Question about Uniden Cordless Phone
Can't answer call on cordless uniden 5.8 phones on charter
I can answer calls on wired phone the pick up cordless and it works fine. I can make calls from the cordless charter tells me its my phones. they worked fine when I had vonage. need advice before i go spend another $150 the phones are about a yearand a half old.
Posted by clemjunk on
Anonymous
    Problem Solver:
  • 5 Answers
Dont by uniden by goyutid
Posted on Sep 20, 2009
I have a Uniden cordless unit hooked in 4 lines. Incoming calls ring briefly for about 1 second and go out! You can talk if you pick up but not sure why no normal rings. There is no problem calling out....
When someone calls you and your phone behaves this way, does the caller get disconnected? The phone may be causing this, but it may also be due to trouble in the telephone line itself. The trouble is caused by defective wiring, a partial short circuit. When you pick up your phone to call out, the voltage on the phone line is low and it works normally. When you get an incoming call, a high voltage is sent to ring the phone. Because of the partial short, the phone company's equipment thinks you've answered the call as soon as the ringing starts. But you haven't picked up the phone, so the phone company's equipment thinks you've hung up and disconnects the call. The result is that short burst of ringing.
Disconnect the cordless phone base unit from the line and try another phone. If you still have the trouble this confirms the line is at fault. You'll need to contact your phone service provider for service. If it's in the outside wiring, they're responsible for repair. If the problem is in your home wiring, you may need to pay them unless you have a wiring maintenance plan.
If the problem goes away when the cordless base is disconnected, then it's time for a new phone.
Jul 16, 2011 | Uniden Cordless Phone
Answering machine is not answering the phone calls. Have ringer set for 4 rings but the machine never picks up. was working fine until our power was off one day
If your phone rings normally and your can make and receive calls, the line is OK, please check if answering option is on, typically a botton marked ANS or similar with an indicator or a display showing that it's on.
Mar 05, 2011 | Uniden DXA15588-2 Twin Cordless Phone
Uniden wall-mounted cordless phone unusable since DSL installed
This happened because there are too many phones sharing the same line with no power amplifiers.
Your phone line is self powered by a small current generated by the phone company (that's why old, wired phones don't need a separate power connection to ring or make calls, it's enough to just plug them in). Each phone you connect to the same line acts as a resistor and drains some of this current. Eventually not enough power is left to carry the signal.
The phone company technician can fix this by installing power amplifiers.
In any case, I would test this theory by unhooking all other phones and checking the cordless ones on their own.
If they work fine, call back the phone company and ask for a "real" repair person..
Jul 13, 2010 | Uniden Cordless Phone
I have a Uniden 5.8GHz DSS8955+1 and it's connected to my phone and fax. The problem is: everytime the fax rings, the answer machine works as it works when is a phone call. How do I set up the machine not...
Set your answering machine to pick up after four rings2.gif . This will give the fax machine enough time to take the call if it senses that it's an incoming fax. Setting the answering machine to pick up after four rings would give the fax machine enough time to accept the fax.
hope this was helpful .
Nov 13, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
How to refuse call and have answering machine pickup
dont answer.
your machine should have a setting that will allow you to set the number of rings before the answering machine picks up the phone. Default is often set at 3 or 5 rings.
look throughout your menu system for the setting.
Oct 04, 2009 | Uniden Cordless Phone
I was given an UNIDEN TRU9485-2 5.8 GHZ PHONE W/ ANSWERING MACH. After charging the individual units, the phones seem to work fine. The problem is getting the answering machine portion to work. I was able...
You can get a full manual with all the instructions for your UNIDEN phone HERE
I suggest downloading a copy and printing it out to keep with your phone.
You'll need it for all the pairing with the remote handsets too.
K
Jun 16, 2009 | Uniden TRU9485 5.8GHz Cordless Expandable...
NEED OWNER'S MANUAL FOR UNIDEN CORDLESS W/ A M MODEL #EXA7248
When answering machine picks up, message says "No one is available to take your call. Please call back." I cannot find "menu" on phone set for caller to leave message.
Mar 30, 2009 | Uniden Cordless Phone EXAI985
Other two phones do not work
This feature that you are experiencing is called exclusion. When you answer a call on one phone you cannot listen to the call on the other phones. Keeps ease droppers from listening. If you have the manual to the phone there will be a feature in there that will tell you how to turn it on and off
Dec 28, 2008 | Uniden Cordless Phone
UNIDEN CORDLESS PHONE 6.0
reset ur phone settings
Oct 28, 2008 | Uniden Cordless Phone
DXA18580 series
Increase the # of rings before the fax picks up so that it's greater than the # of rings before the answering machine picks up. When you're expecting a fax, turn off the answering machine.
Syskiyou
Jul 26, 2008 | Uniden Cordless phone EXS9950
Uniden Cordless Phone Logo
201 people viewed this question
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
