Question about Food Mixers
How to fix a Krupp beater that won't latch in place?
My Krupp mixer has two beaters. The one that does not control rotation won't latch in place.
Posted by Ginger Wallace on
5 Related Answers
Anonymous
SOURCE: bravetta mixer
Call Euro-Pro Operating LLC at (800) 798-7398
Posted on Dec 04, 2007
Anonymous
SOURCE: Where can I find a flat beater for Wolfgang Puck 600 Bistro Mixer
I contact Wolfgang Puck directly. Thanks
Posted on Nov 19, 2009
hslincoln
Howard Lincoln
  • 235 Answers
SOURCE: kitchen aid gear- where the beaters are attached -
Hi BEV, By the symptoms you are describing, it appears that your planetary/agitator shaft (where you attach the beaters) assembly is dropping from the mixer head, is that correct? When you replace the planetary and lift your bowl up into a ‘locked’ position, the planetary is being held in place by the beater resting on the bottom of your mixing bowl and ‘works’ for the time being. However, you don’t want operate your mixer that way for very long.
I suspect what caused the planetary/agitator shaft to drop from the mixer head is that one of the pins used to secure the planetary/agitator shaft assembly to the mixer head has failed (sheared) so now there is nothing holding the planetary/agitator to the mixer head. The good news is that this is fixable.
The inspection and troubleshooting of your mixer’s transmission is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer. If you are lacking one, you can download it from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case KSM50PS. Unfortunately, entering your exact model number yields many Owners manual and no Parts Manuals, so I would use the following, KSM500, and select the last file under Parts List (16) KSM500WH0.pdf (857.41 KB). Verify your mixer matches the mixer in the illustrations. Turn to pages 4 & 5, titled ‘Case, Gearing & Planetary Unit, for the disassembly, troubleshooting, and reassembly of your mixer, along with a listing of all the parts. Make sure you inspect
Locate Illust. No. 14, Groove Pin, Part # 9795443. This pin retains the planetary/agitator shaft to the mixer head, and I suspect this is the pin that has failed and needs to be replaced. Getting to it will require the disassembly of the whole transmission. This will be messy as you will need to remove all the grease from the gears and center shaft.
While your mixer’s apart you should check for any other unseemly wear and tear on the gears, etc. You may find more things that need replacement than just the groove pin.
Besides needing a replacement pin and grease, you might consider replacing the gasket, too. I recommend using a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call).
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. You should search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Here’s a link to an excellent site for disassembling/fixing your KA Mixer. Although it’s a different model, the principles are the same: http://www.neilcrockett.com/mixer.htm and another link to a site that details the disassembly and replacement of mixer’s grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.htmltl
If you feel troubleshooting and repairing is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! – hslincoln
Posted on Dec 07, 2009
hslincoln
Howard Lincoln
  • 235 Answers
SOURCE: KitchenAid Mixer is not rotating.
Hi MANILYNTHEOB. I’m sorry to hear about your mixer not working. Unfortunately from the symptoms you describe, your mixer has experienced a transmission failure. You don’t mention how old your KA mixer is or how hard it’s been used, but for your particular model, KA has a plastic gear designed to fail, instead of the whole mixer ‘going up in smoke’. And what it sounds like is that this fail-safe gear finally ‘failed’ (stripped) so that the power from your electric motor is not getting to your planetary (“elliptical rotating part”) and the agitator shaft. What can you do?
The good news is that this can be fixed quite easily (OK, maybe a little effort) by yourself, if you are a DITY type person, feel adventurous, and your mixer is not under warranty you can troubleshoot it yourself. Be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> then enter the visitor type “Consumer” and then enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 4 & 5, titled: Case, Gearing And Planetary Unit for the disassembly and reassembly of your mixer, along with all the parts. Locate Illus. No. 58, Worm Gear Bracket & Gear, including Illus. No. 12, Worm Gear (23 teeth). I suspect this is the weak link in your mixers transmission and causing the problems. After clearing all the grease away, you’lll probably find that is has been stripped.
You can order a replacement gear and install it yourself. While you’ve got your mixer this far apart you can check for any other unseemly wear and tear on the on the gears and other components. Besides a replacement gear, and grease you might consider replacing the gasket, too. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call). Do not try to reuse any original grease as this should be filled with debris from the stripped gear.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, should you decide to go that route.
