Question about Omron Sport & Outdoor - Others
How do I merge 2 CSV Files in Omron HJ-7201TC to correct 3 months of entries labeled incorrect date format.
Posted by Gilles Cyr on
5 Related Answers
Anonymous
  • 108 Answers
SOURCE: how to move entries that are place in wrong chronological order in payments section
Most mature programs would do that as well as check to make sure the date format is consistent. Since I don't know what program you are using that's all the information I can give you.
Posted on Jan 24, 2008
Anonymous
  • 38 Answers
SOURCE: Labels printing in reverse order
It's not the printers, has to be the software.
Contact your vendor for support.
Steve
Posted on Mar 05, 2008
Axekick
  • 49 Answers
SOURCE: VTech model TM3111-2 the time
Assuming you are using [email protected] for your telephone service you should then;
type into your web browser address bar - 192.168.0.1
On the 'Setup' Tab with the sub category of basic setup look down towards the bottom of the screen for 'time setting.'
Click in the arrow for the drop down box and select your appropriate time zone.
Click on 'Save Settings' and you should be good after that.
Posted on Jan 07, 2009
Jutta24
SOURCE: omron walking style HJ-112
http://www.ccrane.com/instruction-manuals/omron-hj-112-premium-pedometer.pdf
This website has the instruction manual for the Omron pedometer. It may not be the exact same model as yours but it will still help. I just changed my batteries and have a different model which has the reset button on the back. Still, the basic stuff is there and I was able to re enter all info. Hope this helped.
Posted on Jan 17, 2009
Anonymous
  • 17 Answers
SOURCE: Calibration problems Zebra TLP 2844-Z
Your printing a 3 accross label, i think your ZPL command is wrong u must define the X and Y Coordinates of each field.
This is a sample of a ZPL command that i'd wrote. Im using a 1.5 x 1 inch. label
^XA ^PRC  ^LH0,0^FS ^LL203 ^MD0 ^MNN ^LH0,0^FS
(Design No. 1) ^BY2,3.0^FO40,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO64,136^AFN,45,13^CI0^FR^FDsample text^FS
(Design No.2) ^BY2,3.0^FO344,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO368,136^AFN,45,13^CI0^FR^FDsample text^FS
(Design No.3) ^BY2,3.0^FO649,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO673,136^AFN,45,13^CI0^FR^FDsample text^FS ^PQ1,0,0,N ^XZ ^FX End of job ^XA ^IDR:ID*.* ^XZ
I hope this will help you solve your problem...
Posted on Mar 20, 2009
HOW DO I SET MY OMRON TO SHOW HOW MANY MILES I WALKED
Hello there,
You dont need to friend, It does it for you. !!!!
You MUST calibrate the BEFORE use..
See the user guide . 'stride length'
If the initial settings are not correct, the measurement results may not be accurate
Dpwnload here.
http://healthcare.omron.co.in/manuals/HJ-321.pdf
You must set it to miles instead of Kilometres. See manual
Sep 18, 2014 | Omron Hip Pedometer With Holder -...
Omron gosmart hip pedometer hj-151 manual
Monitoring your personal exercise will surely result in a satisfactory feeling of well-being. Omron Pedometer gives exact readings of how many miles/kilometers you have walked. Here's your manual for Omron HJ-151
http://www.omronhealthcare.com/wp-content/uploads/hj-151-instruction-manual.pdf
Aug 23, 2012 | Omron Sport & Outdoor - Others
Newly purchased; does not turn on or activate (I have lost instructions)
Here's a link to the manual in PDF format. You will need adobe reader to read it.
http://www.omronhealthcare.com/media/uploads/hj-720itc-im_eng_final.pdf
Oct 12, 2010 | Omron Hj 720ITC Advanced Pocket Pedometer
Adjust stride length
I went online and used the Omron manual again. I had tried it before and it didn't seem to work but just persevered and had success.
Apr 06, 2010 | Omron Hj 720ITC Advanced Pocket Pedometer
Time & Date
1. To open the USER SETTINGS MENU. Open all three of the One-touch speed dialing panels. Then press the button labeled "Data Registration".
2. Press the "SET" button 2 times until you see:
USER SETTINGS - 1. DATE & TIME.
3. To open the DATE & TIME Menu. Press SET.
Use the buttons on the numeric keypad to enter the current month, day, year and current time. Just enter the new numbers over the old numbers.
To set the year, enter 08, 09, etc.
Use the 24-hours format to enter the time (e.g. 1:00 p.m. would be entered as 13:00)
You can also use the cursor buttons to move the cursor without changing a number entry.
To restore previous entry, press CLEAR.
Press SET to "lock in" the Date and Time.
Jul 10, 2009 | Canon LaserCLASS Fax 710 Printer
Data Transfer Failed
drop-down-icon-small-empty-arrow._v13355991_.gifNathan Price says: I had the same download problem, and after fiddling with the pedometer for a couple of hours I figured out the basis of the problem and was able to fix it. Being a software engineer, I figured that since it copies each day's data to memory once the clock clicks over to 12 AM, there must have been one day somewhere that had corrupt data. The download would always reach a certain percentage and then fail and as more days were saved, the percentage went up slowly. Unfortunately, Omron does not provide a mechanism to clear the internal memory inside the pedometer, which it really needs to do. The reset button on the back does NOT do this. The software on the computer has nothing to do with this problem. It is completely internal to the pedometer itself. In any case, to fix the problem, I just started setting the clock to 11:59 PM, waiting a minute and doing this quite a few times until the corrupt day's data was pushed out of memory. It holds 42 days, so eventually the data will be erased. Well, it fixed the problem! Of course, when the download finally worked the data was all screwed up. Then I just exported all the data to CSV, opened it up in a text editor and fixed the screwed up days, then re-imported the CSV file using the software.
Unfortunately, this whole process takes patience and a good knowledge of computers and software. Shame on Omron for not making it more user-friendly and providing a button to clear the memory or enabling the software to skip over and delete corrupt data. But hey, that's what you get for $30, software developed in India.
Nov 25, 2008 | Omron Hj 720ITC Advanced Pocket Pedometer
Unable to Change Dates
I am using MS-2007, i got the solution upto some level only.
i can't say exactly whether it is right or not.
my solution is :
first change the settings in ControlPanel/Regional and Language Options.
Click on Customize button/open the Date Tab and set the date format there.
and then proceed with CSV.
Open CSV in Excel and divide Text to coloumns.
Ur all Date Cells will be in particual Format.
and Select that coloumns and right click Format Celss....etc.
Thanking u.
If u found any Douts, Suggestions ,Plzz let me know.
Jun 27, 2008 | Excel (SS8SATAS5128400R)
Sport & Outdoor - Others Logo
165 people viewed this question
Top Omron Sport & Outdoor - Others Experts
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Ravindra Jog
Level 1 Expert
Are you an Omron Sport and Outdoor - Other Expert? Answer questions, earn points and help others
