Question about Freezers
Where can I buy a replacement lid seal for a Skandiluxe CF309 chest freezer?
Posted by q1007246 on
3 Related Answers
larryyb
Larry Youngblood
  • 291 Answers
SOURCE: chest freezer ices up quicker than it should
if the box has mold between the seal and liner the the seal isn't the main problem, the main problem is the liner is bad and by time you got both parts if you can it would cost more than to replace the freezer.
Larry
Posted on Nov 25, 2008
geoff hunter
  • 4793 Answers
SOURCE: we have a skandiluxe chest freezer and frost keeps
check to make sure the seal fits flat, if not use a hot cloth to shape it..
Posted on Aug 13, 2010
Kami
  • 307 Answers
SOURCE: Chest freezer lid sticks in closed position
I would assume that the sticking is not the usual vacuum lock experienced if the freezer has been opened within the last few minutes. In that case, you could either wait a few minutes more, or press down firmly on the lid before opening.
Posted on Oct 16, 2018
I have a Skandiluxe CF 136 chest freezer & the orange (fast freeze) light is on all the time.
The compressor won't burn out just because it's running all the time. The plastic fascia pops out easily from behind(take the little panel off on the side) Set the thermostat to the middle of its range and switch the fast freeze off.
Oct 08, 2015 | Freezers
Why is my Skandiluxe chest freezer's red light on
Red light usually means the interior temperature is too warm.
Jun 26, 2014 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
Ice on the inside walls of chest freezer
Check the seal around the lid sits firmly on the rim, give it a good defrost before restocking. Make sure all else is working and clean, particularly any condenser grilles / fans.
Mar 23, 2014 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Skandiluxe freezer seals
Hi
Most freezer lights are screw on bulbs. Unscrew the bulb unticlockwise and replace with a new one.
Feb 15, 2014 | Freezers
Chest freezer ice is filling up around the top of the inner lid
Turn it off, remove the stock, tap the sides with a block of wood and scrape to the bottom of the freezer with a dustpan and scoop it out. Refit the stock and switch back on. Takes 10 minutes. Check the lid seals properly once defrosted and check it's not accidentally in superfreeze mode.
Jul 03, 2012 | Kenmore 5 cu. ft. / 142 liter Chest...
Condensation forms around the freezer opening, between the rim and the seal.
The lid is warped or the seal is bad and leaking air.
Determine which it is and replace the seal or the lid.
Jun 27, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
Alarm light on
there is some problem of your engine you need to call freezer technician to check up the problem.
Apr 02, 2010 | Bosch 8.72 cu. ft. / 247 liter Chest...
Chest freezer ices up quicker than it should
Larry
Nov 25, 2008 | GE 5 cu. ft. / 142 liter Chest Freezer...
Kenmore 12 Chest Freezer - Needs New Lid
searspartsdirect.com
All you need is the model number
It gives you a list of all parts you can buy to replace what's broken, as for the frost try placing a sheet of plastic over the insulation, under the the plastic cover to keep moisture and humidity out of the insulation.
Apr 25, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezers Logo
159 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
