Question about Sony Photography
Hi i'm Sujith i have sony vct100 tripod head. i need to find tripod legs for it. but i don't know how to find ball size of this head
    Top Expert:
  • Sony Master
  • 30,497 Answers
$25 complete
https://www.ebay.com/p/99398998
It's not a very good tripod in my opinion. Any that rely on a ball joint are not going to be firm.
https://www.walmart.com/ip/Sony-VCT-R100-Lightweight-Tripod/4948189
It is a VCT100 not a VCT1000. It is a 'tripod', not a 'tripode'. I changed it. If you can spell it, you can Google it :>)
Posted on Oct 21, 2019
6ya staff
SOURCE:
Anonymous
  • 23 Answers
SOURCE: One Leg has loss it's grip.
take it apart, there is a rubber ring like a belt or rubber band, either broken or missing. you will have to find a relacement for that, may have to take apart another leg to have one to compare, course I don't honestly know where you will find that piece. too take it apart just keep spinning the lock counterclockwise until it comes off. good luck.
Posted on Jun 07, 2007
Anonymous
SOURCE: Manfrotto Tripod Ball-grip Head 322RC2
If you look on the ring that goes around the ball, on the side by the red tension gauge, you'll see an indentation. It is just barely visible on the product shot above.
In the hole, you'll find what looks like an odd shaped bolt. It is actually a threaded post inside a nut.
Use an Allen wrench (hex key) to tighten this post.
Be careful though, a little tension here goes a long way. You should probably turn it no more than 1/8 to 1/4 turn and then test it. If it still isn't tight enough, repeat until you are satisfied.
You should probably also talk to a trained technician at somepoint to see if the loosening is indicative of a larger problem. I really wouldn't know one way or the other. I just discovered the calibration post by taking mine apart.
Posted on Nov 25, 2007
voodoomox
marlon john madrid
  • 1689 Answers
SOURCE: Manfrotto 322rc2 tripod ball head
here is manfrotto's "How To" site, they have illustrated how to use almost all of their products.
http://www.manfrotto.com/Jahia/site/manfrotto/cache/offonce/pid/2475
hope this helps out. if you have other questions please lemme know
Posted on Nov 04, 2008
Anonymous
  • 24 Answers
SOURCE: Breakdown Manfrotto 3265 ball head from 190xb tripod
IT SOME TIMES TAKES A LOT OF EFFORT TO SEPARTE THE HEAD FROM THE TRIPOD. MAKE SURE YOU REMOVE THE 3 LITTLE SCREWS FROM BELOW THE HEAD, AND MAKE SURE THE TRIPOD AND HEAD ARE NOT COLD. IF THEYA RE WARM THEY WILL SEPARATE EASIER.
Posted on Jan 30, 2009
Anonymous
SOURCE: How to Unscrew SLIK tripod head from the rest of tripod?
Below the tripod head you will see what looks like a "sandwich" of two chromed pieces of metal.  The lower one is the top of the tripod's center column.  The upper one is the bottom of the tripod head. Using wrenches or other tools, unscrew the upper one counterclockwise to separate it from the lower one. There is a 1/4" threaded stud which holds them together.
If you plan on replacing the head with a pro head like a Manfrotto, you will need a reducing bushing.  Most heads expect a 3/8" stud, and this tripod's thread is a standard 1/4" stud. The adapters are available through Wolf, Adorama, B&H, and the like.
Posted on Mar 02, 2009
How to remove and change SONY VCT-60AV Remove Control Tripod FLUID HEAD
Most tripod heads are held on to the legs with 1/4" re 3/8" thread bolt - just grasp the legs firmly in one hand, the head in the other and rotate the head anti-clockwise.
Jul 25, 2017 | Sony Photography
Head won't secure to tripod
Two potential issues. 1. Perhaps you have just not screwed it on tight enough. Just tighten the black knob as much as you can then screw the head on your legs as tight as you can. 2. If you can't even do that I will assume that the hole on the bottom of the head is too large for the screw on the tripod legs, in which case you just need a a bushing adapter. Like this one:
http://www.bhphotovideo.com/c/product/882988-REG/Sunwayfoto_tn_15_Bushing_3_8_1_4_Stainless_Steel.html
Apr 10, 2014 | Gitzo Gh2750qr Series 2 Magnesium Off...
How can I mount rc498c4 on my bogen 3001 tripod legs
Go to http://www.bogentripodparts.com/repairs.htm and the top right video shows how to remove and replace the head.
Mar 28, 2013 | Bogen Manfrotto 498rc4 Midi Ball Head W/rc...
Slight dent in one leg near base plate,how does the top section come away from base plate for possible repair,leg will not close all the way.
Check out : www.bogentripodparts.com. While I am not that familiar with that model, there are parts available)not sure which ones_ and ther is a video on tripod repair, albeit a different model.
Apr 24, 2011 | Manfrotto (Distributed by Bogen) 055XDB...
I am looking for advice on how to mount a Ball Head on the plate of a regular tripod, So far I have not found a Ball Head that has the same size thread in the bottom. Is an adapter available as a solution....
The bottom threads on most tripod heafs are 3/8", but some are 1/4"/ The mounting screws on MOST tripods are 3/8", but I have seen `/4" (especially on monopods. IF:
tripod=3/8 head = 1/4 need mounting plate 3/8 female to 1/4 male
tripod = 1/4 head - 1/4 nothing
tripod 3/8 head 3/8 nothing'
tripod 1/4 head = 3/8 there is an adapter/reducer that screws into the 3/8
' female and reduces that to 1/4"
Feb 20, 2011 | Photography
I can't get the ball head off my tripod. I've loosened the set screws at the base, but the head won't budge.
You can try this:
spray lubricant between ball head and base, wrap the ball head with a heavy rag( to help prevent scratches, use a pip wrench on ball head while someone else holds legs ( or also wrap legs in cloth and hold in vise). DO THIS AT OWN RISK
Dec 04, 2010 | Manfrotto (Distributed by Bogen) 055XB...
Tripod head
If the head is loose on the tripod follow these instructions:
There are three small set screw (grub screws) that are under the head, net to the center column. You will have to raise the center column and look under the head. These are slotted screw heads and a small to medium screwdriver should work. You don ot have to remove the grub screws completely, but you should back them out at least half way. The head will unscrew off the center column. The gray part below the head is half the head attachment and half the center column end plate so it should separate in the middle line between the two.
If screws came out elsewhere, we will need to know the model number of the head that came apart.
Jun 01, 2010 | Manfrotto (Distributed by Bogen) 055XDB...
The rubbers that go round the locking part of a gitzo tripod leg, 3 on each leg
Try the us distributor for that part
Bogen Imaging Company
ATTN: Service Dept.
565 East Crescent Ave,
Ramsey, NJ 07446
201-818-9500
Jul 23, 2009 | Gitzo Magnesium Center Ball Head for...
Photography Logo
56 people viewed this question
Top Sony Photography Experts
ChinthakaJ
ChinthakaJ
Andrew Taylor
Andrew Taylor
blackcamo
blackcamo
Level 1 Expert
Are you a Sony Photography Expert? Answer questions, earn points and help others
