Question about Car Audio & Video
I have an msd distributor 8360 3 wire orange red and black no gray wire , and would like to wire the tack just using a blaster coil how to wire
Posted by Gilles gauthier on
5 Related Answers
paul proctor
  • 4102 Answers
SOURCE: re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Posted on Apr 21, 2008
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: 1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Posted on Jan 17, 2009
Anonymous
  • 55 Answers
SOURCE: how to wire a vintage pioneer supertuner kp-500
THAT IS AN OLD RADIO....RED POWER .... HARD TO SAY ABOUT AMPS LOOK ON THE RADIO IT MAY SAY TOTAL AMPS....I WOULD SAY (APX 5 AMP) START WITH THAT .
BLACK .......YES GROUND FOR THE POWER ...AND ALSO FOR THE GROUND FOR THE 2 SPEAKERS
SO .....GRAY&BLACK SAY LEFT SPEAKER
AND....GREEN&BLACK SAY IS YOUR RIGHT SPEAKER IT EASY GOOD LUCK
Posted on Feb 21, 2009
Anonymous
  • 17 Answers
SOURCE: o2 sensor wiring diagram
A new 02 sensor will come with new wires and connector. If not get back with me I think there is a repair kit for that problem.
Posted on Jun 01, 2009
Anonymous
  • 6966 Answers
SOURCE: Pioneer Kp-500 wiring red black gray green Red
Hi and welcome to FixYa,
My compliments on the KP-500.
The black wire serves as common/return for the green/gray speaker wires. Yes, the black wire should also be grounded to the vehicle as it is the power ground and is tied to the chassis/body of the stereo.
Good luck and thank you for asking FixYa.
Posted on Oct 16, 2009
Need a wiring diagram on suzuki raiderj 110. Please. Tnx.
Maybe you can use these codes taken from:
http://www.motorcyclephilippines.com/forums/showthread.php?120554-Motorcycle-Electrical-Wiring-Diagram-Thread
This is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
ORANGE - from Ignition +ACC
BLACK/swhite - Ground
WHITE/sblue - to Ignition Coil
BLUE/syellow - to ENGINE Stator side
ENGINE - Stator Single Phase
WHITE/sred - To RECTIFIER
YELLOW/swhite - To RECTIFIER
BLUE/syellow - from CDI sensor
ENGINE - Transmission Gearbox
GREEN/sblue - 1st Gear
YELLOW/sblue - 2nd Gear
WHITE/syellow - 3rd Gear
RED/swhite - 4th Gear
BLUE - Neutral
ENGINE - Rear Side
PINK - Odometer Speed Sensor
ORANGE/sred -
ELECTRIC Start RELAY
YELLOW/sgreen - form Starter Switch
BREAK - Foot pedal
ORANGE - From ignition + ACC
WHITE/sblack - to Break light
BREAK - Hand Lever
ORANGE - from IGNITION + ACC
WHITE/sblack - To BREAK Light
FUEL Sensor
Yellow/sblack - to Console
REAR - Lights
WHITE/sblack - form BREAK foot/hand
GRAY - From Night Switch
BLACK - from Left Turnsignal
LIMEGREEN - from Right TurnSignal
Signal Flasher Relay
ORANGE - from Ignition + ACC
LIGHTBLUE - Signal SW
RECTIFIER
WHITE/sred - From STATOR
YELLOW/swhite - From STATOR
RED/sorange - BATT+/HEAD LIGHT
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
GREEN - from HORN Switch
ORANGE - Ignition + ACC
NIGHT Switch
RED/sorange - From Rectifier
GRAY - To REAR LIGHT/HEADLIGHTThis is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
Looking for the speaker colors for a 2001 Jeep Grand Cherokee
Item Wire Color Polarity Wire Location
12V red & pink/black + ignition harness
STARTER yellow + ignition harness
IGNITION dk. blue + ignition harness
ACCESSORY red/black + ignition harness
SECOND ACCESSORY none
TACHOMETER *6 *6
POWER LOCK orn/blk - orn/pur *7 5wi door lock switches *1
POWER UNLOCK pnk/blk - pnk/pur *7 5wi door lock switches *1
PARKING LIGHTS + use (-) lights
PARKING LIGHTS - dk. blue/pink *2 steering column
DOOR TRIGGER *4 - *4
HEADLIGHTS yellow *3 at the headlight switch
WIPERS dk. green/red - steering column
LF WINDOW UP/DN lt. blue - white A drivers door lock switch
RF WINDOW UP/DN brown - purple A passengers door lock switch
LR WINDOW UP/DN dk. blue - red/wht B drivers kick panel
RR WINDOW UP/DN gray - dk. green B passengers kick panel
TRUNK/HATCH PIN tan/black - BCM, above diagnostic plug
HOOD PIN none
TRUNK/HATCH RELEASE none
FACTORY ALARM ARM arms with lock *7
FACTORY ALARM DISARM lt. green/orange *7 - *5
HORN TRIGGER gray/orange - steering column
BRAKE WIRE white/tan + drivers kick panel
LOCK MOTOR orange/black drivers door lock switch
UNLOCK MOTOR pink/black drivers door lock switch
DISARM DEFEAT pink/purple passenger kick panel
DISARM NO UNLOCK none
DOME SUPERVISION yellow/dk. green *7 - BCM, above diagnostic plug
SPEED SENSE white/orange PCM, passenger side firewall
SUN ROOF OPEN/CLOSE none
SUN ROOF LIMIT none
LF SPEAKER grn/orn - brn/red at the radio
RF SPEAKER purple - blu/pnk at the radio
LR SPEAKER wht/grn - grn/wht at the radio
RR SPEAKER grn/wht - blu/orn at the radio
RADIO 12V red/white at the radio
RADIO GROUND black at the radio
RADIO SWITCH white/red at the radio
RADIO ILLUMINATE none
POWER ANTENNA none