If you feel this repair is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping. Good luck, I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Posted on Jul 09, 2010
anderson55895
Jerry
SOURCE: Replacement beaters for hand mixer
Hi, replacement beaters can be found easily on amazon, click here and take a look: Amazon com hand mixer beaters. Wish you best of luck.
Jerry
Posted on Jan 07, 2015
Can I get parts hot kitchen aid hand mixer model khm7twh beater won’t stay in because plastic tabs are broken that hold the beater in
Hello, Joe -
From a post on a YouTube video demonstrating a McGyver-type fix to a damaged beater ring (the plastic piece which holds a beater in place) apparently KitchenAid has discontinued the availability of the beather ring.
This is the link to the YouTube video with the McGyver-type repair demonstrated:
https://www.youtube.com/watch?v=CmS4FbROS50
The comment about the discontinued beater ring is from Dan Peters.
See the information here from KitchenAid:
http://producthelp.kitchenaid.com/Countertop_Appliances/Hand_Mixers/Hand_Mixer_Assembly_and_Operation/Beaters_fall_out
If you decide not to try the McGyver-type repair and choose to purchase a new hand mixer, you may wish to put the old mixer up for sale, to be used for repair parts (since it still has 1 good beater ring.) Or, you can send the old mixer to electronics recycling.
Best wishes.
Feb 27, 2018 | Food Mixers
Just replaced planetary and gears, flat beater still heating bowl. is planetary to be loose or fit tight against mixer head?
The beater cannot "heat" the bowl, so I am going to assume that is a typing error, and you meant hitting.
If the beater hits the bowl it is usually caused by the adjusting screw at rear of the column being improperly set. To correct this you need to turn the adjusting screw slightly to right, or left to adjust clearance. Clearance should be 1/16", about the thickness of a dime.
If this does not fix the problem, and the beater still rubs the bottom of the bowl, it can be corrected by tapping the yoke arm with a mallet, there should be 1/16" clearance between bottom of bowl and end of the beater.
You can determine the 1/16" by dropping a dime in the bowl, the flat beater should just "touch" the coin as the beater rotates.
If you have questions feel free to call us @ the Mending Shed.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Apr 30, 2013 | KitchenAid KP2671 Professional 6 Series...
The mixing section has a gap in between
Do you mean the beater is not touching the bottom of the bowl? AS in there is a gap between the beater and the bottom of the bowl so it is not mixing all the ingriedients?
If you have a Tilt-head style mixer, you can adjust the beater/bowl clearance by turning out the adjusting screw. Place your bowl on the bowl screw cap, Place the flat beater on the agitator shaft and lower the head of the mixer so the beater is at the bottom of the bowl. There should be a 1/16" clearance between the bowl and the beater, if the beater is too close to the bowl turn in the adjusting screw, and if the beater is too far away turn out the adjusting screw. The adjusting screw can be located by tilting the head of the mixer back, and in the neck of the mixer you will see a flat head adjusting screw.
However if you have a bowl lift mixer and the bowl is too far from the mixer there are a few different way to fix that problem. If the bowl and beater are too far apart start by adjusting the adjustment screw. On this mixer the adjustment screw is under the head. Remove the bowl, and beater and lay the mixer on its back. You should be able to see under the head a screw sticking out, it does not have a head, but a little slot in the screw, use a flat head screw and adjust the beat 1/4 turn. Put the beater and bowl back on and test mixer to see if it the beater has a 1/16" clearance. If it doesn't adjust the screw and 1/4 turn. If after adjusting the screw the beater and bowl still have too much clearance use a mallet and tap both sides of the yoke arm up evenly until 1/16" beater to bowl clearance is met.
You can use the same dime test in the bowl to make sure you have the correct 1/16" measurement for the beater/bowl distance.
Thank you,
Colleen
MendingShed.com
800-339-9297
Apr 30, 2013 | KitchenAid Food Mixers
Kitchen aid khm3wh beaters will not stay in mixer
I fixed mine (my wife's). Kitchenaid 3-Speed Hand Mixer KHM3WH. Here's how I did it.
This is a pretty old mixer. My wife bought it at a thrift store for $1. She brought it home, we found the beaters and whisk beaters on eBay. Paid $34.00 for both sets of beaters, but when we received them we found they would not stay in the mixer. Oh we also bought the alternative/replacement beaters from Sears, parts online. I don't think those will work with my fix. However with some $0.92 rubber washers from Lowe's and a heavy duty paperclip I fixed the mixer, and it works flawlessly. Maybe some stainless steel wire would be a better, more permanent fix.
