Question about Celestron Optics
I use the celestron hand controller as instructed--press menu -then press focuser--does not show focuser-why
Posted by bob bezeau on
2 Related Answers
SOURCE: Celestron Nexstar 114gt telescope,hand controller lights up only
Do you have a fresh set of batteries in the scope? Better to use an outside 12 volt power pack with the Celestron 12 volt "cigarette" lighter cable.
This can be three things:
Low power
Bad cable from hand controller to scope.
Or a broken hand controller
Try fresh batteries first.
Posted on Dec 31, 2009
Wallwart
Steve Duffy
SOURCE: Celestron CPC 800 frozen display in the Hand Controller
The power cable is the problem. The connector is loose fitting, and the cable is long and high resistance. Combined, these two things result in a significant voltage drop when slewing both motors. Replace the power cable with bigger wire, and tape the power plug down in the socket so it can't move. The other suggestion may help as well.
Posted on Jul 16, 2010
Celestron NexStar 8SE shows No Response 16 and No Response 17 errors repeatedly.
Reset the hand controller and reload the firmware. You will need a special cable available from Celestron to load the firmware. The software is available for free on the Celestron web site.
http://www.celestron.com/c3/home.php
www.telescopeman.org
www.telescopeman.info
www.telescopeman.us
Aug 01, 2011 | Celestron NexStar 8i (600 x 203mm)...
Looking for a replacement focuser for a Celestron NexStar 130 SLT.Would like it to be 1.25 with 2in capibilty with fine focus dial
Either contact Celestron directly-- or look here--
http://www.telescope.com/control/accessories/telescope-focusers
Feb 13, 2011 | Celestron NexStar 130 SLT (306 x 130mm)...
I bought a used nexstar 130 Gt. The hand controller lights up and will move the scope, but will not display any information . Can this be fixed or do I have to get a new one? Thanks Lenny
First do a RESET on the hand controller --- also the b. Some of these scopes have a brightest adjustment.===rightness and contrast may be set too high.
The problem will be navigating the menu tree without seeing anything-- the menu tree is shown in the manual try to get to the reset by "touch". or to the contrast by touch.
Contact Celestron here is you continue to have issues with this:
http://www.celestron.com/c3/page.php?PageID=37
Jan 21, 2011 | Celestron NexStar 130GT (306 x 130mm)...
Hi i just bought a acelestron nexstar 4 se telescope and when turning on the hand control it indicates transmit data and is stuck there , i can't set anything .
The hand controller is stuck in DOWNLOAD mode. Usually cycling the power off and then back on fixes this issue. Is the scope new? If it is take it back to the store and get a replacement (at least get a new hand controller).
The batteries are FRESH I would assume?
Here is Celestron's instructions for fixing these type of problems:
http://www.celestron.com/c3/support3/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=2003
Dec 18, 2010 | Celestron NexStar 4 SE Telescope
When I power on my Celestron CGE 1400 and i hit one of the directional buttons on the remote my telescope goes only in one direction like if one of the buttons is pressed all the time. Thank you.
You either have a bad hand controller or a bad hand controller cable. Try a new cable first. Also do a RESET on the hand controller and return it to the factory default.
If these do not fix the problem it must be returned to Celestron for repair.
Dec 08, 2010 | Celestron CGE-1400 Telescope
Entered three stars to for alignment. Display shows 1. Mintaka,
Just by selecting a new star. It will ask you if you want to replace a previous alignment star. You need to re-read the manual for the Celestron hand-controller.
This web site will also help you:
http://www.nexstarsite.com/
May 22, 2010 | Celestron NexStar 4 SE Telescope
I have the Nexstar 8. It will not auto align or manual....
First do a RESET on the hand controller and make sure TIME, DATE, and SITE, are correct.
If this does not work then RE-load the firmware in the hand controller. If that fails contact Celestron customer service.
May 15, 2010 | Celestron NexStar 102 SLT 102 mm (4.0)...
Low power
Dec 31, 2009 | Celestron Optics
Setting the star coordinates on a celestron Astromaster EQ mount
You need to put more information into your question. There are several different Celestron EQ mounts with different hand controllers.
Go to www.cloudynights.com and post your question with the exact model information in the member forums.
Nov 06, 2009 | Celestron Optics
Optics Logo
143 people viewed this question
Top Celestron Optics Experts
Ekse
Lawrence Oravetz
Marvin
Marvin
Are you a Celestron Optic Expert? Answer questions, earn points and help others
