarm?
And then you want alarm to sound until you push button again?
And then you want timer to delay 20 minutes before sounding alarm again for an unknown amount of time?
What is the reset?
Add a comment and say what control you have wired to the timer and a clear 1-2-3 sequence of events and times for possible help.
1EJE8 is 10-function timer, and no manual appears on the internet July2011.
Magnecraft has same-similar timer, the 820 series.
Open following link for detailed manual with illustrations.
http://www.serelays.com/library/section5/105A_820_Series.pdf
Jul 14, 2011 | Amperite Dayton Solid State Timer On Delay...
I am looking for a multi function relay similar to the Dayton (1)6A855 but with a 240vac input not 120vac input. Can you assist please. Regards Bruce Peters
1) Dayton 6A855 time delay pin timer
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=dayton+6A855&op=search&Ntt=dayton+6A855&N=0&sst=subset
Grainger owns Dayton, so you might want to contact Grainger
http://www.grainger.com/Grainger/static/help_contactus.html
1-888-361-8649
2) Time delay timers at Grainger:
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=dayton+timer&op=search&Ntt=dayton+timer&N=0&sst=subset
3) Grainger shows time-delay 8-pin 120 or 240V
http://www.grainger.com/Grainger/DAYTON-Relay-1EJN7?Pid=search
Grainger shows 11-pin 120 or 240V
http://www.grainger.com/Grainger/DAYTON-Relay-1EJN6?Pid=search
Searching for "11 pin 240Volt delay timer" turned up results:
4) Following pdf shows knob-adjustable 240V delay-on pin timer
https://www.relayspec.com/specs/020050/T1Series.pdf
5) Signaline has delay timers (800) 862-2875
6) SSAC
http://www.ssac.com/standard/ff-tdr1.htm
7) Another pdf with 240V delay pin timers
http://www.askco.com/pdfs/tdd_tud_data.pdf
8) Not wanting to say what already know, but each 240V circuit is made from two out-of-phase 120V lines. Any 240Volt Load can be turned OFF by turning off one of the 120V lines. In this way, the Dayton 120V timer can be used to control 240V load.
Also the 120V Dayton can operate 120V double-pole contactor, and then the contactor controls 240V Load.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html#contactor
Apr 04, 2011 | Amperite Dayton Solid State Timer On Delay...
I am in need of some advise. I have a pellet stove and need to replace an obselete part, I am wondering what would be the best delay relay timer to use, it will operate an 6rpm/150lb torque auger that goes...
1) Pex supply sell the E502 OFF delay Paragon product: Timing cycle begins when switch is activated, and shuts down at end of timing cycle. 5 seconds to 3 hours
http://www.pexsupply.com/Paragon-E502-Electronic-Off-Delay-Timer-5-sec-to-3-Hrs
http://www.grainger.com/Grainger/cycle-timers/timers/electrical/ecatalog/N-8hb
See manuals for Paragon product:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#percentage
2) Tork ACT120 cycle timer (minimum ON is 30 seconds)
http://www.grainger.com/Grainger/TORK-Adjustable-Cycle-Timer-4JNH8?Pid=search
http://www.nsi-sales.com/act_series.htm
See ACT manuals:
http://waterheatertimer.org/Tork-timers-and-manuals.html#cycle
3) Intermatic CT1000 cycle timer: cycle durations of 30 seconds to 30 minutes, with on-off durations from 1 minute to 29 minutes.
Click model number to access manual
http://www.intermatic.com/products/timers/mechanical%20time%20switches/percentage%20cycle%20timers.aspx
Drillspot sells indoor/outdoor 120V or 240V CT1000
http://www.drillspot.com/products/1325934/Cycle_Timer_CT1000_Cycle_Timer?s=1
4) Do a google search for 'electronic cycle timer' or 'percentage timer'
5) Timers listed above can be wired to a contactor (or relay) that turns on auger, if that's what project calls for.
Dayton off-delay timers require push-button operation
Feb 03, 2011 | Amperite Dayton Solid State Timer On Delay...
On terminals 6 & 7 do you need to apply a power source? is terminal 2 the hot from breaker and #3 the neutral terminal?
Following page has Dayton timer wiring:
Terminals 6 and 7 are wired with 120Volt power as shown.
The push button gives momentary impulse of electricity to timer.
Timer activates when impulse of electricity ends.
Timer activation turns Load ON and begins countdown.
When countdown expires, timer turns Load OFF.
Terminal 2 is 125V Hot from breaker.
Terminal 3 is Neutral.
Terminal 1 goes to Load.
Load cannot exceed 1 amp.
So Dayton timer can only control single 100 watt light bulb, or it can control 120Volt coil on contactor.