Apr 30, 2012 | KitchenAid KHM3 Classic Hand Mixer
The top part of my mixer is sitting about 1/4 inch lower than it should. It's placing the beater too low in the bowl and therefore won't mix. (I tried to whip up some whipping cream but it pushes...
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download the following Kitchenaid Service Manual:
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It covers several models including yours.
1. Check/Adjust the Flat Beater to Bowl Clearance:
Turn screw (A) SLIGHTLY counter clockwise (left) to raise the flat
beater or clockwise (right) to lower the flat beater
2. Check the Beater Shaft (Agitator Shaft) making sure the Retaining ring
is flushed with the surface of the Planetary Assembly
Constant Pulling and Removal of the beaters can cause the Agitator shaft to move
3. If the above two still don't solve your problem, follow the service manual
directions to disassemble the Planetary Assembly and check for loose screws
Jul 04, 2011 | KitchenAid KSM150PS Artisan Series Stand...
The mixer turn table won't turn? Its only a year old?
Don't know a solution, because I am having the same damn problem.
I am very discouraged with this product.
It is a piece of ****.
I am thinking about taking it out back and shooting it with my 270 I bought.
That is the only solution I know.
Dec 03, 2010 | Sunbeam Heritage 2346 Stand Mixer
I have a Sunbeam Mixmaster from mthe 1970s,
If this mixer sits on a stand, first remove it from the stand. Turn it upside down and shine a flashlight into the right side socket to look for obstructions. When you say you swivel the head, do you mean you rotate the handle? This is how to eject the beaters after use. It may be that the ejector on the right side is stuck. If so, you will need someone with mechanical skills to disassemble & repair.
May 23, 2017 | Sunbeam 2366 MixMaster Series Hand/Stand...
Mixing blade gets hung up at same spot on each turn
Hi SUSAN. From the symptoms you describe, it sounds like your mixer has a ‘Bowl to Beater Clearance’ issue. That should be pretty simple to fix. But even before we go there, check to make sure your mixing bowl is seating properly in the Bowl Support yolk and ‘snaps’ into place against the Bowl Spring Latch. My wife’s had that happen to her a few times. She thought the bowl was seated tightly, but it wasn’t and she experienced the same problem as you.
If your bowl is seating properly, the next thing to look at is your Beater to Bowl Clearance. The instructions are located in your Owners Instructions manual that came with your mixer. If your lacking one, you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KT2651 )and select the last file listed that appear under Owners Manuals (44): KT2651XWW3.pdf (2974.69 KB) and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 10 and you will find the instructions for adjusting the mixer head height.
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Your Stand Mixer is adjusted at the factory so the flat beater just clears the bottom of the bowl. If, for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, you can correct the clearance easily.
1. Unplug Stand Mixer.
2. Place bowl lift handle in down position.
3. Attach flat beater.
4. Adjust so flat beater just clears bottom surface of bowl when in lifted position by turning screw (A) clockwise to raise the bowl and counterclockwise to lower the bowl. Just a slight turn is all that is required: the screw will not rotate more than 14 turn (90 degrees) in either direction. (The full range of adjustment is 12 turn, or 180 degrees.)
5. Place bowl lift handle in up position to check clearance.
6. Repeat steps 4 and 5 if necessary.
NOTE: When properly adjusted, the flat beater will not strike on the bottom or side of the bowl. If the flat beater or the wire whip is so close that it strikes the bottom of the bowl, coating may wear off the beater or wires on whip may wear.
Dec 19, 2009 | KitchenAid KT2651X Epicurean Stand Mixer
Can't move the lever to start the machine - it's frozen on off position.
Unplug first. Mixers can detach from the bowl base. You may have a lockout either in the latch mechanism or in the beaters. Try removing the mixer head from the base and the beaters from their sockets. Then plug in and try switch. If not working, unplug and attach beaters. Replug and try. Then attach to base and try again.
Make sure speed control does not have safety feature requiring to press in before turning control.
Good Luck.
Jul 09, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid Hand Mixer Beater won't stay in slot
You need a new gear set.  Hard to find however.
Jan 07, 2007 | KitchenAid KHM3 Classic Hand Mixer
Food Mixers Logo
139 people viewed this question
Top Food Mixers Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
john h
Are you a Food Mixer Expert? Answer questions, earn points and help others
