Question about Binatone Lands Phones
How do I turn off the backlight on my Binatone MD 6200 phone as it no longer turns itself off.
Have tried resetting phone and removing batteries.
Posted by Laura Cleave on
5 Related Answers
Anonymous
SOURCE: phone keeps reseting itself
mine did the same thing i called the blackberry warenty and they said that it had gotten wet some how... they said it could had been condisation from going from a cool room to outside where its hot. i mention that because i never got water on it. and there really isnt a way to fix it unless you buy a new one.
Posted on Jul 09, 2008
Anonymous
SOURCE: Evesham Nav-Cam 6200 turns on then sticks at the front page ( navigator, MP3 Photo, Setup) and won't go any further, tried hard and soft reset but nothing happens. can you help.
at the bottom of the unit there is a tiny little black button press this in with a pin or needle and it should reset itself
Posted on Jan 14, 2009
Anonymous
  • 11 Answers
SOURCE: Motorola ic502 turns itself off
bad battert
Posted on Feb 11, 2009
Anonymous
  • 464 Answers
SOURCE: LG Rumour takes longer to turn on everytime it is turned off
My name is Tim and I am collection Specialist with Verizon Wireless, I see a lot of phones with problems but not any like this. This phone has truly seen its better days. Take it to a store and have them replace it with a different LG Rumor phone. IF you don't have Total Equipment Protection on your plan, then you are still covered under warranty for the 1 year or 2 year depending on the manufacturer warranty. But if you have Total Equipment Protection then your warranty is good for the life of the contract and you DO NOT have to pay the 50 dollar deposit, replacement should be free. If the Verizon Store is closed by you then call Verizon from a landline phone or another cell phone and they can get one to you within 2 days using priority shipping. If you don't have Verizon, then contact your service provider and speak to their customer service team.
Posted on Apr 05, 2009
Anonymous
SOURCE: Click on the LG Dare display settings button and the phone resets
all you do is go into your security and settings and reset the phone. it will turn the phone on and back off again. but this should fix the problem and restore the ability to get into your display settings, as well as view your date and time.
Posted on Aug 01, 2009
Have loss my internet service . need to reset my phone
With the information provided, it is hard to help you. Try these:
* Remove the battery, wait for 1 minute, reinsert battery.
* Do a factory Reset. (varies depending on phone)
Feb 08, 2015 | Samsung Cell Phones
AT&T 5840 5.8GHz
try reseting the phone by unpluging it and also removeing the batterys. Il check the manual.
Aug 23, 2008 | AT&T 5840 5.8GHz...
My phone will not reset!
Try shutting phone off and removing battery & sim,replace them after about a minute.Replace turn on again and try to reset again.Or you can try manually removing contacts etc..remove sim battery replace turn on again and reset.Hope that solves the problem.
Jan 03, 2014 | Cell Phones
My motorola cell phonei580 rss- sim in session?? that all phone does, any thing I can do to fix this problem? thank mark
Try removing the simcard and the battery. Then replace both and check if the problem is fixed. If not, remove the simcard, replace back the battery then do a master reset. Press menu then scroll to Advanced, Connectivity, Master reset, Reset Defaults > Reset Settings or Reset Defaults. If it still won't work, try using a different simcard. Your simcard might be defective.
Sep 16, 2011 | Motorola Mobility i580 Cellular Phone
How do i fix freeze on sansung t819
Try to do a master reset on the phone if it works. Then make sure that you try to turn off the phone and remove the battery at the back for atleast 1-2mins and insert the battery back on the phone; try to do this atleast once a day (not including the master reset).
Sep 04, 2009 | Cell Phones
My phone has locked up!
SOFT RESET
1) Turn Off the Phone
2) Remove Battery
3) Remove Sim Card
4) Put battery and sim card again
5) Turn On the phone
6) Press Menu
7) Factory Data Reset (Remember that: This action will reset the phone to its initial factory state, erasing all data and wonloaded applications, so BACKUP BACKUP BACKUP first you try this).
Press "reset phone"
HARD RESET
1) Turn off the Phone
2) Press HOME + POWER KEYS (keep them holding for about 25 secs)
until you see a screen with a phone and a triangle.
then
3) SLIDE YOUR KEYBOARD TO OPEN IT
4) press ALT + l ( TO SHOW YOU OPTIONS)
5) Press ALT + W ( TO FORMAT ALL DATA)
Nov 30, 2008 | HTC G1
Reset buttom
Try doing a cold reset ( no data loss) disable the battery by sliding out and then back in, the battery pin at the back base of the phone without removing the battery PLS do not remove the battery!!!!.
If that dosen't work then you may need to remove the battery and do a default reset (you loose your phone settings) you should back up your data first before trying this.
Feb 21, 2008 | i-mate PDA2k Pocket PC
Flashing Display on Samsung i500
I have had the same problem... twice.  First time I held down some keys just trying desperately to get it to come back to life.  Well I hit the right combination for a hard reset.  So I lost all my data.
Second time I took my phone into the Sprint Store across from Sprint HQ in KC.  The only thing they knew to do was a hard reset. I'm suspicious since I was having trouble removing my battery the second time, that my battery's position may have caused some type of short.  Still searching. KC Ron
Jan 20, 2008 | Samsung SPH-i500 Handheld
I turned the phone on and I cannot do anything with it
TRY REMOVING THE BATTERY TRY AGAIN IF IT STILL FROZEN NORMALLY THEY PUT RESET BUTTON BEHIND THE BATTERY SMALL HOLE YOU PRESS IT TO RESET
Jan 17, 2008 | Motorola Mobility RAZR V3
Lands Phones Logo
121 people viewed this question
Top Binatone Lands Phones Experts
Marvin
Marvin
NOEL
NOEL
Ngoro
Are you a Binatone Lands Phone Expert? Answer questions, earn points and help others