Contactor turns on Load with any voltage: 120, 240, 277, etc or 3 phase contactor.
Suggest busman in-line 1 amp fuse between terminal 1 and Load to protect timer.
Jan 05, 2011 | Dayton Audio Dayton 6a857 Solid State...
Is the button NC or NO? I have it currently wired this way but still it does not work and I'm using a switch not a button. Any suggestion?
The switch is OFF or NO normally open
See wiring diagram at following link
The way the timer works is this::
You click switch ON
When you turn switch OFF, the Dayton begins the timing sequence
The Dayton turns on the circuit going to load for 1/2 second => 5 minutes depending on model of Dayton timer
Grainger sells 120V push buttons if you don't want to turn the switch on-and-off each time
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=push+button+switch&op=search&Ntt=push+button+switch&N=0&sst=subset
http://www.grainger.com/Grainger/IDEAL-Push-Button-1XWT9?Pid=search
Oct 12, 2010 | Amperite Dayton Solid State Timer On Delay...
Hi, I have a Dayton # 2VJ58A Ditital time switch,can I program P1 and P2 with some of the same on and off times during the week. How does the timer know which times to follow when it is put back to the run...
Dayton 2VJ58A is a small, expensive 2 channel timer.
My understanding is that 2 channel timers are made "for the independent control of two circuits." I assume the advantage of multi-channel timers is needing just 1 timer on the control board.
If you are using 2 channels to control one circuit, I don't know the outcome, or if the 2VJ58A is made to do that job. It may ruin the timer!?! Be careful.
The less expensive ST01C timer offers 40 programs per week where overlapping times can exist on same load. These timers advise not to program overlapping times, ST01C troubleshooting says NOTE: Your switch timer automatically skips any conflicting ON event
Dayton timers are made in Japan but I could not locate a web site other than Grainger who sells the product. Probably the timer manual has manufacturing info. Grainger sales might be able to help?
http://www.grainger.com/Grainger/DAYTON-Electronic-Timer-2VJ57
Solution: I would call the seller, or Grainer, or the manufacturer. They might know about the software parameters. I would re-read the instructions carefully, and read up on multi-channel timers before putting power to the timer.
Let us know what you are trying to accomplish with the timer, and maybe we can help from that standpoint
Sep 20, 2010 | Dayton Audio Hardware & Accessories
Nokia 6300- no ringer/ speakerphone/ music
Welcome to FixYa
First up all Check Profile is in Silent mode/Ringer in Silent.
  • Restore Settings by Entering Phone Code[Default is 12345]
Still Trouble, This seems to your Phone's Buzzer is Damaged.Needs to be changed.After Buzzer change Problem Exist [Need Technical Experience]
  • Check Audio IC
  • Check for Damage/Break in Track or Circuit
Your Problem Is Solved now....Thanks for Contacting FixYa..
Jun 21, 2010 | Nokia 6300 Cellular Phone
I have 3 lights and want 1 light to come on for 15 sec and then off and another 1 to come on for 15 sec and then off and then the last light to come on for 15 sec and then off and start the process all...
Intermatic 70815CR
30 amp max, selectable voltage 120V 240V etc.
You want to control 3 separate circuits.
So you need a timer with minimum of 3 independent relays.
Each circuit has a different program.
So you need a 3-channel timer. Each channel is programmed separately to operate a different relay.
You want timer to operate in 15 second intervals. Most electronic timers have minimum 1 minute on-off, so you need electronic timer with pulse capability.
May 11, 2010 | Amperite Dayton Solid State Timer On Delay...
Stand by timer shuts tv off after 30 sec sony tv
Sounds more like it's been set to do that. Use the following to shut off the timer mode. It's possible that the set is set to the wrong time of day but that is unlikely. You can shut off the timer mode using the on screen menu. Follow the instructions below.
Using the Timer Menu
Current Time Set your TV to the current day and time. Press to open the Current
Time menu:
1 Use the F or f buttons to enter the correct day and time, then press
2 Press to exit the menu.
Timer 1 and
Timer 2
Scheduled
viewing
Use the timers to program your TV to turn on and off by day, time,
duration, and channel. The timer duration is a maximum of six hours.
When the channel is fixed, it is not necessary to set the channel.
1 Use the F or f buttons to highlight Timer 1 or Timer 2, then press
2 Use the F or f buttons to enter the desired day, start time, duration,
and channel, then press . The timer status should be On when the
Timer has been set, and the timer light on the front panel of the TV
should be on.
3 Press to exit the menu.
? When you perform Auto Program, Timer 1 and Timer 2 settings will be cleared. Also, in the event of
any loss of power, Current Time, Timer 1, and Timer 2 settings will be cleared
Apr 16, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hardware & Accessories Logo
141 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
