Question about Bissell Vacuums
How do I replace the ready tools dial on a Bissell Pro Heat Pet?
Posted by Linda Samples on
5 Related Answers
advacak
Denny Adams
  • 125 Answers
SOURCE: I have the bissell pro
check the belt
Posted on Dec 03, 2008
sandham
  • 52 Answers
SOURCE: Bissell Pro Heat PET 2x
the element may need to be clean because when these units sit they lime up in the water way
Posted on Mar 03, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Bissell ready tool dial broken
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sghs
Posted on Sep 30, 2010
Anonymous
SOURCE: how do you get the smart mix dial to line back up
First, insert the black plastic control valve all the way into the hole. Make sure that the rounded face with the cut in it is facing toward the tall part of the chamber/hole where you inserted the valve. Try to line up the dial with where the threads would enter the cut in the valve. Hint: the hole in the center of the dial will go over the tall part of the chamber wall. Once you believe you have it aligned correctly, replace the plastic body cover and keep the dial out of the body cover. Just put in the screw on the side the dial is on, so if it is not aligned properly, you can remove the cover more quickly. Once you have the body screwed down, screw the dial into the hole and it should align easily with the valve in the hole. If not, remove the body cover, and try to realign the valve again. Repeat until you get the dial to screw in easliy.
I just did this today because I had to fix a customer's unit. It took me about 20 minutes or so to figure it out, but I finally got it. I was hoping your question had an answer to it when I got on here, but at least I got it figured out anyway. Hope this helps! That is if you still have this unit...
Posted on Nov 04, 2011
small6363
  • 18429 Answers
SOURCE: need an internal parts list for a bissell pro heat pet, model # 8910
click this link for parts list and diagram for bissell 8910
http://www.ereplacementparts.com/bissell-8910-proheat-clearview-powersteamer-carpet-cleaner-parts-c-129994_129995_130010.html
Posted on Aug 21, 2012
Have had a bissell carpet steam cleaner for YEARS! Loved it! Bought a new one Pet Pro Heat in May 2020. Used maybe 5 times! Getting ready for Holidays in November 2020 and it is smoking like crazy!
Try not leaving it plugged in for too long and clean it inside out then try again if that doesn't work than someone probably broke your vaccum.
I bought a bissell pro heat pet tried to use attachments there is no suction i am unable to use it because of this
Check the lever that closes the valve to switch the suction from floor to tools to make sure it's working properly.
How to replace belt on a bissell 66e1 pro heat lift off pet carpet cleaner
There are two belts on your model. Remove the screws on the end cap assembly on each side to remove the assembly to gain access to the belts. Remove the screws holding the brush roll assembly to remove and replace the belts.
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 • Vacuums
3helpful
Bissell pro heat will not extract water from the carpet
Try checking the top section of the machine (where the dial is located to switch it from floor to tool) and there is a little red plastic piece about 1 inch square on the inside of it. This is a lint filter that has a little door on it. Open the door or remove the entire thing to clean it out. It is probably completely blocked with hair, etc.. which is why you have no suction. Replace it after you clean it out and hopefully your problem will be solved!
I am not getting any water to come out of the floor part or tools
Hi There!
Here is a PDF link for a Bissell Service Center Repair Guide. Hope it helps! Juli ;)
newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
3helpful
heatman101
sghs
Vacuums Logo
Top Bissell Vacuums Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
