Question about Refrigerators
MY WHER25 REV. OS. IS LEAKING AT THE HOLE IN THE BOTTOM OF THE SPOUT . i CHANGED THE FILTERS.. IT STILL LEAKED.. I CHECKED THE DRAIN GOING INTO THE P-TRAP .. IT WAS CLEAR
Posted by Joe LaChance on
1 Related Answer
Anonymous
SOURCE: MY WHER25 REV. OS. IS LEAKING AT THE HOLE IN THE
Remove the faucet spout and unscrew the screw keeping the white plastic piece on the bottom (of the faucet). It's where the red and black tubes enter. Pull out the white plastic with the tubes and clear it of debris (usually placed there when your disposal backs up the black tube, which serves as the filter's drain tube). Once it is cleared of debris, make sure the black rubber washer is back in place (it may be stuck in the faucet, so look for it) and replace the plastic, screw the screw back in, and secure the faucet again. I had this same problem and doing this solved it. Should take about 5 minutes or so. Good luck.
Posted on Mar 05, 2010
Water leaks at bottom of fridge
The same thing happened to me then I noticed ice had formed at the bottom of our fridge. It was covering a drain hole so water was leaking out the front of fridge instead of going to the drain pan or wherever the hole goes. After I chipped out the ice and cleared the hole with warm water the leak stopped. I also fixed another leak coming from bottom of fridge caused by a loose brass connection on water line going to the door.
May 25, 2014 | Hotpoint HSS25GFP Side by Side...
Cant find radiator drain plug
  1. Open the hood.
  2. Look for the fill spout.
  3. From the fill spout go strait down the back of the radiator.
  4. The drain spout is right there on the backside of the radiator towards the bottom (see pic).
  5. Turn with a pair of Vice Grips or stick a little screwdriver in the hole in the center of drain tab.
Regards, Tony
Apr 30, 2011 | 1999 Oldsmobile Silhouette
I own the Wher25 Reverse Osmosis system. I
There is a blue cap on the body of the white pressurized water tank. Twisting off the blue cap, you will see a air nozzle - similar as those on the tire. You need to pressurized the tank to 60 PSI. I spend hours to figure out this solution on my own system.
Mar 14, 2010 | Home
MY WHER25 REV. OS. IS LEAKING AT THE HOLE IN THE BOTTOM OF THE SPOUT . i CHANGED THE FILTERS.. IT STILL LEAKED.. I CHECKED THE DRAIN GOING INTO THE P-TRAP .. IT WAS CLEAR .. PLEASE HELP
Dec 02, 2009 | Whirlpool Home
My airconditioner is leaking inside the van. last
YOUR AC CONDENSTAION DRAIN IS PLUGGED, CLEAR IT. THE DRAIN IS ON THE PASWSENGER SIDE UNDER THE CAR BOTTOM OF FIREWALL.
Aug 09, 2009 | 2003 Chevrolet Venture Passanger
My Amana ABB2257CS bottom freezer leaked water
your freezer cabinet need to get all out also the ice machine,and open the back wall
there is a drain hole in the bottom middle of it make sure it is clean, and if you pure water they go all the way
through the pip to the drain pan next to the compressor.
good luck 911servicetoday .com good luck
Jun 29, 2009 | Amana ABB1927DE Bottom Freezer...
Changed filters on Whirlpool Reverse Osmosis and now water leaks.
the tube going from the ro cartridge is clogged or the drain tube going from the faucet to the drain p trap is clogged
I have installed many ro systems a=nd have had that problem Not only do youhave to replace the filters but make sure the drain hoses are clear
use a pipe cleaner or a a stiff wire
I also remove the connection going into the ptrap and clean back to faucet...it is usually real nasty
Dec 29, 2008 | Plumbing
Dehumidifier m7dh65b2a
Mine leaks. Had leaked at other times but i took the vacuum cleaner to the front drain spout, that leaks into the removable basin. That worked in the past, but i't's not working now . The water is overflowing at the back of the catch tray and leaking out through the bottom underneath. The holes are clear, so it shouldn't be doing this. I am stumped.
Jul 04, 2008 | Maytag M7DH45B2A Dehumidifier
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
