Question about Refrigerators
Child lock will not turn off when i tap on it
Child lock and alarm icon will not go off when I tap on them,so water and ice will not dispense
Posted by Lynn Bibby on
Steve Novak
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 149 Answers
The button has to be held down for 5 seconds.
Posted on Oct 05, 2020
5 Related Answers
Anonymous
  • 625 Answers
SOURCE: Water dispenser
the slide switch ice - water may not be making up. the paddle inside the door operates a common microswitch to either dispense ice or operates the water solenoid. check out the selector switch.
Posted on Aug 22, 2007
Collegeboy
  • 6 Answers
SOURCE: water dispenser dripping
HVACRH20, are you any good with GE water dispensers dripping? Let me know, I have a lot of info to provide and maybe you can help answer my problem?
Posted on Apr 02, 2008
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Posted on Apr 05, 2008
Anonymous
SOURCE: Ice and water dispenser lock
I resolved the problem on my Kenmore Elite model 106.55616400 by removing the drip tray, taking out two screws that hold the panel, and disconnecting and reconnecting the wires from the panel to the board. Unplugging the refrigerator did not work.
Posted on Aug 06, 2008
  • 6186 Answers
SOURCE: Red lock light is on below ice and water
Does this model have a light button? (I know the 685 and the 695 do.) If it does, press and hold the Light button until all the LEDs light up once. This takes about 5 seconds. (Repeating the process will reenable the lock.)
I hope this helps.
Posted on Oct 13, 2010
How do you lock the ice dis spencer
Hello Simon;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number so I do not know what unit you have.
No matter; Either you do not have a lock on your dispensers or you have a child lock out on the dispenser key pad. This lock will lock out both the water and ice dispense.
Mar 07, 2015 | Refrigerators
No water and ice dispensing
most dispensers have a hidden lock button that may be set the lock button is a child safety feature,despite that could be the door switch since they wont dispense with the door open or perhaps could be the switch on the dispenser cradle
Jul 18, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I replaced my water filter as soon as the icon began to turn red. the icon did not return to it's original color, and, over the last month, it has turned completely red. is there a problem?
Yes, you need to reset the filter alarm. Try holding in the "ice type" and "child lock" buttons at the same time, and hold until you hear the chimes (about 2 seconds). That should do it.
Best regards, --W/D--
Jan 29, 2011 | Samsung Refrigerators
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
Ice dispenser/water dispenser in side by side fridge not working
Your dispenser is child locked. Hold the child lock button for 4 seconds and the key should disappear, if you do not know which key to press I will need the model number from the tag located on inside of the fresh food section top right corner.
Apr 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
