PlateMaker 4 driver for Mac 10.12.6 - Office Equipment & Supplies
Posted by Barbara Wright on
2 Related Answers
Rico Soriano
  • 33 Answers
SOURCE: Is there a driver for
Platemaker 3 supports Mac 8.x-10.4. Check out their support site from the link below:
http://www.xante.com/support/pm3/
Posted on May 23, 2011
webster1280
webster1280
  • 5 Answers
SOURCE: Image enlarging when plating!
Try outputting a pdf of your document. Set up your page from the printer window and print from Acrobat Reader. Also check your network connection if you are on ethernet. AppleTalk work much better in mac osx tiger vintage mini mac. I have not tested all the printer drivers yet on the new mini mac Lion. But there is less of a compatibility issue if you convert your doc to a pdf file. Hope this helps. :-}
Posted on Jan 29, 2012
Cover open?
Dear its your Platemaker 4 front cover open massage i think please check its right behind the front panel,its not easy to check it first removed the panel cover side cover after that formatter board,fuser assembly you can observe that its communicate with gears,found in main engine there is small lever who controlled front cover,hope you understand.
thanks.
May 13, 2014 | Xante PLATEMAKER 4 Laser Printer
Am tryng to change the front brake pads from a 2003 town and country limited, but i need to know wich size of hex wrench do i need
Metric Size --- 10,12 what ever it takes
All vehicles from 1980 on ,use mostly Metric
Wrenches,Sockets & Torx drivers
Jul 19, 2011 | Chrysler Town and Country Cars & Trucks
Is there a driver for platemaker 3 that works with Mac 10.6.4?
May 23, 2011 | Computers & Internet
hi pip,
check your mac properties, if it is a PC powerchip, you may have to enable "Rosetta" in the indesign applications properties folder.
this may resolve the file print size conversion process.
Rosetta is inbuilt in mac with this type of powerchip, and when activated, works in the background..
http://www.apple.com/rosetta/ this link will give u an insight
not sure this is your answer....cheers rooboy
Dec 08, 2008 | Xante PLATEMAKER 4 Laser Printer
Image quality
Not my area of expertise,but maybe a change
in ink cartridge or material is in order
May 17, 2008 | Xante PLATEMAKER 4 Laser Printer
Sending a plate from word
Not familiar with the printer or if you are using
Windows or Mac but there should be a page setup
tab to set oriientation for Portrait or Landscape
Margins etc
Nov 16, 2007 | Xante PLATEMAKER 4 Laser Printer
Marvin
Marvin
