Https://www.google.com allows a search for a manual.
The following search result appears to be it:
https://www.fire-parts.com/pages/manual/vermont-castings-radiance-2240-radiance_2240_install-pdf
SOURCE: MISSING MANUAL FOR GRILL VERMONT CASTING VM400XBN
Hi!
You can download the manual from the link---
http://safemanuals.com/user-guide-instructions-owner-manual/VERMONT%20CASTINGS/VM400-_E
When you open this link click on the download the complete user guide.
And, you will be able to download the complete user manual by clicking on it.
Thanks
Rylee
SOURCE: Vermont Casting Radiance Gas Stove (RUVSOD) NG to Propane (LP)
Unfortunaletly, due to the delicate nature of vent-free appliances, you'll find that most are not field convertable. If the vent free appliance were to lose its efficiency, you would be subjected to high levels of CO, carbon monoxide, and could likely die. Therefore, field conversion is not recommended and in this case, not possible. Vermont Castings does not provide parts to convert and if they did you would be essentially replacing the entire unit short of the outer cast shell. I wish you luck.
SOURCE: hi. i have a vermont
check to make sure your pilot orfice is not clogged it will be located at the end of the small tube coming from your gas control valve if its not then while you are trying to light the pilot tap the side of the gas valve (sometims somewhat hard) if it then lights you know you have a bad gas valve
SOURCE: I need an owners manual for RDV40 vermont castings
http://legacy.vermontcastings.com/catalog/elements/files/2008/20012697_Radiance_RADVT.pdf
SOURCE: I need a manual for a Vermont Castings VM600 BSP 5-Burner
http://legacy.vermontcastings.com/catalog/elements/files/VM400%20450%20600%20Users.pdf
