Question about Seagate Computers & Internet
Can you please provide more detail on the program you are downloading, the model of drive, and model of computer?
On the face of it, the program seems to be saying it is not compatible with the model of drive you have plugged in, or that the drive has been reformatted in a way that is not compatible.
Does the drive show up in the File Explorer / Finder of the machine?
after comment : ok, if you can drag and drop files onto it, then That means it is operational, and recognized by the system. The next question is why you can’t install the Seagate Desktop software. Where did you get the software from? Try going to Seagate Support and looking up your drive model, and doing a fresh download of the software they have for that model. Alternatively, there are other backup software packages available, Acronis, Aoemi, EaseUS, and others. You can find reliable downloads of utility software at downloads.com (CNET) or look for reviews from PcWorld or PCMagazine for their recommendations of the best paid and free backup software
Posted on Oct 20, 2019
SOURCE: Undetected Clicking External Hard Drive
Try another USB port. Reinstall if needed.
Posted on Nov 12, 2007
Check the drive letter assignment for the disks, and make sure it is not the C: driver.
I am assuming you can boot and then plug the disk, right?
So use the Disk Manager to check the driver letter, and change it if it is conflicting with another disk.
Jules
Posted on Apr 23, 2009
SOURCE: Connecting my Seagate 500GB USB drive reboots PC continuously.
update the firmware from seagate official,sir,any problem u can contact with me,thanks [email protected]
Posted on Apr 28, 2009
SOURCE: I cannot boot my PC
restart the system, while restarting , press delete/F8 to enter in BIOS menu, select boot priority and select the primary HDD as first boot device, deselct the "boot otehr device" option.
it should work fine.,
Cheers!
Posted on Sep 11, 2010
SOURCE: Cannot open files on EXT Hard Drive Seagate
You need data recovery help with your Seagate. This guy does it remotely and works off of donations. FreeDataRecovery.us
Posted on Jul 12, 2011
1. Check to make sure you have the MSXML Parser 6.0 installed:
If this is not found, visit Microsoft's website to install this component: http://www.microsoft.com/downloads/details.aspx?FamilyId=993c0bcf-3bcf-4009-be21-27e85e1857b1&displaylang=en
- Open Control Panel
- Open Add/Remove Programs / Programs & Features (Vista)
- Check box for "Show All Updates"
- Look for "MSXML Parser 6.0"
2. Make sure Microsoft .Net Framework 3.5 installation
- Look for "Microsoft .NET Framework 3.5".
If this is not found, visit Microsoft's website to install this component. 3. Try the steps listed here.
4. Remove the Seagate folder from C:\Documents and Settings\All Users\Application Data (XP) or C:\Program Data folders (Vista) and reboot.
5. Download and install the newest Windows Installer.
6. Download newest Seagate Manager from our Website and re-install a clean copy. Note: Do not do the update when the message pops up saying one is available.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
Acer Aspire X1420 and Seagate Desktop External Drive 1.5 TB 2.0 I have been just copying and pasting but now I want to backup on a regular basis at a set time
