Question about Tools & Hardware - Others
50mm nails for a parkside staple nail gun - Tools & Hardware - Others
Posted by ann williams on
5 Related Answers
Anonymous
  • 195 Answers
SOURCE: staple,nail gun, how do i install the nail properly
SHOULD BE A SPRING LOADED TAB LOCATED USUALLY AT THE REAR OF THE GUN. PRESS IN THEN DOWN AND SOULD POP OUT SO YOU CAN LOAD.
PLEASE RATE
THANKS
Posted on Mar 20, 2009
Anonymous
  • 288 Answers
SOURCE: How do you load nails into a stanley tre550 nail
there should be a button on the bottom rear of the gun, when you press it, it should release a bar that you pull back. the nails go in the dirction you nail them. sometimes the clips are too big for the guns and you have to break about an inch off of them
Posted on Dec 06, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: how do you load nails?
The staples are NOT loaded on top of the pull out shaft; they are inserted directly into the slot that opens when you pull the shaft out. If the nose of the tool is not placed firmly against a surface, it will not fire.
CLICK HERE
and click the PDF icon on the right of the model # to start the download.
Here is a step by step:
Unplug the tool.
Squeeze the end of the shaft at the rear bottom of the tool and pull out the shaft.
Flip the tool over on it’s back.
Insert the staples, (points up) and then slide the shaft back in.
Plug it in, press the on button (under the the power cord in the back). Press the nose squarely against the material and press the trigger
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Mar 06, 2010
CaptAdams35
Christopher
  • 28 Answers
SOURCE: how do you load nails in stanley tr250 staple and
The magazine on the TR250 has a recess on one side as well as a relief at the top where the driver pushes them through the opening. Load the brads/nails on that side of the magazine and it should operate properly. AS A REMINDER: ALWAYS REMOVE NAILS/STAPLES/BRADS WHEN NOT IN USE AS THIS WILL WEAKEN THE SPRING AND CAUSE FEED PROBLEMS IN THE FUTURE.
Posted on Mar 09, 2010
thesnooper
  • 342 Answers
SOURCE: Need help loading staples in my Stanley electric staple/nail gun
there should be a button / lever at the rear press it and it should open so as to insert the staples
Posted on Apr 05, 2010
My Pro 8000 stapler has about 20 staples jamed I need to how to unjam thew booklet does not show this
Clearing the Nail and
Staple Chamber
If, while using your Cobra
staple
and nail gun, it becomes necessary to
clear a jam from the staple chamber or
track, follow these instructions:
With the bottom of the gun
facing away from your face and
body, open the staple chamber by
squeezing and pulling the plastic
track release straight down away
from the base of the gun and
sliding the track back.(Fig 1)
(Note: the jammed staple or nail
may cause the track to be harder
to slide out than usual. Once the
staple or nail has been cleared,
the track will resume its normal,
free operation) Loose staples or
nails will be expelled from the
chamber.
Clear any remaining staples or
nails from the track and chamber
area.
Reload the Cobra staple and nail
gun and continue using.
May 17, 2017 | Staples Tools & Hardware - Others
How do I load the stapler?
Search Results
    Stanley electric stapler/brad nailer - YouTube
    ? 5:06
    https://www.youtube.com/watch?v=Zbgt2UXpS-M
    Dec 29, 2013 - Uploaded by Tindlez
    How to load staples and brad nails in Stanley electric staplermodel TREE550 ... Stanley SharpShooter Manual Staple and Brad Gun review ...
    Stanley Electric Staple/Nail Gun (TRE550) - YouTube
    ? 5:04
    https://www.youtube.com/watch?v=6JTZJjQ3wlA
    Jan 5, 2015 - Uploaded by HowToWith GEO
    This video tests the Stanley electric stapler and nail gun. Model TRE550. This video will test both staples and brad type nails. ...Stanley SharpShooter Manual Staple and Brad Gun review - Duration: 9:35. Unpack Guy 43,106 ...
    Safety Tips for an Electric Stapler : How to Load Staples into ...
    ? 1:01
    https://www.youtube.com/watch?v=dMsdmYBoojU
    Feb 5, 2008 - Uploaded by expertvillage
    Learn how to load staples into an electric stapler in this free educational video ... Stanley Electric Staple/Nail Gun (TRE550) - Duration: 5:04.
Jan 28, 2016 | Heavy Duty Stanley Bostich Heavy-duty...
How do I load nails into the 5700
Here is the link but I copied the instructions here too
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000035709.pdf
Loading Staples or Nails
Make sure there are no staples or nails jammed from previous usage by checking the handle operation.
CAUTION: IF A STAPLE OR NAIL IS JAMMED, POINT THE GUN AWAY FROM
YOURSELF AND OTHERS BEFORE OPENING THE TRACK AS THE JAMMED
STAPLE OR NAIL MAY BE FIRED OUT UPON OPENING
i) Point the bottom of the gun away from you and turn gun sideways.
ii) Turn gun up, grip track release buttons and push away to release, then slide the track out, as shown (fig. 1).
iii) Insert a strip of staples in the chamber with the legs pointing up (fig.1a). If nails are required, turn gun upside
down and tilt the gun away from yourself and load on the right hand side (as indicated on graphics at the
staple and nail exit) with point facing upwards (fig.1b) THE GUN MAY JAM IF NAILS ARE INSERTED IN THE
WRONG SIDE.
*Arrow
iv) Slide staple or nail track back into closed position - a click indicates that it is locked in position.
Your staple and nail gun is now ready for use.
May 20, 2011 | Garden
Apr 05, 2010 | Stanley Staple/Nail Gun Elec
Putting the nails inside the gun
Here is the manual http://www.arrowfastener.com/upload/manuals/79055020257_manual.pdf
Eric
Jan 24, 2010 | Staples Arrow T2025 Staple Gun For Flat &...
How do you load nails into a stanley tre550 nail staple gun?
Dec 06, 2009 | Stanley Tools TRE550 Electric Staple/Brad...
Tools & Hardware - Others Logo
118 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Andrew Taylor
Andrew Taylor
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
