Question about Mitsubishi Televison & Video
Mitsubishi Ed 73733 I’ve lost all red colors - Mitsubishi Televison & Video
Posted by Nick Linamen on
Mitsubishi WD-73733 green blinking light will not turn on.
This is know as the blinkling light of death. You can get parts - just google TV Repair Kits
Mar 26, 2012 | Mitsubishi WD-73733 73" HDTV
My mitsubishi wd 73733 just made a popping sound and went off.when i tried to turn it back on its making noises with no picture goes from a green light to blinking red on lamp inicator do i need a bulb or...
You can actually go with just buying a bulb. I have seen many cases where televisions stopped displaying a picture due to a worn out bulb. The noise is also from the weak bulb.
Mar 13, 2011 | Mitsubishi WD-73733 73" HDTV
Want does yellow light mean
If I'm not mistaking I believe Mitsubishi shows the yellow light to indicate new bulbs needed and or overheating. Most common is overheat, but may actually be a bulb replacement required.
http://www.mitsubishi-tv.com/pdf/ownersguides/WD-73733.pdf
That is the manual for your TV
Mar 10, 2011 | Mitsubishi WD-73733 73" HDTV
No picture, have audio tv shuts off after 2 minutes
If you've replaced the lamp with a Mitsubishi lamp and not a generic, then the problem will be in one of two areas. Its either a bad ballast board (lamp power supply) or the color wheel assembly. If you've gotten a generic lamp, you may find that that's the reason its still not working properly. Many generic lamps are unsuitable for this product and will cause issues like low brightness, intermittent no start, and short lamp life. Also, make sure that the lamp door is properly installed because there is an interlock switch which will open if the door is not aligned properly.
michtech
Feb 14, 2009 | Mitsubishi WD-73733 73" HDTV
Need to align my mitsubishi wd-73733 dlp tv
We TV technicians don't go into alignment unless absolutley needed. I would stray away from alignments period unless you understand all of the ramifications that come with them.
Jan 08, 2009 | Mitsubishi WD-73733 73" HDTV
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
Televison & Video Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
