Celsuis to fahrenheit on thermostat how - Heating & Cooling
Posted by larry williams on
2 Related Answers
Anonymous
  • 130 Answers
SOURCE: how do i change -28
-28 celcius is -18.4 farenheit and if you want to conver more numbers ..click here http://www.wbuf.noaa.gov/tempfc.htm
Posted on Jan 16, 2011
canwoodjc
Canwoodjc
  • 3301 Answers
SOURCE: what is 200 celsuis in
200 ºC = 392 ºF
Posted on Sep 01, 2011
HOW TO REPAIR A THERMOSTAT
Hi, it won't cause your oven overheating by hanging loose. I think your thermostat is faulty. I don't suggest opening it to try and repair it yourself. If your tamper with the metal plates inside, your temperature will not be accurate as where you set it for 120 degrees Celcius or 248 fahrenheit it will meybe give you a true temperature of 220 degrees celcius or 428 fahrenheit which would be chaos. Rather rplace the complete thermostat unit.
May 03, 2014 | Bosch Ovens
Thermostat read out changed to cel instead of faren. .. How do I change it back?
hello cwest.... If your thermostat is reading Celsius instead of Fahrenheit press the 'Set Time' & 'Hold Temp' buttons at the same time to toggle it back to read Fahrenheit again.
J.
Jul 16, 2011 | White Rodgers 0754-1 Electric Water Heater...
How do i change -28 celsuis to fahrenheit
Jan 16, 2011 | White Rodgers White-Rodgers 1F85RF-275...
I want to use two independent Sub procedures: One to convert a temperature from Farenheit to Celsuis, and the other to convert a temperature from Celsuis to Farenheit
Save this as a vbscript (filename.vbs) and modify the language as needed. Should be pretty self explanatory let me know if that works.
Sub ConvertTemp()
temp = InputBox("Please enter the temperature in degrees F.", 1)
MsgBox "The temperature is " & Celsius(temp) & " degrees C."
End Sub
Function Celsius(fDegrees)
Celsius = (fDegrees - 32) * 5 / 9
End Function
Function Fahrenheit(cDegrees)
Fahrenehit = (cDegrees + 32) * 9/ 5
End Function
Apr 05, 2010 | Computers & Internet
Engine turns over but will not fire
Probably a bad fuel pump. Known to fail from one turn of the key to the next.
Mar 22, 2009 | 2000 Chevrolet Astro
Can't change my thermostat from fahrenheit to celsius.
When you do your system setup, Function 320 controls your temp. format. Set Function 320 to 1(celsius); Then press DONE. This will solve your problem.( Function 320 is defaulted to 0-Farenheit).
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
91 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
