Question about Light Office Equipment & Supplies
My printer have ink an d is printing very light colours
6ya staff
SOURCE:
Mergatroid
  • 286 Answers
SOURCE: printing
Likely your purge unit needs cleaning...
Make sure by printing out a test page from printer (not from computer).
If test page is good, you have a software issue. If test page is bad, you need to clean your head and/or purge unit.
Posted on Dec 30, 2007
jyvibar
joey vibar
  • 148 Answers
SOURCE: sharp AJ1800 printer - won't print colour
the color cartrige is defective. replace only with original cartriges
Posted on Mar 23, 2008
Silverblade
Aris C.
  • 173 Answers
SOURCE: Black ink not printing and colour ink very faded
Check the ink status of the printer's cartridge.
Posted on Oct 14, 2008
Anonymous
  • 163 Answers
SOURCE: epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Posted on Apr 02, 2009
Anonymous
SOURCE: Using colour ink without black ink in Epson CX5500
this cannot be resolved, Epson software is useless it will force you to buy an INK
Posted on Jul 13, 2009
Ink is faint
two possiblities
1)not enough ink for the saturation of the media
2) media is not correctly saturated by the ink
sounds like the same issue- let me explain
your image may be purposely printed light because of 'ink save printing'( driver cuts down reqired ink levels to give a draft print.)
or your problem may lie with the paper type itself,
firstly have the machine print off its internal demo page ( read user manual to find how to print)
this print being held by the printer cannot be affected by external controllers, if the demo page looks nice aand even and strong in colour then your issue is software related and you should have a look at how the pc is handling these documents before they get to the printer.
if the demo image is light then you have a problem inside the printer
if it is the latter please re-post as internal demo page printing light in colour
Mar 16, 2014 | HP Officejet 4622 Multifunction Inkjet...
Yellow is printing dark muddy colour, tank content same colour.
Has the printer printed a good yellow using this ink tank at all?
Dec 12, 2013 | Brother Office Equipment & Supplies
The printer in out of colour ink, and still wont print in black and white
Replace the colour ink. Some printers mix-in a bit of coloured ink, when printing "black", in order to prevent the colour-inks from drying-out.
Feb 17, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer is printing the black color as light grey. Toner is already exchanged.
When you print something from a website and the print box comes up, click on preferences tab, and when it comes up click on color . Then click on print in grayscale and change the setting from High Quality to Black ink only, click apply at the bottom, then OK. It should print in black ink.
Jan 11, 2011 | Laser Phaser 6125 Colour XEROX Phaser...
I want to print in white ink on black paper. I have a Canon MX310 printer
Inkjet printer inks are dye-based, and that's the reason.
Perhaps this will help explain things. You know those little boxes of food colouring you can buy in the supermarket - the ones that have four little bottles of colour - red, blue, yellow and green. Within reason you can combine these to turn white icing into most colours. Use nothing and the icing is still white or use everything and the icing will go a black-brown colour. Use a couple of drops of red and blue and you'll get purple.
But if you start with black icing, there's nothing you can add that will make it anything but black.
It's the same with your inkjet printer - because white is obtained by not having any ink print on the white paper. But of course that only works when the paper is white. Naturally you'll get different results on all colours of paper, decreasing as the paper gets darker in colour. Print blue on yellow paper and you should get green printing.
The only way to print in white is to do what commercial printers do - use opaque inks and include a white ink in the process. And as far as I know there's no commercial ink that will do that with an inkjet printer.
I can hear lots of you muttering "Rubbish. Of course you can print light colours on dark paper." Well all I can say is, have fun experimenting, but you won't be able to do it.
About the only way to achieve the sort of result you may be after is to print the job then trim it and paste it in place. For instance, if you want to print onto a black or dark-coloured T-shirt then print onto white transfer material, trim the print to size and iron it in place.
Dec 29, 2010 | Office Equipment & Supplies
Printer will not print in black. Colour ink appears to be out. Should this effect it
Yes for sure If your colour ink is down there is the possibility that the print may vary in colour.As the colour ink level decreases you might have got the error to change the ink. Hence it will tend to change the printing commands. To further confirm on this you can disconnect printer, uninstall and reinstall the printer software,then connect the printer for hardware detection and installation. now do a head cleaning maintenance and a test printing. If there is still no change it will be better to replace the colour cartridge after using the menu for ink cartridge changing so as to get the ink indication correct after installation. Hope you try this out. Good day
Aug 13, 2010 | Epson Stylus C46 InkJet Printer
Epson sx200 One of the colour inks is empty and no print in black
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
PRINTER NOT PRINTING
for printing both colour and black ink must be present, how is the light blinking tell me
Sep 29, 2008 | Epson Stylus Color 640 InkJet Printer
I have just put in both black and colour refills into my printer which is a Pixma MP150, it it printing both black and colour ok, however my Black Ink light still keeps flashing on and off, the coloured...
I think you printer cartridge as sensor which ink levels as it is failed in the black cartridge ,you can either clean the contacts the printer and cart with dry tissue paper and replace and set printer installing new cart or use it like this because the printer company doe not support refilled cartridges to be used .
Apr 09, 2008 | Lexmark X1240 All-In-One InkJet Printer
Printer not printing
Unfortunately, like most multi cartridge ink jet printers when one ink is empty the printer will cease printing regardless of whether you just want to print in black and white and you have plenty of black ink left. I have heard of people tricking the printer into believing the cartridge is full by placing coloured tape etc in front of the ink sensing device but I am not sure how the Brother senses the ink levels as i have some aftermarket ink cartridges for mine which seem to be completely non-opaque (unlike the originals). The need to have colour cartridges in even if you only ever print with black ink is good news for Brother as the MFC-210c uses a large amount of ink during it's routine cleaning cycles (that you cant stop) and will empty all 3 cartridges in under 6 months without ever printer a single drop of colour ink. Sorry about all the bad news, at least your not alone......
Dec 28, 2006 | Brother MFC 210C All-In-One InkJet Printer
Top Light Office Equipment & Supplies Experts
Marvin
Marvin
Copy-Tech
Level 1 Expert
Are you a Light Office Equipment and Supply Expert? Answer questions, earn points and help others
