Question about In Office Equipment & Supplies
SOURCE: Xerox Phaser 8560 Color not correct
the problem is not with the printer but it is with the ink that might be damaged, this is located inside the printer
Posted on Dec 01, 2009
SOURCE: my hp deskjet 1280 will not print yellow
Hello, this is Harry from www.BusinessSpread.co.uk.
We had the exact same problem when printing, we used 3 different 78 colour ink cartages and they all said 100% full but did not work. We then had a look at the dates on the box and they were all expired so when buying ink from anywhere even PC world or Curry’s always look at the expiry date.
Today I went to PC world and purchased a new 78 ink which said expires July 2011 and it works perfectly fine.
Regards,
Businessspread.co.uk
Posted on Jan 04, 2010
SOURCE: Have a Roland SP 540 V Eco Sol MAx printer/cutter.
you should have to use the syringe method to **** the ink before anything, then make a powerful cleaning, test, you may have to do it several cleanings and should be solved.
Posted on Feb 20, 2010
SOURCE: Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Posted on Mar 28, 2010
SOURCE: We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Posted on May 09, 2010
Mar 24, 2017 | Office Equipment & Supplies
Mar 31, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
Nov 17, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Apr 07, 2010 | HP Photosmart 3210 Printer
Nov 08, 2009 | Lexmark C540N PROD SPECS TBD Printer
Sep 01, 2009 | HP PhotoSmart 7960 InkJet Printer
Jul 02, 2009 | HP Hewlett Packard LaserJet 2605dn Printer
Apr 18, 2009 | Epson Stylus C86 InkJet Printer
Mar 22, 2008 | Epson Stylus C88 InkJet Photo Printer
Sep 03, 2007 | Brother MFC 420CN All-In-One InkJet...
22 people viewed this question
