Question about Blenders
How do you disassemble a kitchen aid immersion blender
Posted by Sue Bee on
5 Related Answers
Anonymous
SOURCE: Kitchen Aid Blender Rubber Coupling replacement
Someone else suggested a link that explains exactly how to unthread the old coupling... and it works. It took me about 90 seconds to fix my blender. But in case that link is dead, here's a summary:
(1) Note that the coupling (the round part with teeth) is threaded to the blender motor in reverse to a standard threading. So it screws off just like a bottle top, but in a clockwise direction.
(2) place the blender base on a tabletop, facing you. You should probably unplug it.
(3) take a punch or a flathead screwdriver, and place it against one of the coupling teeth that is furtherest away from you.
(4) strike the back of the screwdriver with a small hammer or maillot. The result will spin coupling clockwise. It may take several tries, but the coupling will eventually spin clockwise faster than the motor, and it will begin to unthread.
(5) unscrew the old coupling, and screw the new coupling into place (counterclockwise). Note that the new coupling will tighten itself every time you use your blender, so no need to worry about tightening it too much.
(6) Make a smoothie to celebrate your success!
Posted on Nov 10, 2007
Anonymous
  • 3 Answers
SOURCE: instruction manual for the bamix immersion blender
From the BAMIX.com website
Mayonnaise 1 egg (or 1 egg yolk) 1 teaspoon of lemon juice 1 teaspoon of herb vinegar 1 pinch salt 1 pinch pepper 1 ½ - 2 cups of oil 1 teaspoon of french mustard Put all the ingredients except the oil in a jug (not too large) and blend well with the WHISK. Then add the oil in a thin, steady stream (not drop by drop), processing all the time, until the mayonnaise has reached the required consistency. To achieve perfect results, all ingredients should be at the same temperature.
go back
Posted on Dec 22, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: need a schematic diagram for a kitchen blender
I think this will help a bit (p.2 only), although it seems a little crude to be a full service manual - this is a service manual for an Oster "Osterizer" Blender - one of the classics:
http://www.villaware.com/manuals/ProductService/Service/Sunbeam/4112.8.pdf
Here is one for a Philips blender, but once again, not as detailed as I've ever seen:
http://www.eserviceinfo.com/download.php?fileid=27616
These are the free one I could find. Generally, an authorized servicer is not allowed to distribute a full service manual, so you normally have to pay someone to get a complete service manual.
-Tha Mp3 Doctor
Posted on Apr 02, 2009
QuietRiot
  • 145 Answers
SOURCE: I need a coupling for
The piece that you need is referred to as the coupler. The coupler is a breakway part that is designed to shear and/or wear down in the event that the blender is overloaded. This is to avoid damage to the motor.
The coupler may be purchased individually and is an easy repair that can be done at home. You may purchase the part and access step-by-step replacement instructions at the following link:
http://www.mendingshed.com/kacoupling.html
Posted on Jul 07, 2009
Lance Hill
  • 1739 Answers
SOURCE: need new chopper bowl for the immersion blender by Wolfgang Puck
Replacement parts for Wolfgang Puck Immersion Blenders are available here:
http://www.wpcookware.com/categories.asp?cat=26
If you do not see the model number for your product or parts are not shown, suggest you contact their Customer service at 1-800-275-8273 to determine if the required replacement part is available for your model. Alternatively try making an inquiry via their webform:
http://www.wpcookware.com/contact.asp
Sorry someone has not responded sooner but just discovered this site.
Posted on Apr 01, 2011
Broken magnet of a Kitchen Aid Blender. Where can I find another one? KSB5WH4
From Kitchen Aid they only come on a new motor. I am a Kitchen Aid service agent and I remove them from burnt out motors and keep them. Look for a service agent near you and see if they can help you out. I have no idea where you are, I'm in New Zealand.
Apr 26, 2016 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Removing over the hood microwave
There is no microwave hood on a Kitchen Aid blender
Sep 06, 2014 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Oven will not heat up
Kitchen Aid blenders are used for chopping/blending not heating.
Apr 03, 2014 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Why the lights on my kitchen aid baking not coming on
Check for loose connections from mains cable to PCB and from PCB to motor. Check motor for circuit continuity, it may need a new motor, it is rarely the PCB.
Jul 26, 2013 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Need new chopper bowl for the immersion blender by Wolfgang Puck
May 02, 2010 | Wolfgang Puck Immersion Blender
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
I'm having a hard time disassembling my Kitchen Aid blender. Does the container come apart from the screw on the underside, detaching the plastic from the glass?
Have a look at the instructions here:
http://kitchenaidblenders.co.uk/KitchenAidBlenderGlassJugJarDisassembly/tabid/157/Default.aspx
This is for the glass jar which may be slightlt different.
Oct 02, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Blenders Logo
219 people viewed this question
Top Blenders Experts
Marvin
Marvin
ray gallant
Tom Chichester
Are you a Blender Expert? Answer questions, earn points and help others