Notes: NOTE: Jeep vehicles that use a gray ignition key have an immobilizer system that needs to be bypassed when remote starting. Use DEI part number 555C or 555U. *1 Use orange/black and pink/black at the drivers door lock switch to lock and unlock the drivers door. Use orange/purple and pink/purple at the passengers door lock switch to lock and unlock all of the other doors. *2 The dk. blue/pink will flash the hazard lights. They will flash even with a latch input to the wire. The parking lights can be activated by using a 1300 ohm resistor to ground on the yellow headlight wire. *3 Use a 330 ohm resistor to ground for headlight activation. Use 80 ohms to ground on the same wire to operate both the headlights and parking lights. *4 There are 4 separate door triggers wire, one for each door. Use all 4 wires and diode isolate each together. The drivers door is tan/red at the drivers door lock switch. The passenger door is tan/red at the passengers door lock switch. The drivers rear door is tan/orange and the passengers rear door is tan/yellow at the BCM. WHEN USING A 455J INTERFACE MODULE, IT IS NOT NECESSARY TO USE THE SEPARATE TRIGGER WIRES. USE THE YELLOW WIRE AT THE UNDERDASH LIGHT FOR DOOR TRIGGER. *5 Factory alarm disarm requires a 463 ohm resistor to ground on the lt.green/orange wire at the drivers door lock switch, you MUST use a relay. *6 The 4.7L motor has a separate coil for each cylinder. Go to any coil and use any wire that is NOT dk. green/orange. On the 4.0L motor use any of the tan/stripe wires at the coil pack, or go to one of the fuel injector and use the wire that is NOT dk. green/orange. *7 Can also use DEI part number 455J door lock interface control module. This will control door lock, unlock, arm, disarm, dome light supervision and more.
3helpful
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
Wiring schematics for a kenwood kdc-mp145 to a 1998 ford ranger
Battery light green to yellow
Accessory yellow/black red
ground black black
Illumination light blue.red orange/white
Power antenna amp=blue blue
LF + orange/light green white
LF - light blue/white white/black
RF + dark green/orange gray
RF - white/light green gray/black
LR + gray/light blue green
LR - tan/yellow green.black
RR + orange/red violet
RR - brown/pink violet/black
Theres no spark
A couple of initial checks using a voltmeter:
  • IGN + 12VDC on the red/white wires going to the ignition coils and the TCI;
  • pulsating voltage on the orange and gray wires coming from the TCI going to the ignition coils when starting;
  • ensure that the black wire is tied to the ground;
  • low pulsating voltage between orange & black and the gray & black coming from the pick-up cil connector going to the TCI when starting.
Postback results of tests.
Good luck and thank you for asking FixYa. Happy Holidays.
2helpful
Wiring diagram to hook-up remote starter on 1996 dodge caravan
Constant 12V+ Red or Pink/Black - Ignition Switch Harness
Starter Yellow - Ignition Switch Harness
Ignition Dark Blue - Ignition Switch Harness
Ignition 2 Black/White - Ignition Switch Harness
Ignition 3 Dark Green/Red - Ignition Switch Harness
Accessory Black/Orange - Ignition Switch Harness
Tach Gray Or Blue/Tan PCM Coil 2.4 Liter - Engine
Neutral Safety Wire Black/White - Power Control Module
Brake Switch White/Tan - Brake Switch
Trunk Pin Tan/Black - 40 Pin Connector at Fuse Panel
Parking Lights Light Green/White (-) - Head Light Switch Harness left of Column
Head Lamp Green/Orange - Light Switch
Factory Disarm White/Dark Green - (665 Ohm) left Connector bottom of Fuse Panel
Door Trigger Brown/White (-) - Lower right Gray Connector at Fuse Panel
Door Lock White/Dark Green - BCM at Fuse Panel
Door Unlock White/Dark Green - White Connector B58 Connector
Horn Wire Black/Red - Steering Column
Windows Up LF=Light Green, RF=Brown/White, LR=Blue, RR=Gray
Windows Down LF=White, RF=Purple/White, LR=Red/White, RR=Dark Green
Your R/S instructions should tell you what goes where.
Thanks for using FixYa - a FixYa rating is appreciated!!
Ford focus 1999
Pin --- Color --- Stripe --- Function
Harness 1
1 --- White --- Black --- Left front +
2 --- Gray --- Black --- Left front -
3 --- White --- Purple --- Left rear +
4 --- Gray --- White --- Left rear -
5 --- White --- Red --- Right front +
6 --- Gray --- Red --- Right front -
7 --- White --- (none) --- Right rear +
8 --- Gray --- (none) --- Right rear -
Harness 2
1 --- (not used)
2 --- Black --- Green --- Radio Ground
3 --- (not used)
4 --- Orange (thin) --- Black --- Radio Illumination
5 --- Green --- Yellow --- Radio switch
6 --- Black --- Yellow --- Radio Ground
7 --- Orange (thick) --- Black --- Radio 12V
Harness 3
1 --- White --- Green --- Speed sensor
2 --- (not used)
3 --- (not used)
4 --- (not used)
5 --- (not used)
6 --- (not used)
Msd distributer
What exactly are you trying to fix? I use the stock type 3-wire distributor in my 68 Mustang and use an MSD 6AL box with a Blaster II coil. What's your truck doing? Why are you going to replace the distributor? Need more info. in order to help you fix your problem. Shoot me an email [email protected]. I'd be more than happy to help you through your problem. I an owner/operator of an auto repair/hot rod shop. I specialize in Fords.
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
 Francisco Mauricio...
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
