Bizhub 36 how can scan 8 image copy - Office Equipment & Supplies
Posted by Sajid ghori on
5 Related Answers
taminol
taminol
  • 62 Answers
SOURCE: Minolta Bizhub C353 fails scan to emails
Hi mmarsh1212,
When you say the bizhub fails Authorization, do you menat it fails Athentication?
If so, and I pressume your technician knows what he's doing, you have an issue with a password. I suggest you create an address for the bizhub on your email server and then re-setup the scanning to email credentials via the web browser direct to the machine.
Let me know if you need help with doing this.
Regards
Taminol
Posted on May 26, 2009
Darek Goral
  • 51 Answers
SOURCE: Konica bizhub C351 copier with BLACK area in center of the copy
u have to run the setup for machine if u like i can send u the step guide how to setup the machine
Posted on Aug 30, 2009
Testimonial: "Thank you Daroon for the setup guide you sent to us via email.We will try this tomorrow to see if this resolves the problem. Thanks again, Lee"
Aloke Das
  • 1833 Answers
SOURCE: Our Bizhub C353 is producing
You have a problem with your Bizhub C353.
# You must check that your printer toner cartridge is not dirty.
# Check your printer settings option.
# Which size of paper you use to print? It support up to A3 size paper.
The above may solve your problem.
Posted on Jan 03, 2011
goutam ghosh
SOURCE: Bizhub c300
microsoft wiondows xp professional version 2002 servicepack 3 software needed for model no M1005 LASERJET SCANNER PRINTER
Posted on Jul 03, 2013
SOURCE: konica minolta bizhub c300
Check the scanner lamp. It is possible the scanner is faulty. Try to replace with a known working lamp. If this doesn't work you might have to check the scanner board or the CCD lense.
Posted on Jul 09, 2013
How can I solve colour registration error in konica minolta Bizhub c 451 printer. Thank you, Uchenna.
run registration procedure in service mode. any p codes check the black image unit as is the reference for color registration
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 18, 2017 | Konica Minolta Bizhub C451 Copy-print-scan
My Konica bizhub c451 is showing p6p7p9p8 and it keeps sterbilizing without showing ready to copy pleas what do I do
Check the Transfer Belt assy,
Remove and Clean properly
Remove all Imaging Unit and shake properly and put it again.
P6/7/8/9 indicating all Imaging units are not in good condition.
So at warmup, color patch not getting properly generated
Dec 22, 2016 | Konica Minolta Bizhub C451 Copy-print-scan
Bizhub C652 has horizontal lines.
Print quality is good, b&w copy is good. When i make a color copy the machine makes blue lines or bink lines. This is a brand new c452.Scan to PC is ok, print its ok only copy. Lines are vertical.ea2265a7-6bf2-4ab0-abb0-94d103145c4c.jpeg
Feb 19, 2014 | Konica Minolta Bizhub C652 Color&b/w...
Marvin
Marvin
