I get the sound feedback from the lexicon lambda on my cpu speakers but it just wont record on fl studio. that is the program i am using. i use an empty sound patch and it records and shows the keys that i am playing but it doesnt have any sound. and when i use a sound patch like a kick or snare or a piano sound it is only that one sound from the program. im trying to get the external sound to record on the program and i was told i dont need a microphone, which seems true seeing as how the sound extracts from the speakers.
SOURCE: lambda lexicon sound problems: is vista the cause?
I have had the same problems with the lambda driver ...they just posted a new installer on the lexicon website which fixed me up...try it.
SOURCE: Lexicon Lambda on Mac
Hi, I just bought one today and am using a condenser mic through the lamdba. I booted up apple logic - plugged in the device and it found it as a usb audio device. You need to use the headphone jack on the lamdba. good luck
SOURCE: Lexicon Lambda not detected
the usb could be the problem. when you plug it in does your comp make a noise if not it is the usb if it does than the drivers are not in sometimes its a program problem try going to start-mycomputer-(cd/dvd drive right click on it and click explore. find the file labled drivers and install them first than install the program hope this helps.
